Home » Modeling » Graphiti » getX and getY in CreateReferenceFeature
getX and getY in CreateReferenceFeature [message #651953] Wed, 02 February 2011 03:55 Go to next message
Hello
I have got a problem.
I have a pictogramelement (witch is linked with a businessobject).
And another pictogramelement (witch is linked with a businessobject and
from the same type).
The pictogramelement has got fixed ports witch should not be seen or
almost. (the ports are only important for the meta-model)
However the ports should possible to connect
if the user clicks on the pictogramelement.
so the connection shall start from the closest port.
The problem is to get this port.
If I get the X and Y that would to it.
Maybe there is a good solution for this problem.
Re: getX and getY in CreateReferenceFeature [message #652001 is a reply to message #651953] Wed, 02 February 2011 06:57 Go to previous messageGo to next message
I'm not sure if I fully understood your problem, nevertheless here's the try
for an answer.
Usually, the ports would be represented as children of your pictogram
element. In order to make the ports visible you will need some graphics
algorithm to represent them (e.g. a circle). This graphics algorith has
coordinates (x and y) you can use for this purpose. In order to find the
port you can go through the containment hierarchie (getChildren) and the
graphics algorithm references of your pictogram element.
As I said, not sure if that solves it...
Michael
"hdw" wrote in message news:iib5rm$dc8$1@news.eclipse.org...
Hello
Re: getX and getY in CreateReferenceFeature [message #652095 is a reply to message #651953] Wed, 02 February 2011 11:39 Go to previous messageGo to next message
I want to use an other solution.
In this solution I got a new problem.
I wan to make a port. This port shall be only a straight line (polyline)
wen I want to make a connection a exceptions happens.
public PictogramElement add(final IAddContext context) {
	final BoxRelativeAnchor boxAnchor =
                    peCreateService.createBoxRelativeAnchor(containerShape);
	createGraphicalPort(boxAnchor);
	private void createGraphicalPort(BoxRelativeAnchor boxAnchor) {
		IGaService gaService = Graphiti.getGaService();
    	//Rectangle rec = gaService.createRectangle(boxAnchor);
		Polyline poly = gaService.createPolyline(boxAnchor ,new int[]{0,PORT_SIZE/2,PORT_SIZE,PORT_SIZE/2});
        //rec.setStyle(styleProvider.getStyle(StyleProvider.PORT));
        poly.setStyle(styleProvider.getStyle(StyleProvider.PORT));
        //gaService.setLocationAndSize(rec, 0, 0, PORT_SIZE, PORT_SIZE);
        gaService.setLocationAndSize(poly, 0, 0, PORT_SIZE, PORT_SIZE);
If there is only the rectangle and not the polyline, it works.
Because of the exceptions:
new vertexes and connection can't be added.
contex menues and context buttons aren't be shown.
and other exceptions.
Here the exceptions (when the connection will be create):
!ENTRY org.eclipse.ui 4 0 2011-02-02 17:23:39.158
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
	at org.eclipse.swt.SWT.error(SWT.java:4083)
	at org.eclipse.swt.SWT.error(SWT.java:3998)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
	at org.eclipse.graphiti.ui.internal.util.draw2d.LineSeg.getLineIntersectionsWithLineSegs(LineSeg.java:465)
	at org.eclipse.graphiti.ui.internal.util.draw2d.GFChopboxAnchor.getIntersectionPoints(GFChopboxAnchor.java:175)
	at org.eclipse.graphiti.ui.internal.util.draw2d.GFChopboxAnchor.getLocation(GFChopboxAnchor.java:126)
	at org.eclipse.graphiti.ui.internal.util.draw2d.GFChopboxAnchor.getLocation(GFChopboxAnchor.java:99)
	at org.eclipse.draw2d.AbstractRouter.getStartPoint(AbstractRouter.java:69)
	at org.eclipse.draw2d.ConnectionRouter$NullConnectionRouter.route(ConnectionRouter.java:92)
	at org.eclipse.draw2d.PolylineConnection.layout(PolylineConnection.java:176)
	at org.eclipse.draw2d.Figure.validate(Figure.java:1894)
	at org.eclipse.draw2d.Figure.validate(Figure.java:1896)
	at org.eclipse.draw2d.FreeformViewport$FreeformViewportLayout.calculatePreferredSize(FreeformViewport.java:25)
	at org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractLayout.java:110)
	at org.eclipse.draw2d.AbstractHintLayout.getPreferredSize(AbstractHintLayout.java:90)
	at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:807)
	at org.eclipse.draw2d.ScrollPaneSolver.solve(ScrollPaneSolver.java:82)
	at org.eclipse.draw2d.FigureCanvas.layoutViewport(FigureCanvas.java:325)
	at org.eclipse.draw2d.FigureCanvas.access$4(FigureCanvas.java:323)
	at org.eclipse.draw2d.FigureCanvas$3.notifyValidating(FigureCanvas.java:292)
	at org.eclipse.draw2d.UpdateManager.fireValidating(UpdateManager.java:143)
	at org.eclipse.draw2d.DeferredUpdateManager.performValidation(DeferredUpdateManager.java:214)
	at org.eclipse.draw2d.DeferredUpdateManager.performUpdate(DeferredUpdateManager.java:190)
	at org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(DeferredUpdateManager.java:44)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
	... 23 more
Re: getX and getY in CreateReferenceFeature [message #652836 is a reply to message #652095] Mon, 07 February 2011 04:26 Go to previous messageGo to next message
This seems to be a bug. Could you please open a bugzilla against Graphiti to
track this?
Michael
Re: getX and getY in CreateReferenceFeature [message #652854 is a reply to message #652836] Mon, 07 February 2011 06:48 Go to previous messageGo to next message
What means that exactly ?
[quote title=Could you please open a bugzilla against Graphiti to track this?l[/quote]
I should send a mail to the "mailing list" isn't it ?
Re: getX and getY in CreateReferenceFeature [message #652892 is a reply to message #652854] Mon, 07 February 2011 08:23 Go to previous messageGo to next message
Not quite. You should point your browser to https://bugs.eclipse.org/bugs/ ,
get a login for that page and file a new bug. The area to choose is
"Modeling", The Product "GMP", then choose component "Graphiti" from the
list.
For more details, there is a FAQ on bug reporting in Eclipse:
http://wiki.eclipse.org/Bug_Reporting_FAQ
Michael
Re: getX and getY in CreateReferenceFeature [message #652916 is a reply to message #652892] Mon, 07 February 2011 10:17 Go to previous message
OK.
Michael Wenz wrote on Mon, 07 February 2011 08:23
list.
Michael
Previous Topic:Permanently Selected Graphics Algorithms
Next Topic:Generative Graphiti
Current Time: Sat Jul 19 04:12:28 EDT 2025
Powered by FUDForum. Page generated in 0.03803 seconds
