Home » Language IDEs » Java Development Tools (JDT) » [SOLVED] How to get notified when user closed an editor file without saving it?
[SOLVED] How to get notified when user closed an editor file without saving it? [message #653607] |
Thu, 10 February 2011 06:47  |
Hi all,
I am using IBufferChangeListeners and an IResourceChangeListener to keep track of the textual changes in an eclipse project. My problem is that, whenever the user makes a change, I also do the same change in a copy project (that is in sync with the original one). This works great, however for the implementation reasons I have to save the copy project even if the user does not save the original files.
My problem is that if the user closes the file editor in Eclipse and does not save his/her changes, since I have already saved them in the copy project, the projects got out of sync. Thus, I need to get a notification when user does this (i.e., closes a file editor without saving it). My questions:
1- I don't get any ResourceChangedEvents or BufferChangedEvents when this happens, is this normal? (It seems like)
2- Is there an extension point in Eclipse API to do what I want? If so, could you please point me some code, documentation or a clue?
3- If not, is this doable? Again, could you point me a starting point to dig up the code?
Thanks a lot in advance, best regards,
[Updated on: Wed, 16 February 2011 17:35] by Moderator
Re: How to get notified when user closed an editor file without saving it? [message #653623 is a reply to message #653607] |
Thu, 10 February 2011 07:53   |
On 10.02.2011 12:47, Kivanc Muslu wrote:
> Hi all,
> so, could you please point me some code, documentation or a clue? 3-
Yes, either use an IPartListener2 or use file buffers instead of the
IBufferChangeListeners.
Dani
Re: How to get notified when user closed an editor file without saving it? [message #654746 is a reply to message #653623] |
Wed, 16 February 2011 17:34  |
Hi Dani,
Thanks for the suggestions. Though I could only had little chance to look at the APIs you have mentioned, I have found another solution to my problem and will share the high level algorithm here, in case anybody else faces the same problem.
To apply this solution, you need to have a very similar situation as in my case: you need a shadow file that is always in sync (even if the changes are not saved), and have a buffer listener in the original file.
So, every time a buffer is closed (i.e., file is closed from the editor), it signals a BufferChangeEvent. You can detect this as a special event by checking
event.getBuffer().isClosed()
When you see that the buffer is really closed, then you can go through the resource, compilation unit and get its new buffer to see its updated contents. When the changes are not saved, though no additional BufferChangeEvents are signaled, the new buffer attached to the same resource will have the correct (i.e., correct with discarded changes) contents. Then, you can compare this contents with your shadow file's contents and sync them in case they differ.
Again Dani, thanks for all help!
Current Time: Sat Jul 26 23:39:53 EDT 2025
Powered by FUDForum. Page generated in 0.56370 seconds
