Home » Modeling » EMF » [EMF-URI] Copy folder's contents through URIs
[EMF-URI] Copy folder's contents through URIs [message #654337] Tue, 15 February 2011 04:20 Go to next message
Here is my problem : I have a model, provided by a plug-in through an extension point. I'd like to be able to make changes to this model at runtime, so I tried to copy it. The problem is that this model may have many dependencies, and I'd like to copy these dependencies as well.
There are two kinds of dependencies : Absolute URIs, which I don't wish to copy, and Relative URIs, which I'm interested in.
The problem is that I can't list the folder's contents, as it cannot be converted to a java.io.File (It is a platform:/plugin/... URI, which isn't a file)
Is there a way to do this copy ? I considered loading the whole ResourceSet (To load all dependencies), then filter the resources I'm interested in, but it seems very expensive, compared to a simple folder copy. Moreover, I don't know how to load the whole ResourceSet.
Any pointer would be really appreciated Smile
Thank you,
Camille Letavernier
Re: [EMF-URI] Copy folder's contents through URIs [message #654346 is a reply to message #654337] Tue, 15 February 2011 05:20 Go to previous messageGo to next message
Camille,
Comments below.
Camille Letavernier wrote:
> Hello,
> which isn't a file)
You could use FileLocator.toFileURI; be warned it will unpack jars to
create a copy.
EcoreUtil.resolveAll can help with that.
I wonder though how much performance is really a concern in the end...
EcoreUtil.resolveAll will help.
> Any pointer would be really appreciated :)
> Thank you,
> Camille Letavernier
Re: [EMF-URI] Copy folder's contents through URIs [message #654395 is a reply to message #654337] Tue, 15 February 2011 10:04 Go to previous message
Thank you for your answers !
Well, it's an interactive operation, so the faster, the better Smile But as long as there is a progress bar, it is not a real problem.
I will try both solutions, and see which one is best in my case. Thanks again.
Camille Letavernier
Previous Topic:Re: CDO Repository Server Reconnect Failure
Next Topic:Resolved proxy
Current Time: Fri Jul 25 22:23:25 EDT 2025
Powered by FUDForum. Page generated in 0.25228 seconds
