Home » Archived » BIRT » Chinese fonts(Adobe asking me download traditional chinese fonts)
Chinese fonts [message #653266] Wed, 09 February 2011 01:43 Go to next message
Hello Everyone,
I have a Simple RPt design which has a table and some rows and columns which are holding dynamic text.
When I generate the pdf report in the windows environment,It renders the pdf perfectly.
But,When I generate the pdf report in the Linux environment,
Adobe is asking me to download traditional chinese fonts.
Any suggestions will be really helpful..
Srikanth
Re: Chinese fonts [message #653440 is a reply to message #653266] Wed, 09 February 2011 13:35 Go to previous messageGo to next message
Srikanth,
Can you post the report? Does it contain fonts that you do not have
installed on linux?
Jason
On 2/9/2011 1:43 AM, srikanth wrote:
> Hello Everyone,
> pdf perfectly.
> Regards,
> Srikanth
Re: Chinese fonts [message #653663 is a reply to message #653440] Thu, 10 February 2011 10:52 Go to previous messageGo to next message
Hi Jason,
The same report was working fine on linux sometime back.Now its causing problem..
Below is the xml source of the rptdesign. I am populating the report fields using java beans.
The BIRT version is 2.6.0.v20100617-7m9f77FT0z0-H04OvPZz0D4
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.0.v20100531 Build &lt;2.6.0.v20100609-1613></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<script-data-source name="DataSource" id="7"/>
</data-sources>
<data-sets>
<script-data-set name="MainDataSet" id="8">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">tableHeaderField1</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">tableHeaderField1Value</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">tableHeaderField2</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">tableHeaderField2Value</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">tableField1</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">tableField2</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">tableField3</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">tableField4</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">tableField5</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">tableField6</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">tableField7</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">tableField8</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">tableField9</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">tableField10</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">tableField11</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">tableField12</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">tableField13</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">tableField14</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">tableField1Value</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">tableField2Value</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">tableField3Value</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">tableField4Value</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">tableField5Value</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">tableField6Value</property>
</structure>
<structure>
<property name="position">25</property>
<property name="name">tableField7Value</property>
</structure>
<structure>
<property name="position">26</property>
<property name="name">tableField8Value</property>
</structure>
<structure>
<property name="position">27</property>
<property name="name">tableField9Value</property>
</structure>
<structure>
<property name="position">28</property>
<property name="name">tableField10Value</property>
</structure>
<structure>
<property name="position">29</property>
<property name="name">tableField11Value</property>
</structure>
<structure>
<property name="position">30</property>
<property name="name">tableField12Value</property>
</structure>
<structure>
<property name="position">31</property>
<property name="name">tableField13Value</property>
</structure>
<structure>
<property name="position">32</property>
<property name="name">tableField14Value</property>
</structure>
<structure>
<property name="position">33</property>
<property name="name">title</property>
</structure>
<structure>
<property name="position">34</property>
<property name="name">titleValue</property>
</structure>
<structure>
<property name="position">35</property>
<property name="name">document</property>
</structure>
<structure>
<property name="position">36</property>
<property name="name">documentValue</property>
</structure>
<structure>
<property name="position">37</property>
<property name="name">location</property>
</structure>
<structure>
<property name="position">38</property>
<property name="name">locationValue</property>
</structure>
<structure>
<property name="position">39</property>
<property name="name">authors</property>
</structure>
<structure>
<property name="position">40</property>
<property name="name">authorsValue</property>
</structure>
<structure>
<property name="position">41</property>
<property name="name">grades</property>
</structure>
<structure>
<property name="position">42</property>
<property name="name">gradesValue</property>
</structure>
<structure>
<property name="position">43</property>
<property name="name">subjects</property>
</structure>
<structure>
<property name="position">44</property>
<property name="name">subjectsValue</property>
</structure>
<structure>
<property name="position">45</property>
<property name="name">courses</property>
</structure>
<structure>
<property name="position">46</property>
<property name="name">coursesValue</property>
</structure>
<structure>
<property name="position">47</property>
<property name="name">type</property>
</structure>
<structure>
<property name="position">48</property>
<property name="name">typeValue</property>
</structure>
<structure>
<property name="position">49</property>
<property name="name">dateModifiedValue</property>
</structure>
<structure>
<property name="position">50</property>
<property name="name">headerTitle</property>
</structure>
<structure>
<property name="position">51</property>
<property name="name">headerAuthor</property>
</structure>
<structure>
<property name="position">52</property>
<property name="name">formattedAuthorsValue</property>
</structure>
<structure>
<property name="position">53</property>
<property name="name">attachment</property>
</structure>
<structure>
<property name="position">54</property>
<property name="name">attachmentValue</property>
</structure>
<structure>
<property name="position">55</property>
<property name="name">formattedAuthors</property>
</structure>
<structure>
<property name="position">56</property>
<property name="name">notes</property>
</structure>
<structure>
<property name="position">57</property>
<property name="name">notesValue</property>
</structure>
<structure>
<property name="position">58</property>
<property name="name">docField1</property>
</structure>
<structure>
<property name="position">59</property>
<property name="name">docField1Value</property>
</structure>
<structure>
<property name="position">60</property>
<property name="name">docField2</property>
</structure>
<structure>
<property name="position">61</property>
<property name="name">docField2Value</property>
</structure>
<structure>
<property name="position">62</property>
<property name="name">docField3</property>
</structure>
<structure>
<property name="position">63</property>
<property name="name">docField3Value</property>
</structure>
<structure>
<property name="position">64</property>
<property name="name">lastmodifiedValue</property>
</structure>
<structure>
<property name="position">65</property>
<property name="name">type_in_header</property>
</structure>
<structure>
<property name="position">66</property>
<property name="name">type_in_headerValue</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">tableHeaderField1</property>
<text-property name="displayName">tableHeaderField1</text-property>
</structure>
<structure>
<property name="columnName">tableHeaderField1Value</property>
<text-property name="displayName">tableHeaderField1Value</text-property>
</structure>
<structure>
<property name="columnName">tableHeaderField2</property>
<text-property name="displayName">tableHeaderField2</text-property>
</structure>
<structure>
<property name="columnName">tableHeaderField2Value</property>
<text-property name="displayName">tableHeaderField2Value</text-property>
</structure>
<structure>
<property name="columnName">tableField1</property>
<text-property name="displayName">tableField1</text-property>
</structure>
<structure>
<property name="columnName">tableField2</property>
<text-property name="displayName">tableField2</text-property>
</structure>
<structure>
<property name="columnName">tableField3</property>
<text-property name="displayName">tableField3</text-property>
</structure>
<structure>
<property name="columnName">tableField4</property>
<text-property name="displayName">tableField4</text-property>
</structure>
<structure>
<property name="columnName">tableField5</property>
<text-property name="displayName">tableField5</text-property>
</structure>
<structure>
<property name="columnName">tableField6</property>
<text-property name="displayName">tableField6</text-property>
</structure>
<structure>
<property name="columnName">tableField7</property>
<text-property name="displayName">tableField7</text-property>
</structure>
<structure>
<property name="columnName">tableField8</property>
<text-property name="displayName">tableField8</text-property>
</structure>
<structure>
<property name="columnName">tableField9</property>
<text-property name="displayName">tableField9</text-property>
</structure>
<structure>
<property name="columnName">tableField10</property>
<text-property name="displayName">tableField10</text-property>
</structure>
<structure>
<property name="columnName">tableField11</property>
<text-property name="displayName">tableField11</text-property>
</structure>
<structure>
<property name="columnName">tableField12</property>
<text-property name="displayName">tableField12</text-property>
</structure>
<structure>
<property name="columnName">tableField13</property>
<text-property name="displayName">tableField13</text-property>
</structure>
<structure>
<property name="columnName">tableField14</property>
<text-property name="displayName">tableField14</text-property>
</structure>
<structure>
<property name="columnName">tableField1Value</property>
<text-property name="displayName">tableField1Value</text-property>
</structure>
<structure>
<property name="columnName">tableField2Value</property>
<text-property name="displayName">tableField2Value</text-property>
</structure>
<structure>
<property name="columnName">tableField3Value</property>
<text-property name="displayName">tableField3Value</text-property>
</structure>
<structure>
<property name="columnName">tableField4Value</property>
<text-property name="displayName">tableField4Value</text-property>
</structure>
<structure>
<property name="columnName">tableField5Value</property>
<text-property name="displayName">tableField5Value</text-property>
</structure>
<structure>
<property name="columnName">tableField6Value</property>
<text-property name="displayName">tableField6Value</text-property>
</structure>
<structure>
<property name="columnName">tableField7Value</property>
<text-property name="displayName">tableField7Value</text-property>
</structure>
<structure>
<property name="columnName">tableField8Value</property>
<text-property name="displayName">tableField8Value</text-property>
</structure>
<structure>
<property name="columnName">tableField9Value</property>
<text-property name="displayName">tableField9Value</text-property>
</structure>
<structure>
<property name="columnName">tableField10Value</property>
<text-property name="displayName">tableField10Value</text-property>
</structure>
<structure>
<property name="columnName">tableField11Value</property>
<text-property name="displayName">tableField11Value</text-property>
</structure>
<structure>
<property name="columnName">tableField12Value</property>
<text-property name="displayName">tableField12Value</text-property>
</structure>
<structure>
<property name="columnName">tableField13Value</property>
<text-property name="displayName">tableField13Value</text-property>
</structure>
<structure>
<property name="columnName">tableField14Value</property>
<text-property name="displayName">tableField14Value</text-property>
</structure>
<structure>
<property name="columnName">title</property>
<text-property name="displayName">title</text-property>
</structure>
<structure>
<property name="columnName">titleValue</property>
<text-property name="displayName">titleValue</text-property>
</structure>
<structure>
<property name="columnName">document</property>
<text-property name="displayName">document</text-property>
</structure>
<structure>
<property name="columnName">documentValue</property>
<text-property name="displayName">documentValue</text-property>
</structure>
<structure>
<property name="columnName">location</property>
<text-property name="displayName">location</text-property>
</structure>
<structure>
<property name="columnName">locationValue</property>
<text-property name="displayName">locationValue</text-property>
</structure>
<structure>
<property name="columnName">authors</property>
<text-property name="displayName">authors</text-property>
</structure>
<structure>
<property name="columnName">authorsValue</property>
<text-property name="displayName">authorsValue</text-property>
</structure>
<structure>
<property name="columnName">grades</property>
<text-property name="displayName">grades</text-property>
</structure>
<structure>
<property name="columnName">gradesValue</property>
<text-property name="displayName">gradesValue</text-property>
</structure>
<structure>
<property name="columnName">subjects</property>
<text-property name="displayName">subjects</text-property>
</structure>
<structure>
<property name="columnName">subjectsValue</property>
<text-property name="displayName">subjectsValue</text-property>
</structure>
<structure>
<property name="columnName">courses</property>
<text-property name="displayName">courses</text-property>
</structure>
<structure>
<property name="columnName">coursesValue</property>
<text-property name="displayName">coursesValue</text-property>
</structure>
<structure>
<property name="columnName">type</property>
<text-property name="displayName">type</text-property>
</structure>
<structure>
<property name="columnName">typeValue</property>
<text-property name="displayName">typeValue</text-property>
</structure>
<structure>
<property name="columnName">dateModifiedValue</property>
<text-property name="displayName">dateModifiedValue</text-property>
</structure>
<structure>
<property name="columnName">headerTitle</property>
<text-property name="displayName">headerTitle</text-property>
</structure>
<structure>
<property name="columnName">headerAuthor</property>
<text-property name="displayName">headerAuthor</text-property>
</structure>
<structure>
<property name="columnName">formattedAuthorsValue</property>
<text-property name="displayName">formattedAuthorsValue</text-property>
</structure>
<structure>
<property name="columnName">attachment</property>
<text-property name="displayName">attachment</text-property>
</structure>
<structure>
<property name="columnName">attachmentValue</property>
<text-property name="displayName">attachmentValue</text-property>
</structure>
<structure>
<property name="columnName">formattedAuthors</property>
<text-property name="displayName">formattedAuthors</text-property>
</structure>
<structure>
<property name="columnName">notes</property>
<text-property name="displayName">notes</text-property>
</structure>
<structure>
<property name="columnName">notesValue</property>
<text-property name="displayName">notesValue</text-property>
</structure>
<structure>
<property name="columnName">docField1</property>
<text-property name="displayName">docField1</text-property>
</structure>
<structure>
<property name="columnName">docField1Value</property>
<text-property name="displayName">docField1Value</text-property>
</structure>
<structure>
<property name="columnName">docField2</property>
<text-property name="displayName">docField2</text-property>
</structure>
<structure>
<property name="columnName">docField2Value</property>
<text-property name="displayName">docField2Value</text-property>
</structure>
<structure>
<property name="columnName">docField3</property>
<text-property name="displayName">docField3</text-property>
</structure>
<structure>
<property name="columnName">docField3Value</property>
<text-property name="displayName">docField3Value</text-property>
</structure>
<structure>
<property name="columnName">lastmodifiedValue</property>
<text-property name="displayName">lastmodifiedValue</text-property>
</structure>
<structure>
<property name="columnName">type_in_header</property>
<text-property name="displayName">type_in_header</text-property>
</structure>
<structure>
<property name="columnName">type_in_headerValue</property>
<text-property name="displayName">type_in_headerValue</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<proper
Re: Chinese fonts [message #653701 is a reply to message #653663] Thu, 10 February 2011 13:22 Go to previous messageGo to next message
Srikanth,
The whole report did not come through. Can you email it to me at
jasonweathersby at windstream dot net? Where is it getting the dynamic
text from?
Jason
On 2/10/2011 10:52 AM, srikanth wrote:
> Hi Jason,
> problem..
> id="1">
> Build <2.6.0.v20100609-1613></property>
> <data-sources>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <proper
Re: Chinese fonts [message #653772 is a reply to message #653701] Fri, 11 February 2011 00:50 Go to previous messageGo to next message
Hi Jason,
I have mailed the rptdesign to
jasonweathersby@windstream.net
I am populating the dynamic text from java beans that I am getting from a java class which I am calling the dataset called "MainDataSet" script.
I had faced the similar issue where the adobe asked me download the Chinese fonts but that was because the data had mathematical characters like "<,>" and that issue was reproducible in both Windows and Linux environment and I had fixed the issue by changing the font type from San-serif to Arial in the rptDesign.
Srikanth
[Updated on: Fri, 11 February 2011 00:53] by Moderator
Re: Chinese fonts [message #653869 is a reply to message #653772] Fri, 11 February 2011 11:08 Go to previous message
Srikanth,
I looked over the design and did not see anything obvious. I assume it
is something in the data. Can you log a bug for this?
Jason
On 2/11/2011 12:51 AM, srikanth wrote:
> Hi Jason,
> I have mailed the rptdesign to mailto:jasonweathersby@windstream.net
> I am populating the dynamic text from java beans from I am getting from
> Regards,
> Srikanth
Previous Topic:Help! Report design got corrupted!
Next Topic:Customize a Pie Chart with Java under Eclispe
Current Time: Wed Jul 23 02:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.06704 seconds
