Home » Eclipse Projects » Rich Client Platform (RCP) » Helios: Unhandled event loop exception
Helios: Unhandled event loop exception [message #654433] Tue, 15 February 2011 13:19 Go to next message
I started to have this error that i cannot trace back to my app (i use "org.eclipse.nebula.widgets" NumberFormatter, that woked pretty well in previous versions of Eclipse).
This error does not seem affect anything crucial...
Thanks.
!ENTRY org.eclipse.ui 4 0 2011-02-15 18:14:42.716
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(Unknown Source)
at org.eclipse.jface.internal.databinding.swt.SWTVetoableValueD ecorator$1.handleEvent(SWTVetoableValueDecorator.java:38)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Text.verifyText(Text.java:2066)
at org.eclipse.swt.widgets.Text.sendKeyEvent(Text.java:1517)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1099 )
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1508)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4268)
at org.eclipse.swt.widgets.Text.WM_CHAR(Text.java:2175)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4160 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2170)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 59)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3655)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at rcpcolibri.ui.workbench.actions.OpenPreferencePageAction.run (OpenPreferencePageAction.java:90)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at rcpcolibri.Application.start(Application.java:56)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: Helios: Unhandled event loop exception [message #655418 is a reply to message #654433] Sun, 20 February 2011 12:32 Go to previous messageGo to next message
Hi Marco,
Something wrong in the preference page that is opened by the rcpcolibri
action?
Wim
> Thanks.
> !STACK 0
(Realm.java:332)
bench.java:664)
tarter.java:369)
tarter.java:179)
Re: Helios: Unhandled event loop exception [message #665648 is a reply to message #654433] Fri, 15 April 2011 07:12 Go to previous messageGo to next message
Hello!
I am having the same problem.
I use the Nebula NumberFormatter with databinding and get the same exception when:
- Select all text in the textbox and press DEL or entering a small number
- Go to the end of the string and press BACKSPACE
However, all data is consistent and the exception does not affect the logic of my code.
Though, it is not very nice Wink
I found a documented bug at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318782
that describes the same errornous behavior. They say that it is fixed, but i don't really think so?
My Eclipse Version:
Version: Helios Service Release 2
Build id: 20110301-1815
The Exception:
!ENTRY org.eclipse.ui 4 0 2011-04-15 13:06:38.542
!STACK 0
at de.cinovo.tcc.rcp.core.TCC.start(TCC.java:28)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Re: Helios: Unhandled event loop exception [message #665745 is a reply to message #665648] Fri, 15 April 2011 13:25 Go to previous message
Yves Schubert wrote on Fri, 15 April 2011 07:12
Hello!
My Eclipse Version:
Exactly my problem.
Still not fixed on the latest Eclipse release: Indigo M6a (Build id: 20110319-2305)
Using Windows XP SP3. I will test also in Ubuntu and OS X.
[Updated on: Fri, 15 April 2011 13:26] by Moderator
Previous Topic:Can I open an Internet Explorer window from RCP app?
Next Topic:ViewPart closing - causing content provider to be disposed
Current Time: Sat Jul 26 10:10:22 EDT 2025
Powered by FUDForum. Page generated in 0.05002 seconds
