Home » Modeling » M2T (model-to-text transformation) » workflow runner going out of space (using xpand to generate code for gmf instance )
workflow runner going out of space [message #654347] Tue, 15 February 2011 05:34 Go to next message
i am currently working on gmf .i am trying to invoke workflow.runner from my gmf context menu.
when i invoke workflow it's going out of memory. so i tried to debug it i found the following error.
execute workflow fails in the workflow runner.i found out that it was because of configuration errors in my workflow file
prepare(workFlowFile, theMonitor, theParams);
can you point out from my workflow file?
all my parameters seem to be fine but i m not sure where something has gone wrong.
xpand workflow works fine normally. when i try to invoke from gmf plugin its going out of memory
follwing is the error dump
Error while logging event loop exception:
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1197)
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:272)
at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
at org.eclipse.m2t.type.emf.EmfRegistryMetaModel.allPackages(Em fRegistryMetaModel.java:210)
at org.eclipse.m2t.type.emf.EmfRegistryMetaModel$2.createNew(Em fRegistryMetaModel.java:182)
at org.openarchitectureware.workflow.util.Cache.get(Cache.java: 25)
at org.eclipse.m2t.type.emf.EmfRegistryMetaModel.getTypeForName (EmfRegistryMetaModel.java:238)
at org.openarchitectureware.expression.TypeSystemImpl.internalG etTypeForName(TypeSystemImpl.java:185)
at org.openarchitectureware.expression.TypeSystemImpl.getTypeFo rName(TypeSystemImpl.java:235)
at org.openarchitectureware.expression.TypeSystemImpl.getTypeFo rName(TypeSystemImpl.java:212)
at org.eclipse.m2t.type.emf.EmfRegistryMetaModel.getTypeForETyp edElement(EmfRegistryMetaModel.java:356)
at org.eclipse.m2t.type.emf.EClassType.getContributedFeatures(E ClassType.java:65)
at org.openarchitectureware.type.AbstractTypeImpl.getAllFeature s(AbstractTypeImpl.java:62)
at org.openarchitectureware.type.AbstractTypeImpl$1.createNew(A bstractTypeImpl.java:84)
at org.openarchitectureware.type.AbstractTypeImpl$1.createNew(A bstractTypeImpl.java:1)
Logging exception:
<?xml version="1.0"?>
<workflow>
<property name="model" value="C:\\Documents and Settings\\rtiragat\\runtime-EclipseApplication\\Automation\\ default.mist " />
<!--<property name="model" value="Automation/default.mist_diagram" />-->
<property name="src-gen" value="src-gen" />
<!-- set up EMF for standalone execution -->
<bean class="org.eclipse.mwe.emf.StandaloneSetup" >
<platformUri value=".."/>
<registerGeneratedEPackage value="mist.MistPackage"/>
<!-- Load GMF Notation package Don't load from model as it gives errors -->
<registerGeneratedEPackage value="org.eclipse.gmf.runtime.notation.NotationPackage"/>
</bean>
<!-- instantiate metamodel -->
<bean id="mm_emf" class="org.eclipse.m2t.type.emf.EmfRegistryMetaModel"/>
<!-- load model and store it in slot 'model' -->
<!--<component class="org.eclipse.mwe.emf.Reader">-->
<component class="org.openarchitectureware.emf.XmiReader">
<modelFile value="${model}"/>
<outputSlot value="model"/>
<firstElementOnly value="true"/>
<!--<model value="${model}"/>-->
<!-- <uri value="platform:/resource/${model}" />-->
<!--<modelSlot value="model" />-->
</component>
<!-- check model -->
<component class="oaw.check.CheckComponent">
<metaModel idRef="mm_emf"/>
<checkFile value="metamodel::Checks" />
<emfAllChildrenSlot value="model" />
</component>
<!-- generate code -->
<component class="org.openarchitectureware.xpand2.Generator">
<expand
value="template::Template::main FOR model" />
<outlet path="${src-gen}" >
<postprocessor class="org.openarchitectureware.xpand2.output.JavaBeautifier " />
</outlet>
</component>
</workflow>
workflow invoking
WorkflowRunner runner = new WorkflowRunner();
Bundle bundle=Platform.getBundle("com.genesyslabs.sipserver.mist.generator ");
URL wfUrl = bundle.getEntry("src/workflow/generator.oaw");
String wfFile = "";
try {
wfFile = FileLocator.toFileURL(wfUrl).getFile();
mb.setMessage(wfFile);
mb.open();
Map<String, String> properties = new HashMap<String, String>();
Map<String,?> slotMap = new HashMap<String,Object>();
//mb.setMessage(PlatformUI.getWorkbench().getActiveWorkbench Window().getActivePage().getActiveEditor().getTitle());
path=getDiagramFile(event);
properties.put("model","C:\\Documents and Settings\\rtiragat\\runtime-EclipseApplication\\Automation\\ default.mist ");
//mb.setMessage(path+"---diagram file path---");
//mb.open();
if(path!=null)
if(runner.prepare(wfFile,new org.openarchitectureware.workflow.monitor.NullProgressMonito r(),properties))
//isSuccess=runner.run(wfFile,new org.openarchitectureware.workflow.monitor.NullProgressMonito r(), properties, null);
//isSuccess=runner.run("C:\\Documents and Settings\\rtiragat\\workspace\\com.genesyslabs.sipserver.mis t.generator\\src\\workflow\\generator.oaw ",new org.openarchitectureware.workflow.monitor.NullProgressMonito r(), properties, null);
isSuccess=runner.run("C:/Documents and Settings/rtiragat/workspace/com.genesyslabs.sipserver.mist.g enerator/src/workflow/generator.oaw ",new org.openarchitectureware.workflow.monitor.NullProgressMonito r(), properties,slotMap);
if(isSuccess)
mb.setMessage("code generation succesfull !!!!");
else
mb.setMessage("code generation unsuccesfull !!!!");
mb.open();
catch (Exception e)
e.printStackTrace();
Re: workflow runner going out of space [message #654444 is a reply to message #654347] Tue, 15 February 2011 14:47 Go to previous messageGo to next message
hi,
why do you call StandaloneSetup in a workflow what runs within eclipse - does it work when you remove it?
~Christian
Re: workflow runner going out of space [message #654507 is a reply to message #654444] Wed, 16 February 2011 00:39 Go to previous messageGo to next message
Hi chris
thanks for replying.
i am not completely clear on this. can you point out where i require to make change.
if i remove standalonesetup bean. what should i replace it with?
Ravi
Re: workflow runner going out of space [message #654518 is a reply to message #654507] Wed, 16 February 2011 02:53 Go to previous messageGo to next message
i said does it work when you remove it? so just send it to /dev/null
~Christian
Re: workflow runner going out of space [message #654539 is a reply to message #654518] Wed, 16 February 2011 04:14 Go to previous messageGo to next message
hi chris
sorry for troubling you again
i hardly have any knowledge about creating a workflow.
i don't know how i should send it to /dev/null
i was thinking like if that bean class should be changed to something else
like some other class and not stanalonesetup class
so can you can make changes in my workflow and give it in the reply ?
Thanks for your patience.
Re: workflow runner going out of space [message #654545 is a reply to message #654539] Wed, 16 February 2011 04:25 Go to previous messageGo to next message
is it so hard to simply delete / remove / eraze / kill /....
</bean>
from you worjkflow?
~Christian
Re: workflow runner going out of space [message #654583 is a reply to message #654545] Wed, 16 February 2011 07:03 Go to previous messageGo to next message
hi chris
thanks for reply
i have deleted and tried that before but it gives me error
but i have one doubt if we remove that how does the workflow know where to take emf model (ecore file)?
here is error
it works fine if i include those lines back again.
the problem is invoking from gmf context menu
9952 ERROR WorkflowRunner - org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://mist.ecore' not found. (file:/C:/Documents%20and%20Settings/rtiragat/runtime-Eclips eApplication/Automation/default.mist, 2, 186)
org.openarchitectureware.workflow.ConfigurationException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://mist.ecore' not found. (file:/C:/Documents%20and%20Settings/rtiragat/runtime-Eclips eApplication/Automation/default.mist, 2, 186)
at org.openarchitectureware.emf.XmiReader.invoke(XmiReader.java :139)
at org.openarchitectureware.workflow.container.CompositeCompone nt.internalInvoke(CompositeComponent.java:129)
at org.openarchitectureware.workflow.container.CompositeCompone nt.invoke(CompositeComponent.java:112)
at org.openarchitectureware.workflow.WorkflowRunner.executeWork flow(WorkflowRunner.java:380)
at org.openarchitectureware.workflow.WorkflowRunner.run(Workflo wRunner.java:261)
at org.openarchitectureware.workflow.WorkflowRunner.main(Workfl owRunner.java:213)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://mist.ecore' not found. (file:/C:/Documents%20and%20Settings/rtiragat/runtime-Eclips eApplication/Automation/default.mist, 2, 186)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:191)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.openarchitectureware.emf.XmiReader.invoke(XmiReader.java :136)
... 5 more
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://mist.ecore' not found. (file:/C:/Documents%20and%20Settings/rtiragat/runtime-Eclips eApplication/Automation/default.mist, 2, 186)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2591)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2422)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
... 9 more
Re: workflow runner going out of space [message #654590 is a reply to message #654583] Wed, 16 February 2011 07:10 Go to previous messageGo to next message
first - the workflow may look different if you run it by rightclick/standalone (then it may contain the standalonesetup) or at runtime / from gmf - then ist should wirk without.
did you check if the 'http://mist.ecore' package is registered to your runtime?
can you share a complete runnable example?
~Christian
[Updated on: Wed, 16 February 2011 07:14] by Moderator
Re: workflow runner going out of space [message #655062 is a reply to message #654590] Fri, 18 February 2011 03:45 Go to previous messageGo to next message
Hi chris
it's working fine now. i am launching as a product it works fine but if i launch as application it not working
i still didn't understand why it's not working their
Ravi
Re: workflow runner going out of space [message #657898 is a reply to message #655062] Fri, 04 March 2011 09:43 Go to previous message
Hi chris
i found out the error Very Happy
i didn't include the src folder in the binary build of the required plug in so i was not able to get the location
Ravi
Previous Topic:How to invoke a JET transform
Next Topic:acceleo - cast of variables
Current Time: Sat Jul 19 01:00:52 EDT 2025
Powered by FUDForum. Page generated in 0.04847 seconds
