Home » Modeling » EMF » [CDO] TimeoutRuntime Exception while opening a session(Unable to open a session on a CDO Repository)
[CDO] TimeoutRuntime Exception while opening a session [message #655918] Wed, 23 February 2011 05:09 Go to next message
I am trying out CDO tutorial, my CDO server is set up and is running, following the steps in http://wiki.eclipse.org/Setting_up_a_CDO_Server.
But when i try to add a session on the given port(2036) in my client( cdo-server-xml
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
</acceptor>)
I get an TimeoutRuntime Exception saying,
Unable to open a session on the specified repository.
org.eclipse.net4j.util.concurrent.TimeoutRuntimeException.
I see from other similar posts that some net4j plugins are not added, on clicking Add Required plugins, and hence the problem.
http://www.eclipse.org/forums/index.php?t=msg&th=159149& amp;start=0&S=911c4e3ce991f567aeda2805d9169019
But i have manually checked all the net4j plugins in my launch configuration, and I see the same problem.
Though I see in my console that the CDO server has started, I am not able to reach the port 2036, using telnet too.
Can anyone clarify, if i am missing some prerequisite before creating a session.
Thanks in advance,
Manasa
Re: [CDO] TimeoutRuntime Exception while opening a session [message #655926 is a reply to message #655918] Wed, 23 February 2011 05:19 Go to previous messageGo to next message
Am 23.02.2011 11:10, schrieb manasa:
> </acceptor>)
After checking them manually, have you pressed "Add Required..." again?
Cheers
/Eike
http://www.esc-net.de
> Thanks in advance,
> Regards,
> Manasa
Re: [CDO] TimeoutRuntime Exception while opening a session [message #655928 is a reply to message #655926] Wed, 23 February 2011 05:56 Go to previous messageGo to next message
Yes, i have tried clicking Add Required Plugins, and without clicking it, after manually checking plugins.
But no luck with it.
Manasa
Re: [CDO] TimeoutRuntime Exception while opening a session [message #655930 is a reply to message #655928] Wed, 23 February 2011 06:16 Go to previous message
Please double check that not only the org.eclipse.net4j plugins are active but also these:
/org.eclipse.emf.cdo.net4j
/org.eclipse.emf.cdo.server.net4j
Cheers
/Eike
Am 23.02.2011 11:56, schrieb manasa:
> Yes, i have tried clicking Add Required Plugins, and without clicking it, after manually checking plugins. But no luck with it.
> Regards,
> Manasa
Previous Topic:running validation from an application (or a junit test)
Next Topic:[CDO] Net4j old version of h2 Db used in plugin
Current Time: Sat Jul 26 20:57:03 EDT 2025
Powered by FUDForum. Page generated in 0.03847 seconds
