ADT dependency errors in Helios [SOLVED] [message #655458] |
Mon, 21 February 2011 04:31  |
Hi. I'm new to Eclipse and programming in general. My problem is with trying to import ADT in Linux64 Helios. I'm using: ADT - https://dl-ssl.google.com/android/eclipse/ but when I select all and click next I receive a slew of dependency errors:
Cannot complete the install because of a conflicting dependency.
Software being installed: Android Development Tools 9.0.0.v201101191456-93220 (com.android.ide.eclipse.adt.feature.group 9.0.0.v201101191456-93220)
Software currently installed: Eclipse Platform 3.6.1 (Eclipse Platform 3.6.1)
Only one of the following can be installed at once:
International Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu 4.2.1.v20100412)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090822 (com.ibm.icu 4.0.1.v20090822)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090415 (com.ibm.icu 4.0.1.v20090415)
Cannot satisfy dependency:
From: Eclipse Platform 3.6.1 (Eclipse Platform 3.6.1)
To: com.ibm.icu [4.2.1.v20100412]
From: Android Development Tools 9.0.0.v201101191456-93220 (com.android.ide.eclipse.adt.feature.group 9.0.0.v201101191456-93220)
To: org.eclipse.wst.xml.ui 0.0.0
From: Java EMF Model Utilities 2.0.200.v200905140200 (org.eclipse.jem.util 2.0.200.v200905140200)
To: bundle com.ibm.icu [3.8.1.1,4.1.0)
From: Java EMF Model Utilities 2.0.201.v201001252130 (org.eclipse.jem.util 2.0.201.v201001252130)
From: Common Frameworks 1.1.300.v200904160730 (org.eclipse.wst.common.frameworks 1.1.300.v200904160730)
To: bundle org.eclipse.jem.util [2.0.100,3.0.0)
From: Validation Framework 1.2.102.v200905201610 (org.eclipse.wst.validation 1.2.102.v200905201610)
To: bundle org.eclipse.wst.common.frameworks [1.1.200,2.0.0)
From: Validation Framework 1.2.104.v200911120201 (org.eclipse.wst.validation 1.2.104.v200911120201)
From: Eclipse XML Editors and Tools 1.1.1.v200908242115 (org.eclipse.wst.xml.ui 1.1.1.v200908242115)
To: bundle org.eclipse.wst.validation [1.2.0,1.3.0)
From: Eclipse XML Editors and Tools 1.1.2.v201001222130 (org.eclipse.wst.xml.ui 1.1.2.v201001222130)
Not really sure what this all means. Could someone translate for me?
[Updated on: Tue, 22 February 2011 04:43] by Moderator
FUDForum. Page generated in 0.10565 seconds
