Sorting bar chart based on y-axis values [message #654277] |
Mon, 14 February 2011 15:51  |
Originally posted by: remkus.wideopenwest.com
My application constrains me to using BIRT 2.2.1.
I have multiple bar charts using the same data set. Each bar chart
graphs a separate column of data.
I'd like to have the bars sorted so that the largest value appears at
either the left or right. It seems with this version of BIRT, I can
only sort the x-axis.
Is there some way to sort the data? maybe from the chart object? via a
script
Re: Sorting bar chart based on y-axis values [message #654282 is a reply to message #654281] |
Mon, 14 February 2011 16:29   |
Jason,
Actually, I don't ...
I'll have multiple bar charts each sorted on the y-axis values. I'm
trying to avoid creating a separate dataset for each bar chart and
hitting the database each time.
The bar charts will actually be implemented in a table group header and
I'll be passing in one of the table values as a parameter to the dataset.
Any way to avoid creating multiple data sets?
On 02/14/11 16:15, Jason Weathersby wrote:
> Dave,
> Do you have the option of adding a hidden table element, sorting it the
> way you want, and then bind the chart to the table instead of the
> dataset. See attached.
> Jason
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version
> 2.2.1.r22a_v20071101 Build <2.2.1.v20071101-1439></property>
> <property name="units">in</property>
> <property name="comments">Copyright (c) 2007 <<Your Company
> Name here>></property>
> <html-property name="description">Creates a blank report with no
> predefined content.</html-property>
> <text-property name="displayName">Blank Report</text-property>
> <property name="iconFile">/templates/blank_report.gif</property>
> <data-sources>
> <oda-data-source
> extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
> id="6">
> <text-property name="displayName"></text-property>
> <property
> name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
> <property name="odaURL">jdbc:classicmodels:sampledb</property>
> <property name="odaUser">ClassicModels</property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
> name="Data Set" id="7">
> <list-property name="columnHints">
> <structure>
> <property name="columnName">ORDERNUMBER</property>
> <property name="displayName">ORDERNUMBER</property>
> </structure>
> <structure>
> <property name="columnName">PRODUCTCODE</property>
> <property name="displayName">PRODUCTCODE</property>
> </structure>
> <structure>
> <property name="columnName">QUANTITYORDERED</property>
> <property name="displayName">QUANTITYORDERED</property>
> </structure>
> <structure>
> <property name="columnName">PRICEEACH</property>
> <property name="displayName">PRICEEACH</property>
> </structure>
> <structure>
> <property name="columnName">ORDERLINENUMBER</property>
> <property name="displayName">ORDERLINENUMBER</property>
> </structure>
> </list-property>
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> <property name="position">1</property>
> <property name="name">ORDERNUMBER</property>
> <property name="dataType">integer</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">PRODUCTCODE</property>
> <property name="dataType">string</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">QUANTITYORDERED</property>
> </structure>
> <structure>
> <property name="position">4</property>
> <property name="name">PRICEEACH</property>
> <property name="dataType">float</property>
> </structure>
> <structure>
> <property name="position">5</property>
> <property name="name">ORDERLINENUMBER</property>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">Data Source</property>
> <structure>
> <property name="nativeName">ORDERNUMBER</property>
> <property name="nativeDataType">4</property>
> </structure>
> <structure>
> <property name="nativeName">PRODUCTCODE</property>
> <property name="nativeDataType">12</property>
> </structure>
> <structure>
> <property name="nativeName">QUANTITYORDERED</property>
> </structure>
> <structure>
> <property name="nativeName">PRICEEACH</property>
> <property name="nativeDataType">8</property>
> </structure>
> <structure>
> <property name="nativeName">ORDERLINENUMBER</property>
> <property name="nativeDataType">5</property>
> </structure>
> </list-property>
> <property name="queryText">select *
> from orderdetails
> where ordernumber = 10101</property>
> <xml-property name="designerValues"><![CDATA[<?xml
> version="1.0" encoding="UTF-8"?>
> <model:DesignValues
> xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
> xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
> <Version>1.0</Version>
> <design:ResultSets derivedMetaData="true">
> <design:resultSetDefinitions>
> <design:resultSetColumns>
> <design:resultColumnDefinitions>
> <design:attributes>
> <design:name>ORDERNUMBER</design:name>
> <design:position>1</design:position>
> <design:nativeDataTypeCode>4</design:nativeDataTypeCode>
> <design:precision>10</design:precision>
> <design:scale>0</design:scale>
> <design:nullability>Nullable</design:nullability>
> <design:uiHints>
> <design:displayName>ORDERNUMBER</design:displayName>
> </design:uiHints>
> </design:attributes>
> <design:usageHints>
> <design:label>ORDERNUMBER</design:label>
> <design:formattingHints>
> <design:displaySize>11</design:displaySize>
> </design:formattingHints>
> </design:usageHints>
> </design:resultColumnDefinitions>
> <design:attributes>
> <design:name>PRODUCTCODE</design:name>
> <design:position>2</design:position>
> <design:nativeDataTypeCode>12</design:nativeDataTypeCode>
> <design:precision>15</design:precision>
> <design:uiHints>
> <design:displayName>PRODUCTCODE</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>PRODUCTCODE</design:label>
> <design:displaySize>15</design:displaySize>
> <design:attributes>
> <design:name>QUANTITYORDERED</design:name>
> <design:position>3</design:position>
> <design:uiHints>
> <design:displayName>QUANTITYORDERED</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>QUANTITYORDERED</design:label>
> <design:attributes>
> <design:name>PRICEEACH</design:name>
> <design:position>4</design:position>
> <design:nativeDataTypeCode>8</design:nativeDataTypeCode>
> <design:uiHints>
> <design:displayName>PRICEEACH</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>PRICEEACH</design:label>
> <design:displaySize>22</design:displaySize>
> <design:attributes>
> <design:name>ORDERLINENUMBER</design:name>
> <design:position>5</design:position>
> <design:nativeDataTypeCode>5</design:nativeDataTypeCode>
> <design:precision>5</design:precision>
> <design:uiHints>
> <design:displayName>ORDERLINENUMBER</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>ORDERLINENUMBER</design:label>
> <design:displaySize>6</design:displaySize>
> </design:resultSetColumns>
> </design:resultSetDefinitions>
> </design:ResultSets>
> </model:DesignValues>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> <style name="crosstab-cell" id="4">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab" id="5">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <table name="tst" id="9">
> <property name="width">100%</property>
> <property name="dataSet">Data Set</property>
> <list-property name="visibility">
> <structure>
> <property name="format">all</property>
> <expression name="valueExpr">true</expression>
> </structure>
> </list-property>
> <list-property name="boundDataColumns">
> <structure>
> <expression
> name="expression">dataSetRow["ORDERNUMBER"]</expression >
> </structure>
> <structure>
> <expression
> name="expression">dataSetRow["PRODUCTCODE"]</expression >
> </structure>
> <structure>
> <expression
> name="expression">dataSetRow["QUANTITYORDERED"]</expression >
> </structure>
> <structure>
> <expression
> name="expression">dataSetRow["PRICEEACH"]</expression>
> </structure>
> <structure>
> <expression
> name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
> </structure>
> </list-property>
> <list-property name="sort">
> <structure>
> <expression
> name="key">row["QUANTITYORDERED"]</expression>
> <property name="direction">desc</property>
> </structure>
> </list-property>
> <column id="38"/>
> <column id="39"/>
> <column id="40"/>
> <column id="41"/>
> <column id="42"/>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> <text-property
> name="text">ORDERNUMBER</text-property>
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> <text-property
> name="text">PRODUCTCODE</text-property>
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> <text-property
> name="text">QUANTITYORDERED</text-property>
> </label>
> </cell>
> <cell id="17">
> <label id="18">
> <text-property
> name="text">PRICEEACH</text-property>
> </label>
> </cell>
> <cell id="19">
> <label id="20">
> <text-property
> name="text">ORDERLINENUMBER</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="21">
> <cell id="22">
> <data id="23">
> <property
> name="resultSetColumn">ORDERNUMBER</property>
> </data>
> </cell>
> <cell id="24">
> <data id="25">
> <property
> name="resultSetColumn">PRODUCTCODE</property>
> </data>
> </cell>
> <cell id="26">
> <data id="27">
> <property
> name="resultSetColumn">QUANTITYORDERED</property>
> </data>
> </cell>
> <cell id="28">
> <data id="29">
> <property
> name="resultSetColumn">PRICEEACH</property>
> </data>
> </cell>
> <cell id="30">
> <data id="31">
> <property
> name="resultSetColumn">ORDERLINENUMBER</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="32">
> <cell id="33"/>
> <cell id="34"/>
> <cell id="35"/>
> <cell id="36"/>
> <cell id="37"/>
> </row>
> </footer>
> </table>
> <extended-item extensionName="Chart" name="NewChart" id="8">
> <xml-property
> name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
> xmlns:data="http://www.birt.eclipse.org/ChartModelData"
> xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
> xmlns:model="http://www.birt.eclipse.org/ChartModel"
> xmlns:type="http://www.birt.eclipse.org/ChartModelType">
> <Type>Bar Chart</Type>
> <SubType>Side-by-side</SubType>
> <Block>
> <Children xsi:type="layout:TitleBlock">
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> <Height>0.0</Height>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Bottom>3.0</Bottom>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Rowspan>-1</Rowspan>
> <Columnspan>-1</Columnspan>
> <Outline>
> <Style>Solid</Style>
> <Thickness>1</Thickness>
> <Color>
> <Transparency>255</Transparency>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> <Visible>false</Visible>
> </Outline>
> <Visible>true</Visible>
> <Label>
> <Caption>
> <Value>Bar Chart Title</Value>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> <horizontalAlignment>Center</horizontalAlignment>
> <verticalAlignment>Center</verticalAlignment>
> </Alignment>
> </Font>
> </Caption>
> <Background xsi:type="attribute:ColorDefinition">
> <Transparency>0</Transparency>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Bottom>0.0</Bottom>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Children xsi:type="layout:Plot">
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <HorizontalSpacing>5</HorizontalSpacing>
> <VerticalSpacing>5</VerticalSpacing>
> <ClientArea>
> <Outline>
> <Thickness>0</Thickness>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Children xsi:type="layout:Legend">
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Bottom>2.0</Bottom>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Orientation>Vertical</Orientation>
> <Direction>Top_Bottom</Direction>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Position>Right</Position>
> <ItemType>Categories</ItemType>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <TitlePosition>Above</TitlePosition>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>434.25</Width>
> <Height>244.5</Height>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> </Block>
> <Dimension>Two_Dimensional</Dimension>
> <Units>Points</Units>
> <SeriesThickness>10.0</SeriesThickness>
> <SampleData>
> <BaseSampleData>
> <DataSetRepresentation>A, B, C</DataSetRepresentation>
> </BaseSampleData>
> <OrthogonalSampleData>
> <DataSetRepresentation>5,4,12</DataSetRepresentation>
> <SeriesDefinitionIndex>0</SeriesDefinitionIndex>
> </OrthogonalSampleData>
> </SampleData>
> <Interactivity/>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Value>X-Axis Title</Value>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <TitlePosition>Below</TitlePosition>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Value>Y-Axis Title</Value>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> <Rotation>90.0</Rotation>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <TitlePosition>Left</TitlePosition>
> <SeriesDefinitions>
> <Query>
> <Definition></Definition>
> </Query>
> <SeriesPalette>
> <Entries xsi:type="attribute:ColorDefinition">
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>0</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>128</Red>
> <Green>64</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>80</Red>
> <Green>240</Green>
> <Blue>120</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>0</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> </SeriesPalette>
> <Series xsi:type="type:BarSeries">
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> <Definition>row["QUANTITYORDERED"]</Definition >
> </DataDefinition>
> <SeriesIdentifier></SeriesIdentifier>
> <DataPoint>
> <Components>
> <Type>Orthogonal_Value</Type>
> </Components>
> <Separator>, </Separator>
> </DataPoint>
> <LabelPosition>Outside</LabelPosition>
> <Stacked>false</Stacked>
> <Riser>Rectangle</Riser>
> </Series>
> <Grouping>
> <Enabled>false</Enabled>
> <GroupingInterval>2</GroupingInterval>
> <GroupType>Text</GroupType>
> <AggregateExpression>Sum</AggregateExpression>
> </Grouping>
> <Sorting>Ascending</Sorting>
> </SeriesDefinitions>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <LabelPosition>Left</LabelPosition>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickStyle>Across</TickStyle>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225<
Re: Sorting bar chart based on y-axis values [message #654438 is a reply to message #654284] |
Tue, 15 February 2011 14:04   |
Dave,
If you were using the latest version of BIRT this is very simple
solution, but in 2.2.1 it is difficult. You can get the datasets used
in the before generation and resort them like:
importPackage(Packages.java.util);
var cat = new ArrayList();
var val = new ArrayList();
function beforeGeneration( chart, icsc )
var xAxis = chart.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var xSerieDef = xAxis.getSeriesDefinitions().get(0);
var ySerieDef = yAxis.getSeriesDefinitions().get(0);
var xSeriesRuntime = xSerieDef.getRunTimeSeries().get(0);
var ySeriesRuntime = ySerieDef.getRunTimeSeries().get(0);
var dscat = xSeriesRuntime.getDataSet().getValues();
var dsval = ySeriesRuntime.getDataSet().getValues();
var myvals = new ArrayList(Arrays.asList(dsval));
var mycats = new ArrayList(Arrays.asList(dscat));
while( myvals.size() > 0 ){
var maxi = -1;
var maxval =-1000000;
for( i=0; i<myvals.size(); i++){
if( myvals.get(i) > maxval ){
maxi = i;
maxval = myvals.get(i);
val.add(myvals.remove(maxi));
cat.add(mycats.remove(maxi));
ySeriesRuntime.getDataSet().setValues(val);
xSeriesRuntime.getDataSet().setValues(cat);
See attached full report.
Jason
id="1">
<data-sources>
<oda-data-source
id="6">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</page-setup>
<body>
<xml-property
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Height>243.75</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Script>importPackage(Packages.java.util);
var maxi = -1;
maxi = i;
}</Script>
<SampleData>
<BaseSampleData>
</BaseSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blu
Re: Sorting bar chart based on y-axis values [message #654475 is a reply to message #654438] |
Tue, 15 February 2011 16:20   |
Jason,
Yes ... a little daunting, but it works perfectly.
Thanks a bunch!
On 02/15/11 14:04, Jason Weathersby wrote:
> Dave,
> var maxi = -1;
> maxi = i;
> Jason
> id="1">
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <xml-property
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> </Block>
> var maxi = -1;
> maxi = i;
> }</Script>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity/>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>0</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>128</Red>
> <Green>64</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>80</Red>
> <Green>240</Green>
> <Blue>120</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>0</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> </SeriesPalette>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </TickAttributes>
> </MinorGrid>
> <Scale>
> </Scale>
> <Origin>
> <Type>Min</Type>
> <Value>0.0</Value>
> </Value>
> </Origin>
> </AssociatedAxes>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
Re: Sorting bar chart based on y-axis values [message #654476 is a reply to message #654475] |
Tue, 15 February 2011 16:44   |
Yes I know. In 2.6 this can all be done in the gui.
On 2/15/2011 4:20 PM, Dave Remkus wrote:
> Jason,
> Thanks a bunch!
>> Dave,
>> while( myvals.size()> 0 ){
>> var maxi = -1;
>> if( myvals.get(i)> maxval ){
>> maxi = i;
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> 2.2.1.r22a_v20071101 Build<2.2.1.v20071101-1439></property>
>> <property name="comments">Copyright (c) 2007<<Your Company
>> <data-sources>
>> <oda-data-source
>> id="6">
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> from orderdetails
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <xml-property
>> <Block>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Label>
>> <Caption>
>> <Font>
>> <Size>16.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>0.0</Left>
>> <Right>0.0</Right>
>> </Insets>
>> </ClientArea>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>2.0</Top>
>> <Left>2.0</Left>
>> <Right>2.0</Right>
>> </Insets>
>> </ClientArea>
>> <Text>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Text>
>> <Separator>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Separator>
>> <Title>
>> <Caption>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> </Block>
>> var maxi = -1;
>> maxi = i;
>> }</Script>
>> <SampleData>
>> <BaseSampleData>
>> </BaseSampleData>
>> </SampleData>
>> <Interactivity/>
>> <Axes>
>> <Type>Text</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <AssociatedAxes>
>> <Type>Linear</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <SeriesDefinitions>
>> <Query>
>> </Query>
>> <SeriesPalette>
>> <Red>80</Red>
>> <Green>166</Green>
>> <Blue>218</Blue>
>> </Entries>
>> <Red>242</Red>
>> <Green>88</Green>
>> <Blue>106</Blue>
>> </Entries>
>> <Red>232</Red>
>> <Green>172</Green>
>> <Blue>57</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>64</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>170</Red>
>> <Green>85</Green>
>> <Blue>85</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>192</Red>
>> <Green>192</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>192</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>7</Red>
>> <Green>146</Green>
>> <Blue>94</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>64</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>80</Red>
>> <Green>240</Green>
>> <Blue>120</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>0</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> </SeriesPalette>
>> <Label>
>> <Caption>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <DataDefinition>
>> </DataDefinition>
>> <DataPoint>
>> <Components>
>> </Components>
>> <Separator>,</Separator>
>> </DataPoint>
>> </Series>
>> <Grouping>
>> </Grouping>
>> <LineAttributes>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </LineAttributes>
>> <Label>
>> <Caption>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <MajorGrid>
>> <LineAttributes>
>> <Color>
>> <Red>196</Red>
>> <Green>196</Green>
>> <Blue>196</Blue>
>> </Color>
>> </LineAttributes>
>> <TickAttributes>
>> <Color>
>> <Red>196</Red>
>> <Green>196</Green>
>> <Blue>196</Blue>
>> </Color>
>> </TickAttributes>
>> </MajorGrid>
>> <MinorGrid>
>> <LineAttributes>
>> <Color>
>> <Red>225</Red>
>> <Green>225</Green>
>> <Blue>225</Blue>
>> </Color>
>> </LineAttributes>
>> <TickAttributes>
>> <Color>
>> <Transparency>255
FUDForum. Page generated in 0.27256 seconds
