Home » Archived » Buckminster » setting the time zone for buckminster?
setting the time zone for buckminster? [message #653483] Wed, 09 February 2011 17:08 Go to next message
so ... Buckminster thinks I'm in GMT and so my hours are wrong.
I've got this set in my properties file:
# How .qualifier in versions should be replaced
qualifier.replacement.*=generator:buildTimestamp
# How the qualifier (last revision) should be formatted
generator.buildTimestamp.format='v'yyyyMMdd-HHmm
and when it runs, the HH are off because it's in GMT. How do I tell Buckminster my time zone? or Java?
thanks
Tamar
Re: setting the time zone for buckminster? [message #653496 is a reply to message #653483] Wed, 09 February 2011 19:02 Go to previous messageGo to next message
I have not checked how it works, but are you sure it is not your local
time but expressed as GMT/UTC? This would be a reasonable approach to
make sure that files produced in any timezone have timestamps in "global
order".
- henrik
> thanks
> Tamar
Re: setting the time zone for buckminster? [message #653532 is a reply to message #653483] Thu, 10 February 2011 02:34 Go to previous message
There's a very good reason why the qualifiers use UTC. That makes the build completely insensitive to timestamps.
- thomas
> thanks
> Tamar
Previous Topic:Updating installed product headlessly
Next Topic:Dependency resolution - too broad?
Current Time: Sat Jul 19 02:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.05323 seconds
