Home » Modeling » Epsilon » On ConstraintsBinding for Model validation with EVL
On ConstraintsBinding for Model validation with EVL [message #656034] Wed, 23 February 2011 15:07 Go to next message
Originally posted by: st.hennig.gmail.com
Hello!
I'm having a partitioned GMF based model editor and a metamodel that
makes use of EPackages. Now, I'm trying to integrate model validations
using Epsilon EVL. However, if I define each package in the
constraintsBinding element (extension), then a model validation always
fails with a NullPointerException (EvlValidator.java:76). If I define
only the topmost EPackage in the constraintsBinding, then the model
validation succeeds. But it affects only those elements which reside
directly within the defined EPackage.
Does anyone have any hint for me to get this working? I've prepared a
little example for the case I've explained the problem not clear enough.
Just send me an Email address I should send the zip file to.
Thanks a lot!
Cheers
Stefan
Re: On ConstraintsBinding for Model validation with EVL [message #656133 is a reply to message #656034] Thu, 24 February 2011 05:35 Go to previous message
Hi Stefan,
Could you please send the zip file to epsilon.devs gmail com?
Dimitris
Previous Topic:[EOL] Ennumerator with reserved keyword
Next Topic:[EVL] Validation on EMF editor
Current Time: Fri Jul 25 23:00:04 EDT 2025
Powered by FUDForum. Page generated in 0.03973 seconds
