Home » Eclipse Projects » JFace » Multiple ApplicationWindow-instances?
Multiple ApplicationWindow-instances? [message #654425] Tue, 15 February 2011 12:24 Go to next message
I'm developing a JFace application using the ApplicationWindow class as the main entrypoint. Now I want to support multiple instances of my application(window) within one JVM. Is this possible with the ApplicationWindow? My experiments ended with UI-thread/-events problems.
Re: Multiple ApplicationWindow-instances? [message #654441 is a reply to message #654425] Tue, 15 February 2011 14:30 Go to previous messageGo to next message
On 02/15/2011 12:24 PM, gattacus@gmail.com wrote:
> Hi I'm developing a JFace application using the ApplicationWindow class
You can create multiple ApplicationWindows if you want.
The pattern would be:
void main(String[] args) {
create display
create and open app window 1
create and open app window 2
run display loop
How did you get off the UI thread? Or did you setBlockOnOpen(*) on your
windows?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Multiple ApplicationWindow-instances? [message #654451 is a reply to message #654425] Tue, 15 February 2011 15:30 Go to previous messageGo to next message
yes, I am using setBlockOnOpen(true). My idea was to have each instance in its own threadgroup. This would make it possible to get the instance from within other (associated) components by using static getInstance(). the singleton pattern is heavily used and a problem in the multiple-window case. so I am looking for a way to circumvent the issue. Any other idea?
Re: Multiple ApplicationWindow-instances? [message #654491 is a reply to message #654425] Tue, 15 February 2011 21:31 Go to previous messageGo to next message
Originally posted by: quincy.cs.gmail.com
I found it very easy to do it with rcp. Any reason not to use rcp?
Quincy Mitchell
wrote in message news:ijecgr$mtg$1@news.eclipse.org...
Re: Multiple ApplicationWindow-instances? [message #654636 is a reply to message #654491] Wed, 16 February 2011 09:36 Go to previous messageGo to next message
Eclipse User wrote on Tue, 15 February 2011 21:31
several: big footprint, does not conform to my user experience vision and switching would cause a lot of work.
Re: Multiple ApplicationWindow-instances? [message #654677 is a reply to message #654451] Wed, 16 February 2011 11:00 Go to previous message
You cannot do that. SWT, like AWT, runs in a single UI thread.
You need to create and open one or more windows, and then run the
display loop.
You can use WindowManager to keep track of your multiple windows, even
to group them and close them together.
PW
Paul Webster
Previous Topic:TableViewer use case
Next Topic:examples of cut/copy/paste of domain objects in TableViewer
Current Time: Fri Jul 25 11:39:18 EDT 2025
Powered by FUDForum. Page generated in 0.06877 seconds
