Keyboard doesn't work in Eclipse 3.5 [message #435538] |
Thu, 30 July 2009 17:08  |
For some reason, Eclipse is not accepting keyboard input anywhere - not in the editor, not in the Preference menu, not in any of the dialogs. I can copy/paste and the function keys do what they're supposed to do, but otherwise it doesn't accept keyboard input. Keyboard works fine in other apps.
ADDENDUM: This was after installing the Blackberry JDE... currently pursuing that route.
thanks,
michael
[Updated on: Thu, 30 July 2009 17:34] by Moderator
Re: Keyboard doesn't work in Eclipse 3.5 [message #437897 is a reply to message #435538] |
Thu, 30 July 2009 23:00   |
"Michael D" <mmdurrant@gmail.com> wrote in message
news:h4t251$2gh$1@build.eclipse.org...
> apps.
Since obviously Eclipse 3.5 is working for many users, this seems like it is
probably due to something in your configuration, or to a corrupted file,
etc. So: perhaps you could provide some details about what your
configuration is, what you've tried so far, whether there are any errors
indicated in the error log, whether it worked for you in the past and if so
what might have changed since then, and so forth.
Re: Keyboard doesn't work in Eclipse 3.5 [message #1837219 is a reply to message #435538] |
Mon, 25 January 2021 06:22  |
I've got the same issue with
Eclipse Version: 2020-09 (4.17.0)
Build id: 20200910-1200
on CentOS8.2.
openjdk version "1.8.0_252"
The issue is not reproducible, doesn't happen frequently (once in a week), doesn't seem to be related with other programs.
Switching Project Explorer and/or Outline sometimes solves the issue, but nothing helps if both keyboard and mouse are blocked.
May be an Eclipse-GNOME issue(?)
My fix: after <CTRL>-<ALT>-<DEL> Eclipse throw up confirmation window, so I had the opportunity to save my work at least :)
FUDForum. Page generated in 0.23908 seconds
