Home » Modeling » TMF (Xtext) » Problem running GMFTools with Xtext/GMF integration
Problem running GMFTools with Xtext/GMF integration [message #656066] Wed, 23 February 2011 20:13 Go to next message
I'm trying to get Xtext/GMF integration to work. I've followed along the provided example and am now trying it on my own setup.
When I try to run the GMFTools, it seems like the generate .gmfgen and .transformed.gmfgen have lots of errors. These errors are of the sort 'Validation failed unexpectedly for ...".
I did the following:
1. Ran the .we2 file to generate .ecore and .genmodel files
2. From the .genmodel file, I generated .gmfgraph, .gmfmap, and .gmftool files. I put all of these files in org.xtext.example.<myDSL>.gfm.models plugin in the models/directory. I also copied the the .ext file and made it as follows:
import gmfgen;
import ecore;
// transforms the given GMFGenModel
List[emf::EObject] transform(List[emf::EObject] gmfGenModelContents) :
   let contents = gmfGenModelContents.eAllContents.addAll(gmfGenModelContents) :
   	contents.internalTransform() ->
   gmfGenModelContents;
internalTransform(GenEditorGenerator this) :
	setDomainGenModel(diagram.domainDiagramElement.genPackage.genModel)->
	setDomainFileExtension("hlm") ->
	setDynamicTemplates(true) ->
	setTemplateDirectory("org.xtext.example.hlm.gmf.models/templates");
internalTransform(GenPlugin this) :
	setPrintingEnabled(true) ->
	requiredPlugins.addAll({"org.xtext.example.hlm", "org.eclipse.xtext.gmf.glue"});
internalTransform(GenDiagram this) :
	setValidationDecorators(true) ->
	setValidationEnabled(true);
internalTransform(emf::EObject this) :
Then I went to Window ->Preferences -> GMFTools and setup the GMF models by adding the required files. I show the errors in the .gmfgen files.
Does anyone know what I'm doing wrong? I'm on Eclipse 3.6 using Xtext 1.0.1 plus latest GMFTools.
thanks
!ENTRY org.eclipse.gmf.validate 4 300 2011-02-23 17:03:26.855
!MESSAGE Validation failed unexpectedly for 'Tool Entry Function'. See log for details.
!STACK 0
	at org.eclipse.gmf.codegen.gmfgen.impl.GenNodeImpl.getReorientedIncomingLinks(GenNodeImpl.java:611)
	at org.eclipse.gmf.codegen.gmfgen.impl.GenNodeImpl.eIsSet(GenNodeImpl.java:369)
	at org.eclipse.gmf.codegen.gmfgen.impl.GenTopLevelNodeImpl.eIsSet(GenTopLevelNodeImpl.java:128)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObjectImpl.java:1247)
	at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:407)
	at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.next(EContentsEList.java:565)
	at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.handleCrossReference(EcoreUtil.java:1696)
	at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.crossReference(EcoreUtil.java:1672)
	at org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer.findExternalCrossReferences(EcoreUtil.java:1908)
	at org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer.find(EcoreUtil.java:1920)
	at org.eclipse.gmf.internal.validate.ExternModelImport.initializeExternPackages(ExternModelImport.java:142)
	at org.eclipse.gmf.internal.validate.ExternModelImport.getImporter(ExternModelImport.java:99)
	at org.eclipse.gmf.internal.validate.ExternModelImport$1.validate(ExternModelImport.java:73)
	at org.eclipse.gmf.internal.validate.ValidatorChain.validate(ValidatorChain.java:67)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:165)
	at org.eclipse.gmf.internal.bridge.transform.ValidationHelper$SmartDiagnostician.validate(ValidationHelper.java:96)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:143)
	at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:184)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:168)
	at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:180)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:114)
	at org.eclipse.gmf.internal.bridge.transform.ValidationHelper.validate(ValidationHelper.java:288)
	at org.eclipse.gmf.internal.bridge.transform.ValidationHelper.validate(ValidationHelper.java:320)
	at org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesOperation.validateGenModel(ExecuteTemplatesOperation.java:263)
	at org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesOperation.run(ExecuteTemplatesOperation.java:106)
	at org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesAction.run(ExecuteTemplatesAction.java:47)
	at de.itemis.gmf.tools.contribution.GmfDiagramCodeGenerator.generateDiagramCode(GmfDiagramCodeGenerator.java:35)
	at de.itemis.gmf.tools.contribution.GMFToolsGeneration.run(GMFToolsGeneration.java:97)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
	at de.itemis.gmf.tools.contribution.GMFToolsHandler.execute(GMFToolsHandler.java:59)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:820)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:796)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
!ENTRY org.eclipse.gmf.validate 4 300 2011-02-23 17:03:26.865
!STACK 0
	at org.eclipse.gmf.internal.validate.AnnotatedOclValidator.handleMetaModel(AnnotatedOclValidator.java:72)
	at org.eclipse.gmf.internal.validate.AnnotatedOclValidator.validate(AnnotatedOclValidator.java:47)
!ENTRY org.eclipse.gmf.validate 4 300 2011-02-23 17:03:26.875
!MESSAGE Validation failed unexpectedly for 'Tool Entry ParenthesizedExpression'. See log for details.
!STACK 0
!ENTRY org.eclipse.gmf.validate 4 300 2011-02-23 17:03:26.886
!STACK 0
and so on.....
What is shown in the Problems View.
Description	Resource	Path	Location	Type
The required feature 'targetMetaFeature' of 'Type Link Model Facet' must be set	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
The required feature 'targetMetaFeature' of 'Type Link Model Facet' must be set	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Feature Label Model Facet'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Feature Label Model Facet'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Feature Link Model Facet'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Feature Link Model Facet'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Figure Viewmap org.eclipse.draw2d.FreeformLayer'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Figure Viewmap org.eclipse.draw2d.FreeformLayer'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Figure Viewmap org.eclipse.draw2d.RectangleFigure'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Figure Viewmap org.eclipse.draw2d.RectangleFigure'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Figure Viewmap org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnectionEx'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Figure Viewmap org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnectionEx'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Context Menu'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Context Menu'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Custom Property Tab domain'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Custom Property Tab domain'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Diagram HLMModelEditPart'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Diagram HLMModelEditPart'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Diagram Updater MyHLMDiagramUpdater'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Diagram Updater MyHLMDiagramUpdater'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Editor Generator org.xtext.example.hlm.myHLM.diagram'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Editor Generator org.xtext.example.hlm.myHLM.diagram'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Editor View org.xtext.example.hlm.myHLM.diagram.part'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Editor View org.xtext.example.hlm.myHLM.diagram.part'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link ActionEditPart'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link ActionEditPart'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link ConditionEditPart'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link ConditionEditPart'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link DefaultEditPart'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link DefaultEditPart'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link StartupNextStateEditPart'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Link StartupNextStateEditPart'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Navigator Child Reference incoming links'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Navigator Child Reference incoming links'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Navigator Child Reference links'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Navigator Child Reference links'. See log for details.	MyHLM.transformed.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Validation failed unexpectedly for 'Gen Navigator Child Reference outgoing links'. See log for details.	MyHLM.gmfgen	/org.xtext.example.hlm/src-gen/org/xtext/example/hlm	Unknown	EMF Problem
Re: Problem running GMFTools with Xtext/GMF integration [message #656114 is a reply to message #656066] Thu, 24 February 2011 04:08 Go to previous messageGo to next message
that looks like the GMF versions don't match. GMF Tooling (not GMFTools)
used to come with new incompatible versions of their Ecore models every
now and then and usually installs UI actions to migrate existing gmf*
models.
Does the problem also appear when you're using plain GMF (no GMFTools)?
If so, please file a bug to Xtext otherwise to GMFTools.
Jan
Am 24.02.11 02:14, schrieb pgbackup@yahoo.com:
> it as follows:
> import gmfgen;
> import ecore;
> let contents =
> setDomainGenModel(diagram.domainDiagramElement.genPackage.ge nModel)- >
> setTemplateDirectory("org.xtext.example.hlm.gmf.models/templates ");
> thanks
> log for details.
> !STACK 0
> at
> org.eclipse.gmf.codegen.gmfgen.impl.GenNodeImpl.getReoriente dIncomingLinks(GenNodeImpl.java:611)
> at
> org.eclipse.gmf.codegen.gmfgen.impl.GenNodeImpl.eIsSet(GenNo deImpl.java:369)
> at
> org.eclipse.gmf.codegen.gmfgen.impl.GenTopLevelNodeImpl.eIsS et(GenTopLevelNodeImpl.java:128)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:1247)
> at
> org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:407)
> at
> org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.next(EContentsEList.java:565)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.handleC rossReference(EcoreUtil.java:1696)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.crossRe ference(EcoreUtil.java:1672)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .findExternalCrossReferences(EcoreUtil.java:1908)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .find(EcoreUtil.java:1920)
> at
> org.eclipse.gmf.internal.validate.ExternModelImport.initiali zeExternPackages(ExternModelImport.java:142)
> at
> org.eclipse.gmf.internal.validate.ExternModelImport.getImpor ter(ExternModelImport.java:99)
> at
> org.eclipse.gmf.internal.validate.ExternModelImport$1.valida te(ExternModelImport.java:73)
> at
> org.eclipse.gmf.internal.validate.ValidatorChain.validate(Va lidatorChain.java:67)
> at
> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:165)
> at
> org.eclipse.gmf.internal.bridge.transform.ValidationHelper$S martDiagnostician.validate(ValidationHelper.java:96)
> at
> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:143)
> at
> org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:184)
> at
> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:168)
> at
> at
> at
> org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:180)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:114)
> at
> org.eclipse.gmf.internal.bridge.transform.ValidationHelper.v alidate(ValidationHelper.java:288)
> at
> org.eclipse.gmf.internal.bridge.transform.ValidationHelper.v alidate(ValidationHelper.java:320)
> at
> org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesOperation.validateGenModel(ExecuteTemplatesOperation.java :263)
> at
> org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesOperation.run(ExecuteTemplatesOperation.java:106)
> at
> org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesAction.run(ExecuteTemplatesAction.java:47)
> at
> de.itemis.gmf.tools.contribution.GmfDiagramCodeGenerator.gen erateDiagramCode(GmfDiagramCodeGenerator.java:35)
> at
> de.itemis.gmf.tools.contribution.GMFToolsGeneration.run(GMFT oolsGeneration.java:97)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
> at
> org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
> at
> de.itemis.gmf.tools.contribution.GMFToolsHandler.execute(GMF ToolsHandler.java:59)
> at
> org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
> at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
> at
> org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
> at
> org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
> at
> org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
> at
> org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
> at
> org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
> at
> org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> log for details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.gmf.internal.validate.AnnotatedOclValidator.hand leMetaModel(AnnotatedOclValidator.java:72)
> at
> org.eclipse.gmf.internal.validate.AnnotatedOclValidator.vali date(AnnotatedOclValidator.java:47)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> and so on.....
> Unknown EMF Problem
> org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnection Ex'. See log
> Unknown EMF Problem
> Unknown EMF Problem
Re: Problem running GMFTools with Xtext/GMF integration [message #991148 is a reply to message #656066] Mon, 17 December 2012 09:30 Go to previous messageGo to next message
I am seeing the same exception when trying to create a generator model from a simple ecore file. Has any one heard of a solution or workaround to this issue? Thanks in advance!
Re: Problem running GMFTools with Xtext/GMF integration [message #1200618 is a reply to message #991148] Thu, 21 November 2013 05:24 Go to previous message
providing target feature for link mapping fixed it for me.
Previous Topic:duplicate validation
Next Topic:Force serialization of equal values?
Current Time: Thu Jul 17 20:19:37 EDT 2025
Powered by FUDForum. Page generated in 0.08628 seconds
