Home » Archived » BIRT » Crosstab inside of a table
Crosstab inside of a table [message #653465] Wed, 09 February 2011 15:41 Go to next message
Originally posted by: remkus.wideopenwest.com
My application constrains me to using BIRT 2.2.1.
I'd like to have a table of data with groups defined.
In the detail row, I'd like to have a crosstab which is filtered on data
from the table.
I've tried setting a filter on the crosstab .. no luck.
<property name="level">PerformanceView/DEVICE_NAME</property>
<property name="filter">
<filter-condition-element>
<expression
name="expr">dimension["PerformanceView"]["DEVICE_NAME"] </expression>
<property name="operator">eq</property>
<simple-property-list name="value1">
<value>data._outer["DEVICE_NAME"]</value>
</simple-property-list>
</filter-condition-element>
</property>
When I run the report, I get a message
"org.mozilla.javascript.EcmaError: TypeError: Cannot read property
"DEVICE_NAME" from null"
Any suggestions?
Re: Crosstab inside of a table [message #653711 is a reply to message #653465] Thu, 10 February 2011 13:43 Go to previous messageGo to next message
Dave,
Not sure this will work but can you add an oncreate script to the row
containing the xtab. In that script get the column value device name
and use reportContext.setGlobalVariable("dn", yourvalue);
Then in the filter put
reportConxtext.getGlobalVariable("dn");
instead of
Jason
> from the table.
> <expression
> </property>
> Any suggestions?
> Thanks
Re: Crosstab inside of a table [message #653729 is a reply to message #653711] Thu, 10 February 2011 15:38 Go to previous messageGo to next message
Jason,
I had been thinking along the lines of setting a variable in the row's
onCreate, but it didn't dawn on me that I could just access the variable
from the reportContext when building the filter expression!
It works ... I'm not sure if you just made a typo or if there's a
concept I don't understand between get/setGlobalVarable and
get/setPersistentGlobalVariable, but I had to use persistent variables
to make my report work
Thanks a ton!
On 02/10/11 13:43, Jason Weathersby wrote:
> Dave,
> instead of
> Jason
>> from the table.
>> <expression
>> </property>
>> Any suggestions?
>> Thanks
Re: Crosstab inside of a table [message #653732 is a reply to message #653729] Thu, 10 February 2011 15:57 Go to previous messageGo to next message
Dave,
It was not a typo. Persistent variables are written to the rptdocument
allowing the separation of run and render task in two java processes.
It should be fine to use persistent. I am a bit curious why the
standard global did not work.
Jason
On 2/10/2011 3:38 PM, Dave Remkus wrote:
> Jason,
> Thanks a ton!
>> Dave,
>> instead of
>> Jason
>>> from the table.
>>> <expression
>>> </property>
>>> Any suggestions?
>>> Thanks
Re: Crosstab inside of a table [message #653922 is a reply to message #653732] Fri, 11 February 2011 16:20 Go to previous message
Jason,
I must have typo'd something when I was trying set/getGlobalVariable ...
now that I have the report working with persistent variables, I went
back and tried standard globals and they work fine! (:doooh!)
On 02/10/11 15:57, Jason Weathersby wrote:
> Dave,
> allowing the separation of run and render task in two java processes. It
> should be fine to use persistent. I am a bit curious why the standard
> Jason
>> Jason,
>> Thanks a ton!
>>> Dave,
>>> instead of
>>> Jason
>>>> data
>>>> from the table.
>>>> <expression
>>>> </property>
>>>> Any suggestions?
>>>> Thanks
Previous Topic:Customize a Pie Chart with Java under Eclispe
Next Topic:how to decode base64 password in BIRT script and when
Current Time: Sat Jul 26 07:52:44 EDT 2025
Powered by FUDForum. Page generated in 0.25723 seconds
