Home » Eclipse Projects » P2 » building p2 headless without a product/application(building p2 headless without a product/application)
building p2 headless without a product/application [message #655100] Fri, 18 February 2011 05:27 Go to next message
Hi guys!
I guess this should be a simple one for you experts out there ..
I have several plug-ins and features which I want to deliver with p2. But there is no product nor an application in these plug-ins.
I can build these features in Eclipse with buckminster or with the export wizard. But how can I achieve this headless?
tia
Re: building p2 headless without a product/application [message #655127 is a reply to message #655100] Fri, 18 February 2011 07:54 Go to previous messageGo to next message
On 02/18/2011 05:27 AM, Ch. S. wrote:
> Hi guys!
You build using eclipse/plugins/org.eclipse.pde.build_xxx/scripts/build.xml
The you create a "master feature" that includes all of your features,
and build that.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: building p2 headless without a product/application [message #655132 is a reply to message #655127] Fri, 18 February 2011 08:05 Go to previous messageGo to next message
that sounds like building a feature containing my features .. but that's too easy. Wink
1) I want to build a update site not a feature.
2) It shall be build headless.
Re: building p2 headless without a product/application [message #655145 is a reply to message #655132] Fri, 18 February 2011 08:46 Go to previous messageGo to next message
> too easy. ;)
Yes, it's building a feature of features. The output of the build (if
you have the p2 properties set) is a p2 repo that contains your features.
PW
Paul Webster
Re: building p2 headless without a product/application [message #655152 is a reply to message #655145] Fri, 18 February 2011 08:59 Go to previous messageGo to next message
Cool. That sounds straight-forward.
Pardon my noobness, but
1) how do I call
outside of Eclipse?
2) how do I set the p2 property?
Re: building p2 headless without a product/application [message #655159 is a reply to message #655152] Fri, 18 February 2011 09:12 Go to previous messageGo to next message
You have to setup a PDE build. There are some links at the end of this
post that describe it.
This is a simple builder that builds a master feature:
http://dev.eclipse.org/viewcvs/viewvc.cgi/platform-incubator /ui/org.eclipse.ui.automated.build/org.eclipse.ui.releng/bui lder/
Helpful links:
http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html
PDE Build help: http://help.eclipse.org/helios/index.jsp?nav=/4_2_0
Andrew's blogs: http://aniefer.blogspot.com/
Paul Webster
Re: building p2 headless without a product/application [message #655169 is a reply to message #655100] Fri, 18 February 2011 09:36 Go to previous messageGo to next message
If you already build with Buckminster you can build it headless with
Buckminster as well. To build a p2 site, you define a feature that
defines the content of the site (does by default not include itself).
There are various variations on this theme depending on what you want to
achieve - check out the buckminster forum, there are many posts about
headless builds, automated builds etc.
- henrik
On 2/18/11 11:27 AM, Ch. S. wrote:
> Hi guys!
> tia
Re: building p2 headless without a product/application [message #655995 is a reply to message #655159] Wed, 23 February 2011 11:29 Go to previous message
Or you might take a look at maven3/tych where its possible to build a
deployable feature (or a whole updatesite) from commandline/integration
server (eg hudson).
http://mattiasholmqvist.se/2010/06/building-with-tycho-part- 3-testing-code-coverage-and-easier-development-using-target- definitions/
https://github.com/sonatype/sonatype-tycho/tree/master/tycho -its/projects/TYCHO321deployableFeature/
"Paul Webster" wrote in message news:ijlu4t$um1$1@news.eclipse.org...
Helpful links:
Paul Webster
Previous Topic:how to find source update site of a plugin at runtime?
Next Topic:legacy sites and "new" updatemanager
Current Time: Fri Jul 18 19:51:35 EDT 2025
Powered by FUDForum. Page generated in 0.26026 seconds
