Home » Archived » M2M (model-to-model transformation) » [ATL] automatic copy of a model
[ATL] automatic copy of a model [message #654917] Thu, 17 February 2011 10:44 Go to next message
Hello all,
I was wondering if ATL provides some means to make a copy of an input model to the output one.
Here's my situation:
I'd like to divide a transformation from model A to model B in two steps: First a from A to an intermediate_B. Second from A and intermediate_B to B.
In the second step i'd like to avoid writing many rules to make a one-one transformation, so i was searching for something that makes this transformation in automatic.
I hope I've explained clearly what I mean,
Nicholas
Re: [ATL] automatic copy of a model [message #655067 is a reply to message #654917] Fri, 18 February 2011 03:30 Go to previous messageGo to next message
Le 17/02/2011 16:44, nicholas a écrit :
> Hello all,
> Regards,
> Nicholas
You may have a look on the 'refining' mode of ATL, which could answer
your need (or not).
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] automatic copy of a model [message #655454 is a reply to message #654917] Mon, 21 February 2011 03:49 Go to previous messageGo to next message
Thanks Vincent,
I've tried a bit with this refining mode, but unfortunately it doesn't allow using "do" blocks and called rules which is a drawback in my opinion. Anyways I'll try to find some workaround to avoid this issue. Thanks anyway for the advice.
Nicholas
Re: [ATL] automatic copy of a model [message #655476 is a reply to message #655454] Mon, 21 February 2011 05:17 Go to previous messageGo to next message
Le 21/02/2011 09:49, nicholas a écrit :
> Thanks Vincent,
> Regards,
> Nicholas
Most uses of "do" blocks can be replaced by declarative code if thinking
of what we want in terms of sets and subsets. It is not a trivial
exercise when we are not used of such an approach, but the result is
always interesting and gives a step to next progress.
Cordialement
Vincent MAHÉ
Re: [ATL] automatic copy of a model [message #655941 is a reply to message #655476] Wed, 23 February 2011 07:21 Go to previous message
see msg 4158:[ATL] Model Copy
and
http://soft.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-transfor mations/EModelCopyGenerator.atl?revision=7689&view=marku p
could provide you some help in copying model without using the refining
mode
Kind regards
Previous Topic:[QVTo] Setting the parent (owner) of a new element
Next Topic:[ATL] resoveTemp and eopposite
Current Time: Sat Aug 30 22:20:51 EDT 2025
Powered by FUDForum. Page generated in 0.02675 seconds
