Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Combo look-and-feel on Windows 7
Combo look-and-feel on Windows 7 [message #653610] Thu, 10 February 2011 07:02 Go to next message
Hi all,
In our RCP application we set the background of a combo to let the user know it is a required field. When running this application on Windows XP the background of the text-area of the combo is rendered in blue.
When we run this application on a Windows 7 the background of this text-area is rendered in some grey color. When the combo list is shown the background of the list is still in blue. But because of this grey color the user can't see anymore if this field is required or not.
I tried running our application with both Eclipse 3.5 and Eclipse 3.6 SR1, but the look-and-feel of the combo is the same. So I guess (and fear) this new look is the new style of a combo in Windows 7. It's quiet an important part of the user experience of our application, so it would be great if this grey color can be changed back to blue on Windows 7.
Any suggestions / ideas are highly appreciated.
Thanks!
Kind regards,
Roel
Re: Combo look-and-feel on Windows 7 [message #654649 is a reply to message #653610] Wed, 16 February 2011 10:01 Go to previous messageGo to next message
Hi Roel,
I tried setting a Combo's background to blue on Windows 7 and I didn't see
an obvious behavioural difference from XP. Does this problem happen for you
regardless of the background colour you choose? Are you using the default
Windows 7 theme? Can you provide a screenshot showing the problem?
Grant
"Roel De Nijs" <roel@javaroe.be> wrote in message
news:ij0jo9$res$1@news.eclipse.org...
> Hi all,
> Thanks!
> Kind regards,
> Roel
Re: Combo look-and-feel on Windows 7 [message #654793 is a reply to message #653610] Thu, 17 February 2011 02:59 Go to previous messageGo to next message
Hi Grant,
I used following small code snippet to test the combo's behavior:
public class ComboTest {
		Display display = new Display();
		Shell shell = new Shell(display);
		shell.setText("ComboTest");
		shell.setLayout(new FillLayout(SWT.VERTICAL));
		new Text(shell, SWT.SINGLE);
		Combo combo = new Combo(shell, SWT.READ_ONLY);
		combo.setItems(new String[] { "A", "B", "C" });
		combo.setBackground(new Color(display, 153, 186, 243));
		shell.pack();
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch())
				display.sleep();
		display.dispose();
I don't see any possibility to attach some files to this topic, so I guess it's not allowed to add files to this forum (according to the help pages).
I executed this program on a Windows XP and a Windows 7 machine and took some screenshots to show the difference.
1. WinXP with XP Theme
http://www.javaroe.be/winxp-theme-xp.jpg
2. WinXP with Classic Theme
http://www.javaroe.be/winxp-theme-classic.jpg
3. Win7 with Win7 Basic Theme
http://www.javaroe.be/win7-theme-win7-basic.jpg
4. Win7 with Windows Classic Theme
http://www.javaroe.be/win7-theme-win-classic.jpg
As you can see the combo looks different on a Win7 with Win7 basic theme (see 3rd screenshot) and the user can't see the blue-ish color (which in our application is the color to indicate a mandatory field).
I ran the code snippet with both Eclipse 3.5 (sr2) and 3.6 (sr1) and the results are the same. I also tried with a different color, but again similar results.
Kind regards,
Roel
Re: Combo look-and-feel on Windows 7 [message #654904 is a reply to message #654793] Thu, 17 February 2011 09:56 Go to previous messageGo to next message
I see, this is for read-only Combos. This is a behaviour that comes from
the theme, so it's "correct" (see "hint" in the javadoc for
Control.setBackground()). It's not something that swt would change, and
quite possibly could not override anyways. I don't know of a workaround to
suggest to make this work, other than to change your visual cue for marking
a control as being "required".
Grant
news:ijik5k$jq9$1@news.eclipse.org...
> Hi Grant,
> public static void main(String[] args) {
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
> similar results.
> Kind regards,
> Roel
Re: Combo look-and-feel on Windows 7 [message #654964 is a reply to message #653610] Thu, 17 February 2011 14:07 Go to previous messageGo to next message
Thanks for confirming this behavior for read-only combos. No need to look further into overriding this behavior.
Do you know if it is possible to simulate the behavior of a read-only combo without using the style constant SWT.READ_ONLY ? So the user should only be able to select 1 item in the drop down list, without being able to enter an item himself.
I guess using the style constant SWT.DROP_DOWN could be an alternative, if it is possible to make it non-editable.
Roel
Re: Combo look-and-feel on Windows 7 [message #655064 is a reply to message #653610] Fri, 18 February 2011 03:47 Go to previous messageGo to next message
We'll use CCombo to emulate a combo's behavior. It's almost as good as a native one with a big plus: the background of the ccombo (the text field) has the correct background color (even on a Windows 7 machine).
Just 2 (minor) issues in comparison with a native combo:
* because a text field is used for the emulation, it seems you can enter some text in the text field (but you can't if you use READ_ONLY style)
* with a native combo you can enter the first letter of an item and the combo will select this item, with a ccombo you can't
But we prefer showing the correct background color above these issues, so CCombo is the obvious choice (unless you would know of some big troubles using this control)
Thanks!
Roel
[Updated on: Fri, 18 February 2011 03:48] by Moderator
Re: Combo look-and-feel on Windows 7 [message #655177 is a reply to message #655064] Fri, 18 February 2011 09:59 Go to previous messageGo to next message
No, there shouldn't be a problem with using CCombo, I should have thought of
this as an alternate suggestion.
Grant
news:ijlbbb$mjb$1@news.eclipse.org...
> using this control)
> Thanks!
Re: Combo look-and-feel on Windows 7 [message #655209 is a reply to message #655177] Fri, 18 February 2011 11:32 Go to previous message
Thanks, Grant!
Previous Topic:Cannot remove first item when using TableEditor and Table.Remove(0) is used
Next Topic:mouseDown/widgetSelected/mouseUp behavior
Current Time: Fri Jul 25 21:53:28 EDT 2025
Powered by FUDForum. Page generated in 0.04207 seconds
