Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Papyrus UML Profiles(How to use UML profiles in Acceleo)
[Acceleo] Papyrus UML Profiles [message #655883] Tue, 22 February 2011 20:39 Go to next message
I created an UML profile with Papyrus, and now I have a model.profile.uml file with the metamodel, and an instance of this metamodel in instance.uml.
Now I'd like to generate code from it using Acceleo. Can I somehow import the meta-model into a template? I already tried to reference it via "platform:/resource/path_to_the_profile", but it keeps telling me that the metamodel couldn't be resolved.
Do I have to use the standard UML2 metamodel instead and use UML APIs, like getAppliedStereotypes(), instead?
Thanks in advance,
Jay
EDIT
Sorry for the double post, my connection lagged and I hit the submit button twice.
[Updated on: Tue, 22 February 2011 20:44] by Moderator
Re: [Acceleo] Papyrus UML Profiles [message #656056 is a reply to message #655883] Wed, 23 February 2011 17:31 Go to previous messageGo to next message
Hi Jay,
Perhaps i don't understand your question.
You created an uml profile, i' think you use it in a Uml model. If you intend to generate with acceleo from this model, you can access stereotype applied to your model elements with code like this :
[query public hasStereotype(e : Element, stereotypeName : String) : Boolean = (not self.getAppliedStereotype(stereotypeNameoclIsUndefined())/]
[query public stereoPropValue(e : Element, stereotypeName : String, propertyName : String) : String =
e.getValue(e.getAppliedStereotype(stereotypeName), propertyName)/]
stereotypeName must be qualified like this:
ProfileName::StereotypeName
Best regards
Re: [Acceleo] Papyrus UML Profiles [message #656057 is a reply to message #655883] Wed, 23 February 2011 17:31 Go to previous messageGo to next message
Hi Jay,
Best regards
sorry i' double post too Smile
[Updated on: Wed, 23 February 2011 17:36] by Moderator
Re: [Acceleo] Papyrus UML Profiles [message #656075 is a reply to message #655883] Wed, 23 February 2011 21:46 Go to previous messageGo to next message
Hi Philippe,
Thank you for your response.
I just thought that I have to call something like the following, but with my profile instead of the regular UML metamodel:
[module classBody('http://www.eclipse.org/uml2/3.0.0/UML')/]
Do I just have to use the UML metamodel and can still access stereotypes applied to my model elements?
Jay
Re: [Acceleo] Papyrus UML Profiles [message #656090 is a reply to message #656075] Thu, 24 February 2011 02:11 Go to previous messageGo to next message
Your model is an UML 2 model, use the regular UML metamodel.
You ll can access stereotype using getAppliedStereotype method on yours model elements.
Best regards
Re: [Acceleo] Papyrus UML Profiles [message #656273 is a reply to message #656090] Thu, 24 February 2011 15:11 Go to previous message
Thank you very much!
Jay
Previous Topic:[Acceleo] Papyrus UML Profiles
Next Topic:xPand and TaggedValues
Current Time: Fri Jul 25 16:49:55 EDT 2025
Powered by FUDForum. Page generated in 0.04705 seconds
