Home » Modeling » M2T (model-to-text transformation) » [Xtend/XPand] Strange behaviour of checks(The checks do not trigger the types)
[Xtend/XPand] Strange behaviour of checks [message #652772] Sun, 06 February 2011 11:03 Go to next message
I wanted to validate my psmModel, before I generate any Code, but no constraint is being triggered.
Here my workflow:
<workflow>
	<property file="src/workflow/workflow.properties"/>
	<property name="model" value="topcased.conpract/src/model/ConpractPIM_Model.uml" />
	<property name="modelDetail" value="topcased.conpract/src/model/ConpractPIM_ModelDetail.uml" />
	<property name="psmModel" value="topcased.conpract/src/model/ConpractPSM_Model.uml" />
	<property name="PIMprofile" value="topcased.conpract/src/model/ConpractPIM.profile.uml" />
	<property name="PSMprofile" value="topcased.conpract/src/model/ConpractPSM.profile.ecore" />
	<property name="src-gen" value="src-gen" />
	<bean class="org.eclipse.xtend.typesystem.uml2.Setup" standardUML2Setup="true" />
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" platformUri=".."/>
	<!-- read the model -->
	<component class="org.eclipse.emf.mwe.utils.Reader">
		<uri value="platform:/resource/${model}" />
		<modelSlot value="model" />
	</component>
	<!-- PIM to PSM transformation -->
	<component class="org.eclipse.xtend.XtendComponent">
		<metaModel class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
			<profile value="platform:/resource/${PIMprofile}" />
		</metaModel>
		<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
			<metaModelFile value="platform:/resource/${PSMprofile}" />
		</metaModel>
		<metaModel class="org.eclipse.xtend.typesystem.uml2.UML2MetaModel" />
		<invoke value="extensions::pim2psmTransformation::transform(model)"/>
		<outputSlot value="psmModel" />
		<globalVarDef name="pim2psm" value="${pim2psm.properties}"/>
	</component>
	<!-- write psmModel to file -->
	<component id="write" class="org.eclipse.emf.mwe.utils.Writer">
		<useSingleGlobalResourceSet value="true"/>
		<modelSlot value="psmModel"/>
		<uri value="platform:/resource/${psmModel}" />
	</component>
	<!-- check the psmModel -->
	<component class="org.eclipse.xtend.check.CheckComponent">
		<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel" >
		</metaModel>
		<checkFile value="check::main" />
		<expression value="psmModel.eAllContents" />
		<!--<emfAllChildrenSlot value="psmModel" />-->
	</component>
	<!-- directory clean -->
	<component id="dirCleaner" class="org.eclipse.emf.mwe.utils.DirectoryCleaner" directory="${src-gen}"/>
	<!--  generate code -->
	<component id="generator" class="org.eclipse.xpand2.Generator">
		</metaModel>
		<expand
			value="template::main::main FOR psmModel" />
		<outlet path="${src-gen}" >
			<postprocessor
				class="org.hybridlabs.source.formatter.JavaImportBeautifier"
				organizeImports="true"
				format="false"/>
			<postprocessor
				class="org.eclipse.xpand2.output.JavaBeautifier"
				configFile="workflow/format.xml" />
		</outlet>
		<globalVarDef name="psm2code" value="${psm2code.properties}"/>
		<fileEncoding value="UTF-8" />
		<prSrcPaths value="${src-gen}" />
	</component>
</workflow>
Here my check file
import ConpractPSM;
context ConpractPSM::Entity ERROR "1":
	false;
context Object if this.metaType == Entity ERROR "2":
	false;
context Entity ERROR "3":
	false;
The strange thing is that the second constraint works, but I do not want to use this workaround if possible, but rather work with either the first or third constraint.
Does anyone know where the problem is?
Generating the code is no problem, and I can access the ConpractPSM types in Xtend and XPand without any problems. Within my check file the auto completion feature also works for the ConpractPSM metamodel.
Re: [Xtend/XPand] Strange behaviour of checks [message #652777 is a reply to message #652772] Sun, 06 February 2011 11:40 Go to previous messageGo to next message
from the docs ( http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. xpand.doc/help/Check_language.html)
emfAllChildrenSlot Name of a workflow slot that contains an EMF object, which has to be validated including all child elements that it contains. This property only works in conjunction with EMF based models.
expression This property allows to set a check expression for the validation component. This property only works in conjunction with non-EMF based models.
~ Christian
Re: [Xtend/XPand] Strange behaviour of checks [message #652778 is a reply to message #652777] Sun, 06 February 2011 11:54 Go to previous messageGo to next message
whether I use
or
the result is the same in both cases. Only the second constraint is getting triggerd.
So it actually should be working with emfAllChildrenSlot, since my psmModel is EMF based, but somehow it does not.
Well the metamodel of the psmModel is PSMprofile which is a EMF model, so psmModel could be called EMF based, right?
Re: [Xtend/XPand] Strange behaviour of checks [message #652780 is a reply to message #652778] Sun, 06 February 2011 12:08 Go to previous messageGo to next message
Maybe the problem is that you instantiate the metamodel more than once.
		</metaModel>
		</metaModel>
		</metaModel>
can you try something like this (instantiate once / reference where needed)
<bean id = "mm" class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
		</bean>
<metaModel idref="mm" />
if this does not help can you provide a minmal exampe that reproduces the problem? ecore/xmi/workflow?
~ Christian
[Updated on: Sun, 06 February 2011 12:12] by Moderator
Re: [Xtend/XPand] Strange behaviour of checks [message #652781 is a reply to message #652780] Sun, 06 February 2011 12:18 Go to previous message
it works now.
Once again you solved the problem Wink.
Thanks.
Muba
Previous Topic:passing parameters from one block to another
Next Topic:[XPand] questions in using AROUND
Current Time: Fri Jul 25 22:20:12 EDT 2025
Powered by FUDForum. Page generated in 0.24064 seconds
