Home » Eclipse Projects » EclipseLink » How to configure batch-writing parameter for sybase
How to configure batch-writing parameter for sybase [message #645056] Wed, 15 December 2010 07:43 Go to next message
In our application we have a requirement to insert huge data to Sybase database (upto 5 lakhs of records). We are using JPA + Eclipselink.
I optimizing the code to improve the performance and came across the method batch-writing.
In a MySql server to persist 10k records as a batch it take 3.9 seconds and the same 10k records takes around 45 seconds in Sybase by using batch-writing.
I tried all the options to configure batch-writing in persistence.xml i.e "JDBC" and "Buffered". In this JDBC gives a good performance comparitively to Buffered while persisting in MySql server but its still same with Sybase.
Please help me out how do I optimize or tune to achive the same in Sybase server. (from 45 seconds to 4 sec)
Re: How to configure batch-writing parameter for sybase [message #645106 is a reply to message #645056] Wed, 15 December 2010 10:35 Go to previous messageGo to next message
JDBC batch writing requires that the JDC driver support parametrized batch writing. Some JDBC drivers do not support this, so this optimization will not be available. Check with your JDBC driver to see what it supports, and see if there are any other drivers available.
If parametrized batch writing is not supported, then you could try dynamic batch writing. To enable this set "eclipselink.jdbc.bind-parameters" to "false", and batch writing to either "JDBC" or "Buffered".
Re: How to configure batch-writing parameter for sybase [message #655443 is a reply to message #645106] Mon, 21 February 2011 02:21 Go to previous message
Hi James,
Thanks for the suggestions. But unfortunately I am still facing the same issue in performance.
I looked in to database side also.
I am not sure how it differs from MySql databse + windows O.S and Sybase database + Unix O.S which gives lot of performance difference as I had already discussed in my previous query.
I need help to increase performance on Unix + Sybase setup. Please let me know if any suggestions and help me.
Previous Topic:Running CanonicalModelProcessor in maven causes 100% CPU usage
Next Topic:execute update
Current Time: Wed Jul 23 07:52:03 EDT 2025
Powered by FUDForum. Page generated in 0.04342 seconds
