Home » Modeling » OCL » OCLs for abstract classes and children(How to write OCLs for abstract classes and make the children be affected by the OCL too)
OCLs for abstract classes and children [message #652744] Sun, 06 February 2011 00:20 Go to next message
Hi, I have a metamodel which has a Metaclass named "Model" this class is going to be the root of everything. Then I have another metaclass called "NamedElement" this class is going to compose the "Model". "NamedElement"that its an Abstract Class and is father of all the rest of metaclasses In the model.
import ecore_0 : 'http://www.eclipse.org/emf/2002/Ecore#/';
package MAS : MAS = 'http://MAS/1.0'
class MASModel
property Elements#MAS : MASNamedElement[*] { composes };
class MASNamedElement { abstract }
attribute name : String[?];
property MAS#Elements : MASModel[1];
-- invariant UniqueName:
-- Achieves.allInstances()or Agent.allInstances() or Capabilities.allInstances()or
-- Goal.allInstances() or Possesses.allInstances() or Requires.allInstances() or Role.allInstances()->isUnique(name) ;
class MASElement extends MASNamedElement { abstract };
class MASRelation extends MASNamedElement { abstract }
property source : MASElement[?];
property target : MASElement[?];
class Requires extends MASRelation
invariant RequiresDestinationType:
self.target->forAll(a|a.oclIsKindOf(Capabilities));
invariant RequiresSourceType:
self.source->forAll(a|a.oclIsKindOf(Role));
class ScoredRelation extends MASRelation { abstract }
attribute score : ecore_0::EFloat[?] = '0' { transient };
class Achieves extends ScoredRelation
invariant AchievesDestinationType:
self.target->forAll(a|a.oclIsKindOf(Goal));
invariant AchievesSourceType:
class Possesses extends ScoredRelation
invariant PossessesDestinationType:
invariant PossessesSourceType:
self.source->forAll(a|a.oclIsKindOf(Agent));
class Role extends MASElement;
class Goal extends MASElement;
class Agent extends MASElement;
class Capabilities extends MASElement;
What I want is to write an OCL that checks for repeated names... normally it wold be like:
self.AllInstances->IsUnique(name); also I tried another thing where the OCL comments are...but doesn't work.
But I want to check for all the children of NamedElement(from Elements and Relations untill the end of file), and also there are no instances of NamedElement, so I'm having trouble defining this constraint for the ecore file and for the Audits in GMF.
Thanks in advance...
Re: OCLs for abstract classes and children [message #652745 is a reply to message #652744] Sun, 06 February 2011 02:00 Go to previous messageGo to next message
Perhaps it's related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=329389 ?
Cheers
/Eike
http://www.esc-net.de
Am 06.02.2011 06:22, schrieb Oscar Andres Fajardo F.:
> class MASModel
> invariant RequiresDestinationType: self.target->forAll(a|a.oclIsKindOf(Capabilities));
> invariant RequiresSourceType: self.source->forAll(a|a.oclIsKindOf(Role));
> invariant AchievesDestinationType: self.target->forAll(a|a.oclIsKindOf(Goal));
> invariant AchievesSourceType: self.source->forAll(a|a.oclIsKindOf(Role));
> invariant PossessesDestinationType: self.target->forAll(a|a.oclIsKindOf(Capabilities));
> invariant PossessesSourceType: self.source->forAll(a|a.oclIsKindOf(Agent));
Re: OCLs for abstract classes and children [message #652767 is a reply to message #652745] Sun, 06 February 2011 10:23 Go to previous messageGo to next message
It seems to be as you say.
Haven't you found an alternative solution?
Maybe a crazy idea might work for me (right now my thinking isn't very sharp, just a newbie).
thanks in advance
Re: OCLs for abstract classes and children [message #652789 is a reply to message #652767] Sun, 06 February 2011 13:13 Go to previous messageGo to next message
Am 06.02.2011 16:23, schrieb Oscar Andres Fajardo F.:
IIRC we rely on Ed to address this.
Cheers
/Eike
Re: OCLs for abstract classes and children [message #652790 is a reply to message #652744] Sun, 06 February 2011 13:49 Go to previous messageGo to next message
Hi Oscar
Your solution has a number of typos.
should be
NamedElement.allInstances()->isUnique(name)
but, as Eike points out, abstract classes don't work at present.
Hopefully fixed for Indigo, maybe even M6. Might even be fixed in
M5, but it's beyond my current testing horizon.
Ed Willink
> class MASModel
Re: OCLs for abstract classes and children [message #652810 is a reply to message #652790] Sun, 06 February 2011 23:19 Go to previous message
Thank you very much, both of you, you were very helpful and I hope this feature to be implemented very soon so I can do my IsUnique(name) thing...
Previous Topic:Hierarchy cast with oclAsType
Next Topic:Type of variable in "let" not agreeing with oclIsTypeOf/oclAsType
Current Time: Wed Jul 23 11:55:25 EDT 2025
Powered by FUDForum. Page generated in 0.02759 seconds
