Home » Archived » BIRT » Using BIRT APIs
Using BIRT APIs [message #653220] |
Tue, 08 February 2011 16:56  |
I would like to utilize BIRT APIs. Is there a document which lists the APIs and what they do? I am looking for APIs to remove columns and rows, change text color, change font and preview mainly; however, might need more later.
please advise
Neil
Re: Using BIRT APIs [message #654431 is a reply to message #654293] |
Tue, 15 February 2011 13:01   |
Neil,
If you just want to drop a detail row you can use the drop method. I am
attaching a test class that shows how to do various things with the de
api. In the example I insert a detail row using the
RowOperationParameters class. Right before I save the design I drop the
added row.
Jason
package DEAPI;
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import java.io.BufferedInputStream;
import java.io.InputStream;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.ColumnHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.ImageHandle;
import org.eclipse.birt.report.model.api.ActionHandle;
import org.eclipse.birt.report.model.api.ReportElementHandle;
import org.eclipse.birt.report.model.api.RowOperationParameters;
import org.eclipse.birt.report.model.api.ScalarParameterHandle;
import org.eclipse.birt.report.model.api.ScriptLibHandle;
import org.eclipse.birt.report.model.api.TextItemHandle;
import org.eclipse.birt.report.model.elements.JointDataSet;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.JointDataSetHandle;
import org.eclipse.birt.report.model.api.JoinConditionHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import org.eclipse.birt.report.model.elements.ReportItem;
import org.eclipse.birt.report.model.api.elements.structures.Embedd edImage;
import org.eclipse.birt.report.model.elements.Style;
import org.eclipse.birt.report.model.elements.ReportDesign;
import org.eclipse.birt.report.model.api.StyleHandle;
import
org.eclipse.birt.report.model.api.elements.structures.Aggreg ationArgument;
import
org.eclipse.birt.report.model.api.elements.structures.DateTi meFormatValue;
import org.eclipse.birt.report.model.api.elements.structures.Format Value;
import org.eclipse.birt.report.model.api.elements.structures.MapRul e;
import org.eclipse.birt.report.model.api.elements.structures.HideRu le;
import
org.eclipse.birt.report.model.api.elements.structures.Proper tyBinding;
import org.eclipse.birt.report.model.api.elements.structures.TOC;
import org.eclipse.birt.report.model.api.elements.structures.JoinCo ndition;
import org.eclipse.birt.report.model.api.elements.structures.ParamB inding;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConst ants;
import org.eclipse.birt.report.model.api.elements.structures.Highli ghtRule;
import org.eclipse.birt.report.model.elements.interfaces.IJointData SetModel;
import org.eclipse.birt.report.model.api.elements.structures.SortKe y;
import org.eclipse.birt.report.model.api.SortKeyHandle;
import
org.eclipse.birt.report.model.api.elements.structures.Filter Condition;
import org.eclipse.birt.report.model.api.elements.structures.Action ;
import org.eclipse.birt.report.model.api.elements.structures.Includ eScript;
import java.util.Iterator;
import com.ibm.icu.util.ULocale;
* Simple BIRT Design Engine API (DEAPI) demo.
public class StructFactoryTest
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public static void main( String[] args )
try
StructFactoryTest de = new StructFactoryTest();
de.buildReport();
catch ( IOException e )
e.printStackTrace();
catch ( SemanticException e )
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
PropertyBinding pb = new PropertyBinding();
designHandle.getDataSources( ).add( dsHandle );
long currid = dsHandle.getID();
//pb.setName("odaUser");
//pb.setID(currid);
//pb.setValue("params[\"NewParameter\"].value");
//PropertyHandle ph = designHandle.getPropertyHandle("propertyBindings");
//ph.addItem(pb);
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds",
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select * from customers";
dsHandle.setQueryText( qry );
addFilterCondition( dsHandle );
designHandle.getDataSets( ).add( dsHandle );
void buildDataSet2( ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds2",
String qry = "Select * from orderdetails where ordernumber = ?";
void buildJointDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle1 = designFactory.newOdaDataSet( "ds1",
dsHandle1.setDataSource( "Data Source" );
String qry1 = "Select * from customers";
dsHandle1.setQueryText( qry1 );
OdaDataSetHandle dsHandle2 = designFactory.newOdaDataSet( "ds2",
dsHandle2.setDataSource( "Data Source" );
String qry2 = "Select * from orders";
dsHandle2.setQueryText( qry2 );
JointDataSetHandle jds = designFactory.newJointDataSet("test");
designHandle.getDataSets( ).add( dsHandle1 );
designHandle.getDataSets( ).add( dsHandle2 );
jds.addDataSet("ds1");
jds.addDataSet("ds2");
String leftExpression = "dataSetRow[\"CUSTOMERNUMBER\"]";
String rightExpression = "dataSetRow[\"CUSTOMERNUMBER\"]";
JoinCondition condition = StructureFactory.createJoinCondition( );
condition.setJoinType( DesignChoiceConstants.JOIN_TYPE_LEFT_OUT );
condition.setOperator( DesignChoiceConstants.JOIN_OPERATOR_EQALS );
condition.setLeftDataSet( "ds1" ); //$NON-NLS-1$
condition.setRightDataSet( "ds2" ); //$NON-NLS-1$
condition.setLeftExpression( leftExpression ); //$NON-NLS-1$
condition.setRightExpression( rightExpression ); //$NON-NLS-1$
PropertyHandle conditionHandle = jds
.getPropertyHandle( JointDataSet.JOIN_CONDITONS_PROP );
conditionHandle.addItem( condition );
designHandle.getDataSets( ).add( jds );
void addMapRule(TableHandle th){
try{
MapRule mr = structFactory.createMapRule();
mr.setTestExpression("row[\"CustomerCreditLimit\"]");
mr.setOperator(DesignChoiceConstants.MAP_OPERATOR_EQ);
mr.setValue1("0");
mr.setDisplay("N/A");
PropertyHandle ph = th.getPropertyHandle(StyleHandle.MAP_RULES_PROP);
ph.addItem(mr);
}catch (Exception e){
void addVisRule(ReportElementHandle rh){
try{
HideRule hr = structFactory.createHideRule();
hr.setFormat("pdf");
hr.setExpression("true");
PropertyHandle ph = rh.getPropertyHandle(ReportItem.VISIBILITY_PROP);
ph.addItem(hr);
void addBottomBorder(ReportElementHandle rh){
try{
rh.setProperty(StyleHandle.BORDER_BOTTOM_COLOR_PROP, "#000000");
rh.setProperty(StyleHandle.BORDER_BOTTOM_STYLE_PROP, "solid");
rh.setProperty(StyleHandle.BORDER_BOTTOM_WIDTH_PROP, "2px");
void addHighLightRule(RowHandle th){
try{
HighlightRule hr = structFactory.createHighlightRule();
hr.setOperator(DesignChoiceConstants.MAP_OPERATOR_GT);
hr.setTestExpression("row[\"CustomerCreditLimit\"]");
hr.setValue1("100000");
hr.setProperty(HighlightRule.BACKGROUND_COLOR_MEMBER, "blue");
PropertyHandle ph =
th.getPropertyHandle(StyleHandle.HIGHLIGHT_RULES_PROP);
ph.addItem(hr);
void addSortKey(TableHandle th){
try{
SortKey sk = structFactory.createSortKey();
//sk.setKey("row[\"CustomerName\"]");
sk.setDirection(DesignChoiceConstants.SORT_DIRECTION_ASC);
sk.setKey("if( params[\"srt\"].value){ if( params[\"srt\"].value ==
'a' ){ row[\"CustomerName\"]; }else{ row[\"CustomerCity\"];}}");
PropertyHandle ph = th.getPropertyHandle(TableHandle.SORT_PROP);
ph.addItem(sk);
void modSortKey(TableHandle th){
try{
SortKeyHandle sk;
//get number or iterate
sk = (SortKeyHandle)ph.get(0);
sk.setDirection(DesignChoiceConstants.SORT_DIRECTION_DESC);
void addFilterCondition(OdaDataSetHandle dh){
try{
FilterCondition fc = structFactory.createFilterCond();
fc.setExpr("row[\"COUNTRY\"]");
fc.setOperator(DesignChoiceConstants.MAP_OPERATOR_EQ);
fc.setValue1("'USA'");
dh.addFilter(fc);
void addFilterCondition(TableHandle th){
try{
fc.setExpr("row[\"CustomerCountry\"]");
PropertyHandle ph = th.getPropertyHandle(TableHandle.FILTER_PROP);
ph.addItem(fc);
void addHyperlink(LabelHandle lh){
try{
Action ac = structFactory.createAction();
ActionHandle actionHandle = lh.setAction( ac );
//actionHandle.setURI("'http://www.google.com'");
actionHandle.setLinkType(DesignChoiceConstants.ACTION_LINK_T YPE_DRILL_THROUGH);
actionHandle.setReportName("c:/test/xyz.rptdesign");
actionHandle.setTargetFileType("report-design");
actionHandle.setTargetWindow("_blank");
actionHandle.getMember("paramBindings");
ParamBinding pb = structFactory.createParamBinding();
pb.setParamName("order");
pb.setExpression("row[\"ORDERNUMBER\"]");
actionHandle.addParamBinding(pb);
<structure name="action">
<property name="linkType">drill-through</property>
<property name="reportName">detail.rptdesign</property>
<property name="targetWindow">_blank</property>
<property name="targetFileType">report-design</property>
<list-property name="paramBindings">
<structure>
<property name="paramName">order</property>
<expression
name="expression">row["ORDERNUMBER"]</expression>
</structure>
</list-property>
</structure>
void addToc(DataItemHandle dh){
try{
TOC myToc = structFactory.createTOC("row[\"CustomerName\"]");
dh.addTOC(myToc);
void addImage(){
try{
EmbeddedImage image = structFactory.createEmbeddedImage( );
image.setType( DesignChoiceConstants.IMAGE_TYPE_IMAGE_JPEG );
image.setData( load( "logo3.jpg" ) );
image.setName( "mylogo" );
designHandle.addImage( image );
public byte[] load( String fileName ) throws IOException
InputStream is = null;
is = new BufferedInputStream( this.getClass( ).getResourceAsStream(
fileName ) );
byte data[] = null;
if ( is != null )
try
data = new byte[is.available( )];
is.read( data );
catch ( IOException e1 )
throw e1;
return data;
void addScript(ReportDesignHandle rh){
try{
IncludeScript is = structFactory.createIncludeScript();
is.setFileName("test.js");
rh.getPropertyHandle(ReportDesign.INCLUDE_SCRIPTS_PROP);
//ph.addItem(is);
void buildReport() throws IOException, SemanticException
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_5_1/birt-runtime-2_5_1/ReportEngine ");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject(
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
ReportDesignHandle design = null;
try{
//open a design or a template
designHandle = session.createDesign();
addScript( designHandle);
designFactory = designHandle.getElementFactory( );
//designHandle.findScriptLib("name").setName("test2");
//Iterator iter = designHandle.scriptLibsIterator( );
//((ScriptLibHandle) iter.next()).drop() ;
//designHandle.dropScriptLib( lib );
buildDataSource();
buildDataSet();
buildJointDataSet();
TableHandle table = designFactory.newTableItem( "table", 3 );
table.setWidth( "100%" );
table.setDataSet( designHandle.findDataSet( "ds" ) );
// get first row in group header of group 0 .
//RowOperationParameters parameters1 = new RowOperationParameters( 0, 0,
// 0 );
// get second row in group header of group 0.
//RowOperationParameters parameters2 = new RowOperationParameters( 0, 0,
// 1 );
// get second row in table footer.
//RowOperationParameters parameters3 = new RowOperationParameters( 2, -1,
// 1 );
// get first row in table header.
//RowOperationParameters parameters4 = new RowOperationParameters( 0, -1,
// 0 );
// get second row in table detail which contain row span.
//RowOperationParameters parameters5 = new RowOperationParameters( 2, -1,
// 1 );
// get first row in group header of group 1.
//RowOperationParameters parameters6 = new RowOperationParameters( 0, 1,
// 0 );
//second parm has to be -1 unless you are modifying a group
//third parm specifies the row number
//first parm is the slotid
RowOperationParameters ro = new RowOperationParameters(2, -1, 0);
table.insertRow(ro);
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1, cs2, cs3, cs4, cs5;
cs1 = StructureFactory.createComputedColumn();
cs1.setName("CustomerName");
cs1.setExpression("dataSetRow[\"CUSTOMERNAME\"]");
computedSet.addItem(cs1);
cs2 = StructureFactory.createComputedColumn();
cs2.setName("CustomerCity");
cs2.setExpression("dataSetRow[\"CITY\"]");
//cs2.setDataType(dataType)
computedSet.addItem(cs2);
cs3 = StructureFactory.createComputedColumn();
cs3.setName("CustomerCountry");
cs3.setExpression("dataSetRow[\"COUNTRY\"]");
computedSet.addItem(cs3);
cs4 = StructureFactory.createComputedColumn();
cs4.setName("CustomerCreditLimit");
cs4.setExpression("dataSetRow[\"CREDITLIMIT\"]");
computedSet.addItem(cs4);
cs5 = StructureFactory.createComputedColumn();
cs5.setName("CustomerCreditLimitSum");
cs5.setExpression("dataSetRow[\"CREDITLIMIT\"]");
cs5.setAggregateFunction("sum");
//cs5.setFilterExpression(expression)
//All or group name
//cs5.setAggregateOn(aggregateOn)
computedSet.addItem(cs5);
// table header
RowHandle tableheader = (RowHandle) table.getHeader( ).get( 0 );
ColumnHandle ch = (ColumnHandle)table.getColumns().get(0);
ch.setProperty("width", "50%");
ColumnHandle ch2 = (ColumnHandle)table.getColumns().get(1);
ch2.setSuppressDuplicates(true);
LabelHandle label1 = designFactory.newLabel("Label1" );
label1.setOnRender("var x = 3;");
addBottomBorder(label1);
label1.setText("Customer");
CellHandle cell = (CellHandle) tableheader.getCells( ).get( 0 );
cell.getContent( ).add( label1 );
LabelHandle label2 = designFactory.newLabel("Label2" );
label2.setText("City");
cell = (CellHandle) tableheader.getCells( ).get( 1 );
cell.getContent( ).add( label2 );
LabelHandle label3 = designFactory.newLabel("Label3" );
label3.setText("Credit Limit");
cell = (CellHandle) tableheader.getCells( ).get( 2 );
cell.getContent( ).add( label3 );
// table detail (second Detail Row)
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 1 );
cell = (CellHandle) tabledetail.getCells( ).get( 0 );
DataItemHandle data = designFactory.newDataItem( "data1" );
data.setResultSetColumn("CustomerName");
addToc( data );
cell.getContent( ).add( data );
cell = (CellHandle) tabledetail.getCells( ).get( 1 );
data = designFactory.newDataItem( "data2" );
data.setResultSetColumn("CustomerCity");
cell = (CellHandle) tabledetail.getCells( ).get( 2 );
data = designFactory.newDataItem( "data3" );
TextItemHandle tih =designFactory.newTextItem("mytextitem");
//tih.setContentType(contentType);
//tih.setContent(value);
data.setResultSetColumn("CustomerCreditLimit");
FormatValue fv = structFactory.newFormatValue();
fv.setPattern("#,##0.00{RoundingMode=HALF_UP}");
fv.setCategory("custom");
data.setProperty("numberFormat", fv);
addHyperlink(label1);
addMapRule(table);
addHighLightRule(tabledetail);
addSortKey(table);
modSortKey(table);
addFilterCondition(table);
addImage();
RowHandle tablefooter = (RowHandle) table.getFooter().get( 0 );
cell = (CellHandle) tablefooter.getCells( ).get( 0 );
ImageHandle image1 = designFactory.newImage( "mylogo" );
image1.setImageName( "mylogo" );
//image1.sets
//addVisRule( image1 );
//cell.getContent( ).add( image1 );
cell = (CellHandle) tablefooter.getCells( ).get( 2 );
data = designFactory.newDataItem( "datasum" );
//FormatValue formatValueToSet = new DateTimeFormatValue( );
//formatValueToSet.setPattern( "dd/mm/yy" );
//formatValueToSet.setCategory("Custom");
//data.setProperty( StyleHandle.DATE_TIME_FORMAT_PROP,
// formatValueToSet );
//has to have a style data.getStyle().setDateTimeFormat("dd/mm/yy");
data.setResultSetColumn("CustomerCreditLimitSum");
ScalarParameterHandle sph = designFactory.newScalarParameter("srt");
sph.setIsRequired(false);
//sph.setAllowNull(true);
//sph.setAllowBlank(true);
sph.setValueType(DesignChoiceConstants.PARAM_VALUE_TYPE_STAT IC);
sph.setDataType(DesignChoiceConstants.PARAM_TYPE_STRING);
designHandle.getParameters().add(sph);
//delete the row added earlier:
table.getDetail().get(0).drop();
designHandle.getBody( ).add( table );
// Save the design and close it.
designHandle.saveAs("output/desample/structfactorytest.rptdesign " );
designHandle.close( );
Platform.shutdown();
System.out.println("Finished");
On 2/14/2011 6:17 PM, Neil Wang wrote:
> Hi Jason,
> I would like to start with removing a row.
> I looked through the APIs in org.eclipse.birt.report.model.api and am
> thinking shiftRow() in TableHandle is the method to use. Of course, I
> could be wrong and also am not sure how to initiate a TableHandle.
> Please advise.
> Neil
Re: Using BIRT APIs [message #662812 is a reply to message #662782] |
Fri, 01 April 2011 00:09   |
Neil,
1 - If you just want to set the color do
tableheader.setProperty(StyleHandle.BACKGROUND_COLOR_PROP, "Blue");
or
tableheader.setProperty(StyleHandle.BACKGROUND_COLOR_PROP, "#FF8080");
2 - Not sure what you want here. Are you needing the fontFamily changed
use:
tableheader.setProperty( StyleHandle.FONT_WEIGHT_PROP,
DesignChoiceConstants.FONT_WEIGHT_BOLD );
tableheader.setProperty( StyleHandle.FONT_FAMILY_PROP, "Century" );
tableheader.setProperty( StyleHandle.FONT_SIZE_PROP, "12pt" );
3 - Do you mean row height or font size?
tableheader.setProperty(ReportItemHandle.HEIGHT_PROP, "1.2in");
4 - What is the context? The Web Viewer is a plugin and you can call
the WebViewer.display method from a RCP/Eclipse based app.
Jason
On 3/31/2011 6:10 PM, Neil Wang wrote:
> Hi Jason,
> I have some questions about how to modify the properties
> 1. Change the background color of a row
> This is what I did to change the background of a row:
> RowHandle tableheader = (RowHandle) table.getHeader().get(0);
> tableheader.getStyle().getBackgroundColor();
> I was looking for setBackgroundColor() but didn't find it. Please let me
> know how I can set the color? I would like to use RGB value to set the
> color.
> 2. Change the font of a row of text
> This is what I did to change the font of a row of text:
> tableheader.getStyle().setFontStyle(fontStyle)
> The java doc shows this:
> Sets the style of the font. The input value is one of constants defined
> in DesignChoiceConstants:
> - FONT_STYLE_NORMAL
> - FONT_STYLE_ITALIC
> - FONT_STYLE_OBLIQUE
> There is a lot of different fonts but I can't find them all. Please let
> me know how I can find them.
> 3. Change the size of a row of text
> I tried to find the method but couldn't find it. Please advise.
> 4. Is it possible to invoke the preview method programmatically; so
> that, preview can be performed on an existing template?
> regards,
> Neil
Re: Using BIRT APIs [message #663278 is a reply to message #663006] |
Mon, 04 April 2011 09:51   |
Neil,
I believe this will depend on what fonts are installed on your system.
The viewer plugin is org.eclipse.birt.report.viewer.
Jason
On 4/1/2011 7:24 PM, Neil Wang wrote:
> Hi Jason,
> Thank you for the comment.
> Do you know where I can find all the available values for
> "StyleHandle.FONT_FAMILY_PROP"?
> You have it as "Century" in the example.
> Also, what I am trying to do with preview is that I am adding a wizard
> to modify existing reports. In the wizard, I would like to have a
> preview button. When clicked, it will bring up a window which shows a
> subset of the report. If the Web Viewer is something I should use, can
> you please let me know which plugin has it?
> regards,
> Neil
Re: Using BIRT APIs [message #663650 is a reply to message #663412] |
Tue, 05 April 2011 23:07   |
Neil,
Can you try something like:
BrowserManager bmg = BrowserManager.getInstance();
bmg.setAlwaysUseExternal(false);
HashMap myparms = new HashMap();
HashMap emitmap = new HashMap();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
//myparms.put("RESOURCE_FOLDER_KEY", "c:/myresources");
myparms.put("ALLOW_PAGE", "false");
myparms.put("SHOW_PARAMETER_PAGE", "false");
//emitmap.put("Top Count", "6");
//myparms.put("EMITTER_OPTIONS_KEY", emitmap);
//myparms.put("MAX_ROWS_KEY", "500");
//WebViewer.display(rpt, browser, myparms);
//WebViewer.display(reportName, browser, myparms);
WebViewer.display(reportName, myparms);
I have commented out some of the options.
Jason
On 4/4/2011 6:16 PM, Neil Wang wrote:
> Hi Jason,
> Thank you for your comment. Is there a doc which explains how to use the
> display() method?
> I used this one: public static void display(String report, String
> format, boolean allowPage)
> This is how I invoked it: WebViewer.display("C:/report.rptdesign",
> WebViewer.HTML, true);
> However, I ran into this exception
> at org.eclipse.birt.report.viewer.utilities.AppServerWrapper.ge
> tPort(AppServerWrapper.java:207)
> at org.eclipse.birt.report.viewer.utilities.WebappAccessor.getP
> ort(WebappAccessor.java:162)
> at org.eclipse.birt.report.viewer.utilities.WebViewer.getBaseUR
> L(WebViewer.java:316)
> at org.eclipse.birt.report.viewer.utilities.WebViewer.createURL
> (WebViewer.java:532)
> (WebViewer.java:500)
> at org.eclipse.birt.report.viewer.utilities.WebViewer.display(W
> ebViewer.java:907)
> ebViewer.java:881)
> please advise,
> Neil
Re: Using BIRT APIs [message #664286 is a reply to message #664214] |
Fri, 08 April 2011 04:46   |
Neil,
Use MAX_ROWS_KEY:
myparms.put(WebViewer.MAX_ROWS_KEY, "5");
Jason
On 4/7/2011 4:55 PM, Neil Wang wrote:
> Hi Jason,
> Thank you. It works fine.
> Is there a property I can set to limit the number of rows in the report?
> please advise,
> Neil
Current Time: Wed Jul 23 05:39:47 EDT 2025
Powered by FUDForum. Page generated in 1.87965 seconds
