invalid QName for EMF but not for javax.xml.namespace [message #655098] |
Fri, 18 February 2011 05:16  |
I have a QName value that works with javax.xml.namespace.QName but not with org.eclipse.emf.ecore.xml.type.internal.QName
I suppose that there is better check to follow W3C recommendation but due to this issue I cannot load the EMF resource.
Is there a way to avoid this check?
BTW you can test it with the following code:
final String qname = "https://editor";
new javax.xml.namespace.QName(qname);
new org.eclipse.emf.ecore.xml.type.internal.QName(qname);
You will see that it hrows the exception for the third line:
org.eclipse.emf.ecore.xml.type.InvalidDatatypeValueException: cvc-datatype-valid.1.2.1: invalid QName: https://editor
[Updated on: Fri, 18 February 2011 05:16] by Moderator
Re: invalid QName for EMF but not for javax.xml.namespace [message #655878 is a reply to message #655717] |
Tue, 22 February 2011 19:45  |
Aurelien,
Comments below.
Aurelien Pupier wrote:
> Hi Ed,
> Ed Merks wrote on Tue, 22 February 2011 07:20
>> This doesn't look like a QName to me. I.e., I don't think / is a
>> valid character in an NCName.
> I also think that it is not valid following w3c Recommendation.
> Unfortunately,
> - w3c Recommendation are just recommendation
> - w3c Recommendation are not very understandable( which is the correct
> patterns for a QName?)
> - default javax.xml allows to use '/'
> - the file that I get is generated by a third party with these bad
> QNames (yes there are several :()
> So I was wondering if there is way to ignore QName errors?
No.
> I don't find how to do it until now.
> Or do you know if there is a place where there is a readable and
> easy-understandable definition of QName?
http://www.w3.org/TR/1999/REC-xml-names-19990114/#ns-qualnam es
http://www.w3.org/TR/1999/REC-xml-names-19990114/#NT-NCName
> Regards,
FUDForum. Page generated in 0.04960 seconds
