Home » Eclipse Projects » EGit / JGit » team->share project->git NoWorkTreeException(Getting exceptions while trying to share a git project via egit)
team->share project->git NoWorkTreeException [message #655822] Tue, 22 February 2011 13:05 Go to next message
I am getting this exception when trying to team->share project->git. From my understanding, this would be thrown if I try to share a public repo. But I do not have any public repo inside my workspace.
Can someone throw light on the code path that is causing this exception, so that I can pinpoint the problem.
Parth
org.eclipse.jgit.errors.NoWorkTreeException: Bare Repository has neither a working tree, nor an index
	at org.eclipse.jgit.lib.Repository.getWorkTree(Repository.java:1089)
	at org.eclipse.egit.ui.internal.sharing.ExistingOrNewPage.fillTreeItemWithGitDirectory(ExistingOrNewPage.java:273)
	at org.eclipse.egit.ui.internal.sharing.ExistingOrNewPage.createControl(ExistingOrNewPage.java:141)
	at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
	at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:734)
	at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1162)
	at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1221)
	at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1218)
	at org.eclipse.jface.wizard.WizardDialog$6.run(WizardDialog.java:1207)
	at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1205)
	at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:894)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:426)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.team.internal.ui.wizards.ConfigureProjectWizard.openWizard(ConfigureProjectWizard.java:224)
	at org.eclipse.team.internal.ui.wizards.ConfigureProjectWizard.shareProjects(ConfigureProjectWizard.java:124)
	at org.eclipse.team.internal.ui.actions.ConfigureProjectAction$1.run(ConfigureProjectAction.java:39)
	at org.eclipse.team.internal.ui.actions.TeamAction$3.run(TeamAction.java:266)
	at org.eclipse.team.internal.ui.actions.TeamAction.run(TeamAction.java:263)
	at org.eclipse.team.internal.ui.actions.ConfigureProjectAction.execute(ConfigureProjectAction.java:33)
	at org.eclipse.team.internal.ui.actions.TeamAction.run(TeamAction.java:515)
	at org.eclipse.team.internal.ui.actions.TeamAction.runWithEvent(TeamAction.java:549)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: team->share project->git NoWorkTreeException [message #656118 is a reply to message #655822] Thu, 24 February 2011 04:58 Go to previous message
What is the output of "git config -l" on this repository ?
Previous Topic:Hooks and supported script languages?
Next Topic:Howto commit the deletion of a project
Current Time: Sun Jul 27 22:21:54 EDT 2025
Powered by FUDForum. Page generated in 0.03583 seconds
