.git Folder Visible in Navigator [message #653346] |
Wed, 09 February 2011 08:30  |
I've been using SVN/Subversive for years and wanted to get into Git. I've decided to give EGit a try.
When I follow the tutorial on this page:
http://wiki.eclipse.org/EGit/User_Guide
...I end up with a project and a git repository and everything (including git-related stuff) seems to work fine. I can commit, view history, etc. However, when I view the project in a navigator view, the .git repository folder is visible and shows in the view as unversioned-files.
This doesn't seem right. None of the screenshots in the tutorials show a visible .git folder. Also, when I clone a remote git repository and create a new project from it, the .git folder is properly hidden from view.
Is there something simple I'm missing here? Is this a known bug?
I'm running Helios on Windows. I have the most recent EGit plugin as of the time of this writing.
Thanks!
Re: .git Folder Visible in Navigator [message #654181 is a reply to message #653747] |
Mon, 14 February 2011 09:00  |
On 10/02/2011 23:02, eclipse@musicware.com wrote:
> Okay, I figured it out. I was running the 0.10.1 release. I installed to
> bleeding edge build and was eventually able to solve it.
> Interestingly, even after upgrading the plug-in the .git folder still
> would not go away in my previously existing project. Opening and closing
> the preexisting project didn't get rid of the folder either.
> I had to create a new project, close it, and reopen it, then the folder
> finally went away.
> I hope this helps someone out there. Thanks for your help.
> - Mike
I discovered that if I share a project with the project tree nodes open
then I can see the .git folder in Package Explorer (assuming you haven't
filtered "*.resources"). But share the project with the project node
collapsed and you don't see it.
FUDForum. Page generated in 0.05315 seconds
