Helios: Unhandled event loop exception [message #654433] |
Tue, 15 February 2011 13:19  |
I started to have this error that i cannot trace back to my app (i use "org.eclipse.nebula.widgets" NumberFormatter, that woked pretty well in previous versions of Eclipse).
This error does not seem affect anything crucial...
Thanks.
!ENTRY org.eclipse.ui 4 0 2011-02-15 18:14:42.716
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(Unknown Source)
at org.eclipse.jface.internal.databinding.swt.SWTVetoableValueD ecorator$1.handleEvent(SWTVetoableValueDecorator.java:38)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Text.verifyText(Text.java:2066)
at org.eclipse.swt.widgets.Text.sendKeyEvent(Text.java:1517)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1099 )
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1508)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4268)
at org.eclipse.swt.widgets.Text.WM_CHAR(Text.java:2175)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4160 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2170)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 59)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3655)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at rcpcolibri.ui.workbench.actions.OpenPreferencePageAction.run (OpenPreferencePageAction.java:90)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at rcpcolibri.Application.start(Application.java:56)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
FUDForum. Page generated in 0.17963 seconds
