Home » Eclipse Projects » Eclipse Platform » Eclipse fails to activate UI plugin
Eclipse fails to activate UI plugin [message #654008] Sat, 12 February 2011 16:37 Go to next message
I am having a problem described below related to using UI plugin, on HP-UX. If someone seen this before or have any idea about fixing it, please let me know the solution.
Thanks!
Vijay
Problem:
When trying to launch an eclipse application that has a UI-based plugin using the Equinox launcher on a HP-UX platform, I get a ClassNotFound exception on the SWTError class. The detailed stack trace could be found below.
I verified that all the required plugins are properly placed because the same setup works fine on Windows platforms (tested with the corresponding eclipse binaries for Windows).
Platform:
HP-UX IA64
Eclipse binaries version: 3.5
Eclipse Equinox Jar:
org.eclipse.equinox.launcher_1.0.200.v20090520.jar
Eclipse SWT:
org.eclipse.swt.motif.hpux.ia64_32.source_3.5.0.v3550b.jar
org.eclipse.swt.motif.hpux.ia64_32_3.5.0.v3550b.jar
org.eclipse.swt_3.5.0.v3550b.jar
Stack Trace:
Caused by: org.osgi.framework.BundleException: The activator com.mycompany.ui.tag.Activator for bundle com.mycompany.ui.tag is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 40 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:150)
... 45 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (105).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:454)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 63 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
... 73 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
... 78 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
Re: Eclipse fails to activate UI plugin [message #654168 is a reply to message #654008] Mon, 14 February 2011 08:26 Go to previous message
On 02/12/2011 04:37 PM, Vijay wrote:
> Thanks!
> Vijay
> Problem:
> below.
> Platform: HP-UX IA64
> Eclipse Equinox Jar: org.eclipse.equinox.launcher_1.0.200.v20090520.jar
> Eclipse SWT: org.eclipse.swt.motif.hpux.ia64_32.source_3.5.0.v3550b.jar
Is your JVM an IA64_32 bit JVM? Are you launching eclipse on hpux, and
then trying to launch your RCP app? Did you create an HPUX version
using the delta pack on windows?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Project import loses some files
Next Topic:glue code for linking two classes?
Current Time: Thu Jul 24 22:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.08593 seconds
