Home » Archived » BIRT » Incorrect margins and paddings when generating DOC file
Incorrect margins and paddings when generating DOC file [message #655267] Fri, 18 February 2011 16:33 Go to next message
I am trying to do a report that will have a doc style for headers and indentation i.e.
1. Some topic
__The text here is alligned to the first leter
__1.2. Some subtopic
______Text here is also alligned to the first leter
By using styles I set correct margins (tried with paddings too) and everything looks good in PDF and HTML, but not in DOC.
Run the report here (very simple one) http://pics.daskalov.net/BIRT/SingleReport_short.rptdesign once to generate PDF and once DOC and will see the problem.
Word is just ignoring paddings and margins.
I tried with Indents, but then only the first line of any multi-line (like dynamic text) component is moved on right, while the next lines start from the beggining of the page.
Can you give me an advice how to move blocks of text on right, please? Is there a standard way for emulating "bullets and numbering"?
Re: Incorrect margins and paddings when generating DOC file [message #655522 is a reply to message #655267] Mon, 21 February 2011 09:46 Go to previous messageGo to next message
Anyone?
the obvious solution is to use 2 columns, the first used only to set indent on it, and second for the content.
But if there is a chance to do it with 1 column will be great.
Re: Incorrect margins and paddings when generating DOC file [message #655564 is a reply to message #655522] Mon, 21 February 2011 13:45 Go to previous messageGo to next message
Can you log a bug for this?
Jason
On 2/21/2011 9:46 AM, Stanislav wrote:
> Anyone?
Re: Incorrect margins and paddings when generating DOC file [message #655590 is a reply to message #655267] Mon, 21 February 2011 15:36 Go to previous message
I will try, haven't done it ever.
[Updated on: Mon, 21 February 2011 15:37] by Moderator
Previous Topic:Howto create a Timedimension
Next Topic:Expose BIRT Reports
Current Time: Fri Jul 25 22:57:25 EDT 2025
Powered by FUDForum. Page generated in 0.05886 seconds
