Home » Eclipse Projects » Eclipse Platform » Missing bin suffix at getCodeSource().getLocation()
Missing bin suffix at getCodeSource().getLocation() [message #654360] Tue, 15 February 2011 06:56 Go to next message
I am developing a eclipse plugin and trying to get the location uri of the corresponding class path. It works fine with the exported jar file. As I am still developing the plugin, I cannot use debug features with a jar file. If I start the plugin direct, the following code return the project root path, without the needed bin suffix.
I have created a new Hello World project, which just returns the location of the code source and the bin suffix is still missing.
this.getClass().getProtectionDomain().getCodeSource().getLoc ation().toString()
I am using the Helios Service Release 1 (20100917-0705) and no update are available.
I have searches for a long time on google, but have not found any solution. Have someone a hint for me for solving my problem?
Thomas
Re: Missing bin suffix at getCodeSource().getLocation() [message #654363 is a reply to message #654360] Tue, 15 February 2011 07:32 Go to previous messageGo to next message
What are you trying to do, exactly? You have a project in eclipse that
you are currently working on, and you want to run "what" on it that you
need to find its classpath? Do you want to run it in your eclipse on
your working project?
Or you are going to launch an inner Eclipse app? Java app? and you'd
like to operate on what from the inner?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Missing bin suffix at getCodeSource().getLocation() [message #654365 is a reply to message #654363] Tue, 15 February 2011 07:50 Go to previous messageGo to next message
Paul Webster wrote on Tue, 15 February 2011 07:32
I am creating a non eclipse data transformation with antlr. The transformation classes are loaded dynamically for all parts, during creation of the transformator. This part is already working as a standalone java project, as file://... and jar resource.
This transformation is used in a graphical and textual editor and it works fine, when I import the transformation project as jar file and add the classpath to the editors, as the the package is at the top level of the jar file.
To allow debugging of the transformator within the eclipse run-time environment I have changes the project type of the transformator to a plugin project and started the run-time environment. The transformation parts are not found anymore, as the binary files are store in $(projectRoot)/bin the getCodeSource().getLocation() returns $(projectRoot) only.
The transformation package is used in a standalone application and a eclipse plugin. The second does only work with a jar file, not a normal (plugin) project.
Re: Missing bin suffix at getCodeSource().getLocation() [message #654382 is a reply to message #654365] Tue, 15 February 2011 09:07 Go to previous messageGo to next message
So you are in an eclipse environment, and you need to access files from
within the project?
Option one: If your tool is an eclipse plugin, use core.resources to
access projects in the workspace. But it sounds like you need something
that doesn't care about an eclipse workspace.
Option two: You've created your project, launched an inner, and want it
to find the files correctly from your plugin. Use Bundle.getEntry(*)
which returns a URL (which returns an InputStream). It will return a
useful URL/InputStream when run from a project in eclipse or after your
project has been deployed as a <plugin>.jar
PW
Paul Webster
Re: Missing bin suffix at getCodeSource().getLocation() [message #654402 is a reply to message #654382] Tue, 15 February 2011 10:31 Go to previous messageGo to next message
I will explain my project dependencies.
STI-Project:
I am using simple transformation infrastructure for translating between different models. It scans within a given package name for classes with a runtime annotation. Checks theses classes for a method with a given name and put the type of the first parameter to as key and a callback object as value in a look-up map.
ATransformation-Project:
This project provides the transformation classes for the model elements.
Both projects are not eclipse plug-ins, therefore they cannot use the eclipse platform framework.
AModelEditor-Project:
Is an gmf editor, which uses the STI and ATransformation projects for a transformation.
The junit tests for STI- and ATransformation-projects works fine, while using the eclipse project or the exported project jars.
I have converted the STI- and ATransformation-projects as eclise plugins, to add these as dependencies in the AModelEditor project. If I export the STI- and ATransformation-Project as "Deployable plug-in and fragments", the transformation works fine, as the package is exported to the root of the jar file.
If I just start the AModelEditor-Plugin with the STI- and ATransformation-projects as dependencies for debugging purposes, the transformation classes are not found, as the AnAnnotationClass.class.getProtectionDomain().getCodeSource( ).getLocation() does not return the binary folder ($project/bin), but the project root. AnAnnotationClass.class is part of the ATransformation-project, which contains the transformation classes.
I have tried a lot of changes in plugin.xml or the MANIFEST.MF, but with no success. And all resources on the web I have found, tells that ....getCodeSource().getLocation() returns the binary folder. On my machine it's the project root.
How can I change the plugin.xml or the MANIFEST.MF, so that the AnAnnotationClass.class.getProtectionDomain().getCodeSource( ).getLocation() returns the binaryFolder and not the project root folder?
Re: Missing bin suffix at getCodeSource().getLocation() [message #654449 is a reply to message #654402] Tue, 15 February 2011 15:12 Go to previous messageGo to next message
> machine it's the project root. How can I change the plugin.xml or the
AFAIK you cannot. That information is coming from the OSGi classloader
(which isn't in any way based on a real classpath). When eclipse
launches and includes projects from your workspace as plugins, it is
launched in a special mode for projects that are plugins and passed in a
dev.properties file that instructs it to load classes from that project
in a special place. In my example, that file has entries like:
org.eclipse.e4.core.services=bin
org.eclipse.e4.ui.css.jface=bin
etc.
So the problem is you need to have the STI plugin walk classes provided
by the ATransformation plugin so you can scan for runtime annotations,
and then apply that to the AModelEditor project?
PW
Paul Webster
Re: Missing bin suffix at getCodeSource().getLocation() [message #654566 is a reply to message #654449] Wed, 16 February 2011 05:43 Go to previous messageGo to next message
Paul Webster wrote on Tue, 15 February 2011 21:12
I don't understand the apply. The AModelEditor uses the ATransformation plugin to transform the edited model. I am using aClassLoader.getResources(package.replace('.', '/')) and directory search to find the classes.
The real problem depends on this How to list files in a bundleresource:// URL?
And it seems there is no solution for me, I tried to go around this problem with .getCodeSource().getLocation().
Perhaps there is a very simple solution. Is there a way to use the normal java project (no plug-in) in eclipse plug-in projects, including debugging and hot code replace?
Re: Missing bin suffix at getCodeSource().getLocation() [message #654612 is a reply to message #654566] Wed, 16 February 2011 08:41 Go to previous messageGo to next message
thanks for information
Re: Missing bin suffix at getCodeSource().getLocation() [message #654642 is a reply to message #654566] Wed, 16 February 2011 09:50 Go to previous messageGo to next message
I have tried to create two ClassFinder projects - one for standalone application and the other for the eclipse plug-in project. I am using
Bundle bundle = FrameworkUtil.getBundle(containedClass);
try {
URL url = bundle.getEntry(packageName.replace('.', '/'));
uri = FileLocator.toFileURL(url).toURI();
and it still does not work.
I have to add the "bin/" prefix myself.
URL url = bundle.getEntry("bin/" + packageName.replace('.', '/'));
It is a bug or did I misunderstand the usage of the getEntry method?
Re: Missing bin suffix at getCodeSource().getLocation() [message #654715 is a reply to message #654642] Wed, 16 February 2011 14:20 Go to previous messageGo to next message
getEntry is about finding bundle resources that will be available in
your plugin (i.e. you have a <project>/icons directory to be included in
your plugin).
It apparently doesn't work against source or java resources.
PW
Paul Webster
Re: Missing bin suffix at getCodeSource().getLocation() [message #654716 is a reply to message #654566] Wed, 16 February 2011 14:28 Go to previous messageGo to next message
It's this search that you can't do reliably.
In java (in general) there's no reliable way to get a list of all of the
classes supplied in 1) the classpath or 2) even for a specific package.
Changes to the environment (from a java app to an applet to a
container environment) change how classes are looked up.
In just java, if the problem is you need a set of classes to "publish"
themselves to your STI jar so they can be used for transforms, you can
have the ATransformation jar include some kind of txt file, a properties
file that STI can be handed, so it can load the classes. You could also
use Service Provider Interface between STI and ATransformations. That's
allows ATransformations to publish classes in both java and would work
within eclipse.
PW
Paul Webster
Re: Missing bin suffix at getCodeSource().getLocation() [message #654790 is a reply to message #654716] Thu, 17 February 2011 02:54 Go to previous message
Thank you for your help. I will use a special class loader for developing purposes and replace it, by a class list file, when it's ready.
Previous Topic:LTK: No default action starting Apply Script wizard?
Next Topic:Accessing PUTTY from Eclipse 3.3
Current Time: Wed Jul 23 04:16:49 EDT 2025
Powered by FUDForum. Page generated in 0.07917 seconds
