Home » Archived » Buckminster » Buckminster SVN [SOLVED](Problem with rmap)
Buckminster SVN [SOLVED] [message #656216] Thu, 24 February 2011 10:24 Go to next message
I'm trying to build my application with Buckminster but I'm stuck. It doesn't matter what I set in uri for the svn provider, I always have the same error. I have tried with both subversive and subeclipse support for svn. My svn repository is organized as follows:
+ myRepo
    + tags
    + branches
    + trunk
         + net.morcate.myApplication
         + net.morcate.myApplication.feature
         + net.morcate.myApplication.otherPlugins ....
This is the error that I get and my cquery, mspec, and rmap files. Sorry for the length of the post.
     [java] import '-P' '/home/joaquin/workspaceMyApplication/consoleBuild/build/build-387595675properties' '/home/joaquin/workspaceMyApplication/net.morcate.myApplication.releng/build/myApplication.mspec'
     [java] Platform install location: /home/joaquin/workspaceMyApplication/consoleBuild/tools/buckminster
     [java] Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
     [java] net.morcate.myApplication.feature:eclipse.feature: Using resolver rmap
     [java] net.morcate.myApplication.feature:eclipse.feature: Using resolver Local resolver
     [java] net.morcate.myApplication.feature:eclipse.feature: Trying provider local(materialized)
     [java] No materialization found for net.morcate.myApplication.feature:eclipse.feature
     [java] net.morcate.myApplication.feature:eclipse.feature: Trying provider local(workspace)
     [java] No open workspace project found that corresponds to net.morcate.myApplication.feature:eclipse.feature
     [java] net.morcate.myApplication.feature:eclipse.feature: Trying provider local(target)
     [java] net.morcate.myApplication.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/net.morcate.myApplication.feature): No component match was found
     [java] net.morcate.myApplication.feature:eclipse.feature: Using resource map file:/home/joaquin/workspaceMyApplication/net.morcate.myApplication.releng/build/myApplication.rmap
     [java] net.morcate.myApplication.feature:eclipse.feature: Using search path default
     [java] net.morcate.myApplication.feature:eclipse.feature: Trying provider svn(svn+ssh://localhost/svn/myRepo/trunk/{0}[svn+ssh://localhost/svn/myRepo/trunk/net.morcate.myApplication.feature])
     [java] ERROR   [0001] : java.lang.NoSuchMethodError: org.eclipse.buckminster.core.resolver.NodeQuery.getRevision()J
     [java] INFO:  TAG-ID 0001 = Query for net.morcate.myApplication.feature:eclipse.feature
     [java]
     [java] Doing full workspace refresh
     [java] Waiting for jobs to end
     [java] Java Result: 1
myApplication.cquery
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="myApplication.rmap">
    <cq:rootRequest name="net.morcate.myApplication.feature" componentType="eclipse.feature"/>
</cq:componentQuery>
myApplication.rmap
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
         xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
	<rm:searchPath name="default">
		<rm:provider readerType="svn" componentTypes="osgi.bundle,eclipse.feature,buckminster"
			mutable="true" source="true">
			<rm:uri format="svn+ssh://localhost/svn/myRepo/trunk/{0}">
				<bc:propertyRef key="buckminster.component"/>
			</rm:uri>
		</rm:provider>
	</rm:searchPath>
	<rm:locator searchPathRef="default" pattern="^net\.morcate\.myApplication\..*"/>
</rm:rmap>
myApplication.mspec
<mspec:mspec xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
             xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0"
             materializer="p2" name="myApplication.mspec" url="myApplication.cquery"
             conflictResolution="UPDATE">
	<mspec:property key="target.os" value="*" />
	<mspec:property key="target.ws" value="*" />
	<mspec:property key="target.arch" value="*" />
	<mspec:mspecNode filter="(buckminster.source=true)"
				     materializer="workspace"/>
</mspec:mspec>
[Updated on: Mon, 28 February 2011 04:51] by Moderator
Re: Buckminster SVN [message #656227 is a reply to message #656216] Thu, 24 February 2011 11:01 Go to previous messageGo to next message
I'm sure you have checked this, but
(1) The rmap is sending it to svn+ssh://localhost/svn/myRepo/trunk/net.morcate.myApplicati on.feature so have you verified that you can manually check out from that location?
(2) Does net.morcate.myApplication.feature actually contain a feature.xml, where the internal id is net.morcate.myApplication.feature? Note that the feature id and the directory or project name can be different. The feature id is what Buckminster looks for, not the directory name.
Matthew Webber
Re: Buckminster SVN [message #656347 is a reply to message #656227] Fri, 25 February 2011 03:41 Go to previous messageGo to next message
Matthew,
Thank you very much for your answer,
Unfortunately the problem remains the same:
(1) svn co svn+ssh://localhost/svn/myRepo/trunk/net.morcate.myApplicati on.feature checks out the module without any problem.
(2) I use the same name for the directory or module that for the feature.: net.morcate.myApplication.feature.
But still I think that the problem is in the URI in the rmap because doesn't matter what I put there (a wrong host, a wrong path to the module) I always get the same error.
Maybe it's just a silly mistake since this is my first attempt to build my application with Buckminster .....
Joaquin Morcate
Re: Buckminster SVN [message #656389 is a reply to message #656216] Fri, 25 February 2011 06:57 Go to previous messageGo to next message
Hi Joaquin,
I think your install is messed up. You get NoSuchMethodError on
NodeQuery.getRevision(). This tells me that your
org.eclipse.buckminster.subversion bundle is out of synch with the
org.eclipse.buckminster.core bundle.
Try a clean install.
Thomas Hallgren
On 2011-02-24 16:24, Joaquin Morcate wrote:
> + myRepo
> + tags
> + branches
> + trunk
> [java] import '-P'
> '/home/joaquin/workspaceMyApplication/consoleBuild/build/bui ld-387595675properties'
> '/home/joaquin/workspaceMyApplication/net.morcate.myApplicat ion.releng/build/myApplication.mspec'
> /home/joaquin/workspaceMyApplication/consoleBuild/tools/buck minster
> rmap
> Local resolver
> map
> file:/home/joaquin/workspaceMyApplication/net.morcate.myAppl ication.releng/build/myApplication.rmap
> path default
> provider
> svn(svn+ssh://localhost/svn/myRepo/trunk/{0}[ svn+ssh://localhost/svn/myRepo/trunk/net.morcate.myApplicati on.feature])
> org.eclipse.buckminster.core.resolver.NodeQuery.getRevision( )J
> [java] [java] Doing full workspace refresh
> <cq:componentQuery
> myApplication.rmap
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> </rm:rmap>
> myApplication.mspec
> </mspec:mspec>
Re: Buckminster SVN [message #656641 is a reply to message #656389] Sun, 27 February 2011 16:15 Go to previous messageGo to next message
Hi Thomas,
Thank you very much for you answer but I don't thisnk that there is something wrong in my installation. I have re-installed several times and in different computers (maybe I am make the same mistake every time). I have installed evrery thisn from these two sites:
http://localhost/BuckmisterHeadless-3.6
http://download.cloudsmith.com/buckminster/external
and this is the output of listsite for my buckmisnter installation:
$ ./buckminster listsite
Features:
  org.eclipse.buckminster.core.headless.feature (%featureName)
  org.eclipse.buckminster.emma.headless.feature (%featureName)
  org.eclipse.buckminster.pde.headless.feature (%featureName)
  org.eclipse.buckminster.product (Buckminster Product)
  org.eclipse.buckminster.subversive.headless.feature (Buckminster - Subversive based SVN support for headless operation)
  org.eclipse.equinox.p2.director.feature (%featureName)
Thank you very much again.
Regardas
Joaquin Morcate
Re: Buckminster SVN [message #656684 is a reply to message #656641] Mon, 28 February 2011 02:12 Go to previous messageGo to next message
On 2011-02-27 22:15, Joaquin Morcate wrote:
> Hi Thomas,
That's not correct. You should use http://download.cloudsmith.com/buckminster/external-3.6
Thomas Hallgren
Re: Buckminster SVN [SOLVED] [message #656689 is a reply to message #656684] Mon, 28 February 2011 02:46 Go to previous message
Hi Thomas,
Thank you! Thank you! Thank you very much! That was the problem! Have a nice week!
Joaquin Morcate
Previous Topic:How to remove old bundles from p2 sites?
Next Topic:Materializing workspace stops: "The target file is in an invalid format and could not be opene
Current Time: Tue Sep 16 00:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.06231 seconds
