Home » Modeling » TMF (Xtext) » Hook after edits
icon5.gif  Hook after edits [message #644085] Thu, 09 December 2010 07:31 Go to next message
I want to process changes to the model immediately. I expect a hook to which I can register my code which is then called with the changed EObject as parameter.
Imagine something like a code generator which works real-time (in a background job) instead of batch.
Any advise?
Marco
Re: Hook after edits [message #644106 is a reply to message #644085] Thu, 09 December 2010 09:21 Go to previous messageGo to next message
Hi Marco,
you could try to register an
org.eclipse.xtext.ui.editor.model.IXtextModelListener
Sebastian
Am 09.12.10 13:31, schrieb Marco:
> Any advise?
> Marco
Re: Hook after edits [message #644135 is a reply to message #644106] Thu, 09 December 2010 11:04 Go to previous messageGo to next message
Sebastian,
Thank you for your quick answer.
There is no service I can use to register the listener. So I need to register to the XTextDocument, right? So I need to register it to all XTextDocuments for which an editor was opened, right? What is then the hook to use to act when a document was opened?
An IXtextModelListener.modelChanged just gets the resource. How can I then efficiently identify which object was just changed?
/m
Re: Hook after edits [message #644777 is a reply to message #644135] Tue, 14 December 2010 03:36 Go to previous messageGo to next message
Hi Marco,
you may want to use the IStateChangeEventBroker and inspect the deltas.
Sebastian
Am 09.12.10 17:04, schrieb Marco:
> Sebastian,
> /m
Re: Hook after edits [message #644855 is a reply to message #644777] Tue, 14 December 2010 08:35 Go to previous messageGo to next message
Hi Sebastian,
This works fine for the general notification. But the delta does not provide any specific information about the change EObject.
Comparing the content of new with the content of old would be quite slow. I am even not sure if I would recognize if there is a non-structural change like the value of a literal in an expression.
Do you have any further hint?
Marco
Re: Hook after edits [message #644881 is a reply to message #644855] Tue, 14 December 2010 10:15 Go to previous messageGo to next message
Hi Marco,
you could try to use some kind of hash in the user data of EObjects that
reflects the structure. Sorting the old descriptions and new
descriptions and walking both collections should be pretty fast if you
can simply compare the hash values.
There is no other protocol in Xtext available, but you could always use
an EMF adapter to get very fine grained notifications.
Sebastian
Am 14.12.10 14:35, schrieb Marco:
> Hi Sebastian,
> Marco
Re: Hook after edits [message #644888 is a reply to message #644881] Tue, 14 December 2010 10:50 Go to previous messageGo to next message
Sebastian,
For the hash approach I would need to define a post processing for the generator which would generate a hash method into each relevant EObject, right?
What is this EMF adapter thing?
BTW: Is there a simple method for a generic deep copy of a model. I want to take a quick snapshot for heavy processing in the background. This way I would then also compare the model with the latest snapshot instead of track all changes.
Thx,
Marco
Re: Hook after edits [message #644926 is a reply to message #644888] Tue, 14 December 2010 13:50 Go to previous messageGo to next message
Hi Marco,
I assumend that you customize your resource description manager to add
user data to the descriptions of EObjects. There is no need to generate
something into every EClass.
Please refer to the EMF documentation about Notifications and EAdapter
for details on this concept.
EcoreUtil.copy() is your friend if you want to create a deep copy.
Sebastian
Am 14.12.10 16:50, schrieb Marco:
> Sebastian,
> right?
> Thx,
> Marco
Re: Hook after edits [message #655343 is a reply to message #644926] Sat, 19 February 2011 11:43 Go to previous message
Hi Sebastian,
Could you kindly suggest where to hook up the EMF adapter to listen for model changes in the Xtext generated projects?
I have exactly the same requirements as Marco. But I'd like to use the model changes to customise the content assist and drive parts of the validation. I suspect the "MyDSL.ui" project is the right project, but where in the APIs is the appropriate place to hook the model change listener?
Thanks in advance.
Dayo
Previous Topic:popup actions on the editor text
Next Topic:Xtext as RCP but with integration in external JAVA SWT application.
Current Time: Fri Jul 18 03:35:33 EDT 2025
Powered by FUDForum. Page generated in 0.08543 seconds
