Home » Archived » BIRT » Problems with viewing report as PDF and also in Preview(View report as PDF)
Problems with viewing report as PDF and also in Preview [message #654834] Thu, 17 February 2011 06:22 Go to next message
Hi everybody,
recently I have started to use Birt to create reports from a database of research groups.
I have detected some problems when generating a PDF and also when making a preview of the report, due to long lines that appear in the database.
In my report, the data from the groups are collected in a table. In some cell I have added a grid with all the information. The problem is that when making a preview or generating the PDF, in the cells of the grid only the first line is shown, the rest of the content is cut off.
If I choose the option "View as DOC" all the contents in the table are shown but I have to resize the cells.
Do anybody know how to solve this problem with the PDF generator?
Thank you very much for your help.
Best regards
Re: Problems with viewing report as PDF and also in Preview [message #654941 is a reply to message #654834] Thu, 17 February 2011 12:05 Go to previous messageGo to next message
Is there any whitespace in the string? You may want to look at this:
//RE API method
http://dev.eclipse.org/newslists/news.eclipse.birt/msg30589. html
PDFRenderOption options = new PDFRenderOption();
options.setOption(IPDFRenderOption.PDF_HYPHENATION, true);
options.setOption(IPDFRenderOption.PDF_TEXT_WRAPPING, true);
options.setOutputFileName("output/resample/wordwrap.pdf");
options.setOutputFormat("pdf");
or
//javascript substring
http://www.birt-exchange.org/org/forum/index.php/topic/19827 -how-do-i-use-word-wrap-in-report-design/page__s__ad0bb32bbb ac95aee7b5556149417a73
Jason
On 2/17/2011 6:22 AM, Teresa Sanchez wrote:
> Hi everybody,
> research groups. I have detected some problems when generating a PDF and
> in the database.
> Best regards
Re: Problems with viewing report as PDF and also in Preview [message #655456 is a reply to message #654941] Mon, 21 February 2011 03:58 Go to previous messageGo to next message
Thank you Jason for your help, but I would like to know how to change the option in PDFRenderOption because I think that I don't have the source code.
I am using the the gui environment of Birt.
Again, thank a lot.
Teresa.
Re: Problems with viewing report as PDF and also in Preview [message #655518 is a reply to message #654834] Mon, 21 February 2011 09:39 Go to previous messageGo to next message
Hi Jason Weathersby,
Can you please explain how it script work and hot they get parameter - longStr and width?
function wrap(longStr,width){
length = longStr.length;
if(length <= width)
return longStr;
return (longStr.substring(0, width) + "\n" + wrap(longStr.substring(width, length), width));
Re: Problems with viewing report as PDF and also in Preview [message #655567 is a reply to message #655518] Mon, 21 February 2011 13:55 Go to previous messageGo to next message
longStr I believe in that example is whatever you pass in as a value.
For example in an expression wrap(row["mydata"], 20)
Width is the max length you want the string to be before inserting a new
line.
Jason
> longStr and width?
> if(length <= width)
> return longStr;
Re: Problems with viewing report as PDF and also in Preview [message #655568 is a reply to message #655456] Mon, 21 February 2011 13:56 Go to previous messageGo to next message
Teresa,
Currently there is no option to change this in the Viewer unless you
modify the source for it. Can you log a bug for this?
Jason
> source code.
> Again, thank a lot.
> Regards,
> Teresa.
Re: Problems with viewing report as PDF and also in Preview [message #655683 is a reply to message #655568] Tue, 22 February 2011 04:57 Go to previous messageGo to next message
Please explain where in report I need write this code?
Re: Problems with viewing report as PDF and also in Preview [message #655690 is a reply to message #655683] Tue, 22 February 2011 05:34 Go to previous messageGo to next message
If you have any example please send me
kolomiec_sergey@mail.ru
Thanks!
Re: Problems with viewing report as PDF and also in Preview [message #655695 is a reply to message #655690] Tue, 22 February 2011 05:40 Go to previous messageGo to next message
kolomiec_sergey(at)mail.ru
Thanks!
[Updated on: Tue, 22 February 2011 05:41] by Moderator
Re: Problems with viewing report as PDF and also in Preview [message #655802 is a reply to message #655695] Tue, 22 February 2011 11:29 Go to previous messageGo to next message
Are you using the API or the Viewer? If you are using the Viewer are
you going to modify the viewer source code?
Jason
On 2/22/2011 5:40 AM, Sergey wrote:
> If you have any example please send me kolomiec_sergey(at)mail.ru
> Thanks![/quote]
Re: Problems with viewing report as PDF and also in Preview [message #655932 is a reply to message #655802] Wed, 23 February 2011 06:24 Go to previous messageGo to next message
What is "the API"? For viewer I am using Actuate iPortal. I have little experience in creating Birt report, if you have example, how I can modify the viewer source code, please give me it.
Thanks!
Re: Problems with viewing report as PDF and also in Preview [message #655934 is a reply to message #655802] Wed, 23 February 2011 06:36 Go to previous messageGo to next message
No Message Body
[Updated on: Wed, 23 February 2011 06:39] by Moderator
Re: Problems with viewing report as PDF and also in Preview [message #655981 is a reply to message #655934] Wed, 23 February 2011 10:39 Go to previous messageGo to next message
I mean the Report Engine API. What version of the Actuate iPortal are
you using?
Jason
On 2/23/2011 6:37 AM, Sergey wrote:
> What is "the API"? For view I am using "Actuate iPortal". If you have
> any example how use "the API" please give me it.
> Thanks!
Re: Problems with viewing report as PDF and also in Preview [message #656271 is a reply to message #655981] Thu, 24 February 2011 15:04 Go to previous messageGo to next message
Actuate iPortal - 10.
I never use API. If you have any example please provide me.
Thanks!
Re: Problems with viewing report as PDF and also in Preview [message #656276 is a reply to message #656271] Thu, 24 February 2011 15:17 Go to previous messageGo to next message
Sergey,
I did some checking and currently this is not supported in iPortal.
Jason
> Thanks!
Re: Problems with viewing report as PDF and also in Preview [message #656423 is a reply to message #656276] Fri, 25 February 2011 09:51 Go to previous messageGo to next message
Are you have some information or example report or user guide about "API"?
Re: Problems with viewing report as PDF and also in Preview [message #656453 is a reply to message #656423] Fri, 25 February 2011 12:23 Go to previous message
Sergey,
Currently this is not possible with the Actuate APIs.
Jason
Previous Topic:Bar Chart vertical axis scaling question
Next Topic:HowTo - Scripting - Dinamically get Images...
Current Time: Wed Jul 23 14:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.05714 seconds
