Home » Eclipse Projects » GEF » Any suggestion to create flow chart diagram?
icon5.gif  Any suggestion to create flow chart diagram? [message #652666] Fri, 04 February 2011 20:03 Go to next message
Hi All,
I would like to create a diagram tool in Eclipse which is similar to flow chart diagram so that user can easily manage their data flow. I also want to keep the minimum set of the Eclipse plugins and make some modifications for the flow chart behaviors. Because it's time-consuming to create a new one from scratch, is there any Eclipse project or component doing this? Or how to build a tool which can create sequence diagram using some data?
Thanks in advance.
Charles
[Updated on: Tue, 08 February 2011 06:08] by Moderator
Re: Any suggestion to create flow chart diagram? [message #652677 is a reply to message #652666] Sat, 05 February 2011 02:54 Go to previous messageGo to next message
Hi Charles,
Try to look at Eclipse Java Workflow Tooling (http://www.eclipse.org/jwt/). I haven't used it personally, but it looks like something you may want.
Greets,
Kamil
Re: Any suggestion to create flow chart diagram? [message #652815 is a reply to message #652666] Mon, 07 February 2011 02:24 Go to previous messageGo to next message
Hi Charles,
You should have a look at all the BPM / BPMN stuff in order to draw flowchart diagrams. If you like it, you'll find a lot of editors and projects providing a diagram editor.
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Re: Any suggestion to create flow chart diagram? [message #766570 is a reply to message #652815] Thu, 15 December 2011 21:12 Go to previous message
Hi Mickael,
What do you mean by "all the BPM / BPMN stuff" ? I looked at JWT and BPMN plugins, but none seem to provide an extension point to their editor (maybe I missed it).
I am looking at a simple BPMN-like editor for my own Eclipse plugin.
Any advice or pointer where I should look at ?
Thanks!
Previous Topic:What is the best framework for developing a graphical editor?
Next Topic:[ZEST] Problem with number of node and also color of node
Current Time: Wed Jul 23 03:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.10096 seconds
