Home » Archived » BIRT » how to configure where BIRT cache is located
how to configure where BIRT cache is located [message #653193] |
Tue, 08 February 2011 14:16  |
we are using BIRT 2.2.1 due to Java 1.4 considerations, is there a way
to configure where the "BirtDataTemp..." directories are created?
presently, by default, they are showing up in "/tmp" directory, but we
would like to locate then in a application specific area, somewhere
under "${birt home}" preferably.
Re: how to configure where BIRT cache is located [message #653491 is a reply to message #653202] |
Wed, 09 February 2011 17:40   |
On 2/8/2011 1:51 PM, Jason Weathersby wrote:
> John,
> Currently this comes from either the engine config or the system property:
> System.getProperty( "java.io.tmpdir" );
> If using the api just do
> EngineConfig config = new EngineConfig();
> config.setTempDir("yourlocation");
> If using the viewer set the system property above on the app server
> startup or put script like this in a report's before factory (if its
> changed once it will affect all other reports ran afterwards):
> reportContext.getReportRunnable().getEngine().getConfig().se tTempDir( "yourlocation");
> Jason
Thanks for the info, I'm trying to test, so first I wanted to validate
where the "BirtDataTemp..." folders where getting created on my test
system, before I implement the change. Now I can't seem to get the
folders to be created. I've run several reports and no instances of the
folders has shown up, but I have found old ones on my test system.
Under what conditions do these folders get created (again we are using
version 2.2.1)? Thanks again for your help.
Re: how to configure where BIRT cache is located [message #653693 is a reply to message #653202] |
Thu, 10 February 2011 12:24   |
> John,
> Jason
Jason,
We are not using the API so I've implemented this in a report script and
am getting an error, here is what I put into the "before factory" script:
reportContext.getReportRunnable().getEngine().getConfig().se tTempDir( "C:\birt\tmp");
and this is the error:
Caused by: org.mozilla.javascript.EcmaError: TypeError: getEngine is not
a function. (<inline>#1)
Is getEngine() not available in 2.2.1 or is it misspelled, or ...?
Re: how to configure where BIRT cache is located [message #653700 is a reply to message #653693] |
Thu, 10 February 2011 13:20   |
Try:
reportContext.getReportRunnable().getReportEngine().getConfi g().setTempDir( "c:/test");
Jason
>> John,
>> property:
>> Jason
> Jason,
Re: how to configure where BIRT cache is located [message #653726 is a reply to message #653700] |
Thu, 10 February 2011 15:25   |
On 2/10/2011 11:20 AM, Jason Weathersby wrote:
> Try:
> Jason
>>> John,
>>> property:
>>> Jason
>> Jason,
Jason, thanks that resolved the error. Now in my testing I don't seem
to be generating the "BirtDataTemp..." folders, I've run several reports
and no instances of the folders has shown up. I have old ones on my test
system. Under what conditions do these folders get created (again we are
using version 2.2.1)? Thanks again for your help.
Re: how to configure where BIRT cache is located [message #653728 is a reply to message #653726] |
Thu, 10 February 2011 15:34   |
I believe these happen when you have large datasets that are cached to disk.
Jason
>> Try:
>> Jason
>>>> John,
>>>> property:
>>>> Jason
>>> Jason,
>>> script:
> Jason, thanks that resolved the error. Now in my testing I don't seem to
Re: how to configure where BIRT cache is located [message #727143 is a reply to message #726783] |
Tue, 20 September 2011 10:08  |
Jason I used the following code in my application's BirtReportHelper.java:
String sparkTemp = System.getenv( "SPARK_TEMP" );
config.setTempDir( sparkTemp );
It's now working for me. Thank you so much Jason.
But Jason what is the difference between running report with the viewer and with Report Engine API. I have ReportEngine and WebViewerExample folders in my deploy/BIRT location and one birt.war file. So I guess this application uses viewer. Thanks a lot again.
Current Time: Wed Jul 23 14:15:11 EDT 2025
Powered by FUDForum. Page generated in 0.05041 seconds
