Home » Archived » BIRT » Preview fails when parameters present
Preview fails when parameters present [message #655848] Tue, 22 February 2011 15:03 Go to next message
I am developing BIRT reports in 2.3.2. When I attempt to preview a report in the development environment that has no parameters, the preview works fine. However, when I preview a report that has parameters, the parameter prompts appear. Then, when I click OK, I receive the following error...
java.lang.ClassCastException: java.lang.NoSuchMethodError incompatible with java.lang.Exception
Our team is using jsp pages and the BIRT Viewer to view the reports in production which works fine. It's only in the development environment that we are having an issue.
Any thoughts on why this would behave like this?
Any help would be greatly appreciated.
-Don
Re: Preview fails when parameters present [message #655865 is a reply to message #655848] Tue, 22 February 2011 16:52 Go to previous messageGo to next message
Don,
Can you post an example report that contains the issue?
Jason
> -Don
Re: Preview fails when parameters present [message #655946 is a reply to message #655848] Wed, 23 February 2011 08:31 Go to previous messageGo to next message
Jason,
I've included a simple report I put together using the Classic Models SampleDB. This fails with the same error when I click the OK button on the "Enter Parameters" dialogue of the Preview.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_20090202 Build &lt;2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<parameters>
<scalar-parameter name="custNbr" id="9">
<property name="valueType">static</property>
<property name="dataType">integer</property>
<property name="paramType">simple</property>
<text-property name="promptText">Enter the Customer Number:</text-property>
<property name="controlType">text-box</property>
<property name="defaultValue">157</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="state" id="10">
<property name="dataType">string</property>
<text-property name="promptText">Enter the State</text-property>
<property name="defaultValue">PA</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
<text-property name="displayName"></text-property>
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="rptDs" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<property name="displayName">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<property name="displayName">CUSTOMERNAME</property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<property name="displayName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<property name="displayName">CONTACTFIRSTNAME</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">custNbr</property>
<property name="nativeName"></property>
<property name="nativeDataType">4</property>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
<structure>
<property name="name">param_2</property>
<property name="paramName">state</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
</list-property>
<property name="queryText">select
CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER,
CLASSICMODELS.CUSTOMERS.CUSTOMERNAME,
CLASSICMODELS.CUSTOMERS.CONTACTLASTNAME,
CLASSICMODELS.CUSTOMERS.CONTACTFIRSTNAME
from CLASSICMODELS.CUSTOMERS
where CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER = ?
and CLASSICMODELS.CUSTOMERS.STATE = ?</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
<design:attributes>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
</design:DataSetParameters>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="11">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="columnName">PHONE</property>
<property name="displayName">PHONE</property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<property name="displayName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<property name="displayName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="columnName">CITY</property>
<property name="displayName">CITY</property>
</structure>
<structure>
<property name="columnName">STATE</property>
<property name="displayName">STATE</property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<property name="displayName">POSTALCODE</property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<property name="displayName">COUNTRY</property>
</structure>
<structure>
<property name="columnName">SALESREPEMPLOYEENUMBER</property>
<property name="displayName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<property name="displayName">CREDITLIMIT</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<property name="queryText">select *
from CLASSICMODELS.CUSTOMERS</property>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="12">
<property name="width">100%</property>
<property name="dataSet">rptDs</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CONTACTLASTNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CONTACTFIRSTNAME"]</expression >
</structure>
</list-property>
<column id="36"/>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<header>
<row id="13">
<cell id="14">
<label id="15">
<text-property name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property name="text">CUSTOMERNAME</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property name="text">CONTACTLASTNAME</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property name="text">CONTACTFIRSTNAME</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<data id="24">
<property name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property name="resultSetColumn">CONTACTLASTNAME</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property name="resultSetColumn">CONTACTFIRSTNAME</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="31">
<cell id="32"/>
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
</row>
</footer>
</table>
</body>
</report>
Re: Preview fails when parameters present [message #655962 is a reply to message #655946] Wed, 23 February 2011 09:31 Go to previous messageGo to next message
Don,
Are you using the allinone download for 2.3.2? What os are you running on?
Jason
On 2/23/2011 8:33 AM, Don wrote:
> Jason,
> id="1">
> 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property name="queryText">select CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER,
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:attributes>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="12">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="36"/>
> <column id="37"/>
> <column id="38"/>
> <column id="39"/>
> <header>
> <row id="13">
> <cell id="14">
> <label id="15">
> </label>
> </cell>
> <cell id="16">
> <label id="17">
> </label>
> </cell>
> <cell id="18">
> <label id="19">
> </label>
> </cell>
> <cell id="20">
> <label id="21">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="22">
> <cell id="23">
> <data id="24">
> </data>
> </cell>
> <cell id="25">
> <data id="26">
> </data>
> </cell>
> <cell id="27">
> <data id="28">
> </data>
> </cell>
> <cell id="29">
> <data id="30">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="31">
> <cell id="32"/>
> <cell id="33"/>
> <cell id="34"/>
> <cell id="35"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Preview fails when parameters present [message #655986 is a reply to message #655848] Wed, 23 February 2011 11:16 Go to previous messageGo to next message
Jason,
Our development is through IBM Rational Software Architect (RSA) so what's running is whatever got installed with that, as opposed to the All-in-one download. FYI - we are running RSA Version: 7.5.5.2 Build ID: 20100923_2051.
Our OS is XP.
Let me say this, that there are four developers on our team. Two of us can preview reports just fine. The other two are having issues. It seems that, even though we are supposed to have the same development software baseline, something is different between our installs. If you are familiar enough with the software to know what goes on when I click OK on the parameters page, that might give us an indication of what to compare between our separate installs of RSA.
Thanks for your help.
Don
Re: Preview fails when parameters present [message #655989 is a reply to message #655986] Wed, 23 February 2011 11:28 Go to previous messageGo to next message
Don,
In the navigator view do you see a reportname.rptconfig file? This
should get created when you run the report in the designer.
Jason
On 2/23/2011 11:17 AM, Don wrote:
> Jason,
> 20100923_2051.
> Our OS is XP.
> Don
Re: Preview fails when parameters present [message #655994 is a reply to message #655848] Wed, 23 February 2011 11:49 Go to previous messageGo to next message
Jason,
No there is no .rptconfig file corresponding to my report. Should there be? I thought this was only created once a report was successfully previewed.
Don
Re: Preview fails when parameters present [message #656013 is a reply to message #655994] Wed, 23 February 2011 13:09 Go to previous messageGo to next message
Don,
What directory is your workspace and eclipse install are in? Can you
compare this to the machines that are working?
Jason
On 2/23/2011 11:49 AM, Don wrote:
> Jason,
> previewed.
> Don
Re: Preview fails when parameters present [message #656021 is a reply to message #655848] Wed, 23 February 2011 14:19 Go to previous messageGo to next message
Jason,
All of us have our workspace on our C drives but we have multiple workspaces...most directly off of the C drive.
The eclipse executable is in C:\Program Files\IBM\SDP. However, there is a multitude of folders under this in which pieces of the entire Rational software is installed. Is there something specifically that we could compare from one machine to another?
Don
Re: Preview fails when parameters present [message #656219 is a reply to message #656021] Thu, 24 February 2011 10:32 Go to previous message
Don,
I was wondering if this was a disk permission issue. Any change you can
download the 2.3.2 allinone download as a test?
Jason
On 2/23/2011 2:19 PM, Don wrote:
> Jason,
> Don
Previous Topic:Setting margins for Excel output
Next Topic:Replace string with null
Current Time: Sun Jul 27 09:29:17 EDT 2025
Powered by FUDForum. Page generated in 0.28079 seconds
