Home » Eclipse Projects » GEF » Change the Figure after it is first created
Change the Figure after it is first created [message #65458] Tue, 18 February 2003 15:45 Go to next message
GEF uses MVC pattern, so every model has 1 figure. But can I change that
figure after it is first created thru a command? For example, I have a model
which represents as a Square (a figure), can I have a command in the menu to
switch that to a Circle? I notice the createFigure() only called once per
EditPart.
My question is if it is possible to swap that figure after it is initially
created.
Thank you.
Re: Change the Figure after it is first created [message #65483 is a reply to message #65458] Tue, 18 February 2003 15:54 Go to previous messageGo to next message
There are workarounds, please open a feature request for this.
you might try overriding:
protected void setFigure(IFigure newFigure) {
if (figure != null) {
unregisterVisuals();
IFigure parent = figure.getParent();
int index = parent.indexOf(figure);
Object constraint = parent.getLayoutManager().getConstraint(figure);
figure = newFigure;
parent.add(figure, constraint, index);
registerVisuals();
} else
super.setFigure(newFigure);
"yinglcs" <yinglcs@netscape.com> wrote in message
news:b2u4ej$eb1$1@rogue.oti.com...
model
to
> EditPart.
> created.
> Thank you.
Re: Change the Figure after it is first created [message #65628 is a reply to message #65483] Wed, 19 February 2003 10:31 Go to previous messageGo to next message
In the latest drop of GEF neither IFigure nor Figure has an indexOf method.
John-Mason Shackelford
Software Developer
Pearson Educational Measurement - eMeasurement Group
2510 North Dodge St.
Iowa City, IA 52245
ph. 319-354-9200x6214
john-mason.shackelford@pearson.com
http://etest.ncspearson.com
Re: Change the Figure after it is first created [message #65649 is a reply to message #65628] Wed, 19 February 2003 10:31 Go to previous messageGo to next message
"John-Mason P. Shackelford" <john-mason.shackelford@pearson.com> wrote in
message news:3E53A335.9070309@pearson.com...
method.
try parent.getChildren().indexOf(child)
> Software Developer
> Iowa City, IA 52245
Re: Change the Figure after it is first created [message #65691 is a reply to message #65649] Wed, 19 February 2003 11:13 Go to previous messageGo to next message
Randy,
What do you think about adding something like this to the API for Figure
and EditPart? Certaily could be handled by subclasses, but perhaps handy
enough to consider making more readily available. What do you think?
public int getChildCount(Class c) {
int i = 0;
Iterator iter = children.iterator();
while (iter.hasNext()) {
if (c.isAssignableFrom(iter.next().getClass())) {
i++;
return i;
Software Developer
Iowa City, IA 52245
Re: Change the Figure after it is first created [message #65713 is a reply to message #65691] Wed, 19 February 2003 11:25 Go to previous message
What would this be used for?
message news:3E53AD2E.80208@pearson.com...
> Randy,
> int i = 0;
> i++;
> return i;
> Software Developer
> Iowa City, IA 52245
Previous Topic:confused about ConstrainedLayoutPolicy.createAddCommand()
Next Topic:Getting the right location after scrolling
Current Time: Mon Oct 20 13:47:21 EDT 2025
Powered by FUDForum. Page generated in 0.04622 seconds
