| How to print a report with PrintDialog [message #652588] |
Fri, 04 February 2011 11:03  |
in our RCP application we would like to print the report to a user-selected printer with a PrintDialog (source below).
The problem is that the printer is receiving data (spooler shows it, with the right size in bytes), but does not print in the end. Just with a PDF virtual printer we can obtain the task right.
What are we doing wrong?
Is it right to use a PDF OutputFormat if our goal is to send the report to a printer?
Thank you very much.
Vincenzo Caselli
RCP Vision
Our source:
EngineConfig config = new EngineConfig();
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
IReportEngine engine = factory.createReportEngine(config);
IReportRunnable design = null;
//Output Report
FileInputStream fs = new FileInputStream(reportDesignPath);
design = engine.openReportDesign(fs);
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
PDFRenderContext renderContext = new PDFRenderContext();
HashMap<String, PDFRenderContext> contextMap = new HashMap<String, PDFRenderContext>();
contextMap.put(EngineConstants.APPCONTEXT_PDF_RENDER_CONTEXT, renderContext);
task.setAppContext(contextMap);
IRenderOption options = new PDFRenderOption();
final ByteArrayOutputStream bos = new ByteArrayOutputStream();
options.setOutputStream(bos);
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
byte[] bytes = bos.toByteArray();
task.close();
engine.destroy();
//Print Report
PrintDialog pd = new PrintDialog(PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell());
PrinterData pdata = pd.open();
PrintService[] services = PrintServiceLookup.lookupPrintServices(null, null);
PrintService service = null;
for (int i = 0; i < services.length; i++) {
if (services[i].getName().equals(pdata.name)) {
service = services[i];
break;
DocPrintJob job = service.createPrintJob();
InputStream fin = new ByteArrayInputStream(bytes);
Doc doc = new SimpleDoc(fin, DocFlavor.INPUT_STREAM.AUTOSENSE, null);
PrintRequestAttributeSet pras = new HashPrintRequestAttributeSet();
pras.add(new Copies(1));
job.print(doc, pras);
doc.getStreamForBytes().close();
fin.close();
| Re: How to print a report with PrintDialog [message #652643 is a reply to message #652588] |
Fri, 04 February 2011 14:53   |
Vincenzo,
Checkout the birt viewer source code and look at the
org.eclipse.birt.report.utility.PrintUtility
org.eclipse.birt.report.utility.Printer
org.eclipse.birt.report.utility.BirtUtility (doPrintAction method)
classes. I believe the PrintUtility class shows printing in Postscript.
Jason
On 2/4/2011 11:03 AM, Vincenzo Caselli wrote:
> to a printer? Thank you very much.
> Vincenzo Caselli
> RCP Vision
> Our source:
> Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
> //Output Report
> contextMap.put(EngineConstants.APPCONTEXT_PDF_RENDER_CONTEXT ,
> renderContext);
> task.run();
> task.close();
> engine.destroy();
> //Print Report
> PrintDialog(PlatformUI.getWorkbench().getActiveWorkbenchWind ow().getShell());
> null);
> break;
> fin.close();
| Re: How to print a report with PrintDialog [message #653201 is a reply to message #653057] |
Tue, 08 February 2011 15:33  |
Vincenzo,
The print code I referenced earlier was for printing on the server. If
you want the print dialog to open automatically when the user opens the
pdf you could use iText which BIRT already uses. For example add the
com.lowagie.text plugin to your dependencies and put in code like this:
IRunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
//System.setProperty("java.io.tmpdir", "c:/temp/test/testsampledb");
config = new EngineConfig( );
//config.getAppContext().put(EngineConstants.WEBAPP_CLASSPAT H_KEY,
"C:/work/workspaces/2.5.1workspaces/BIRT -DE RE API
Samples/APIs/Reports/myimage.jar");
config.setBIRTHome(" C:\\birt\\birt-runtime-2_6_1\\birt-runtime-2_6_1\\ReportEngi ne ");
Platform.startup( config );
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
//Open the report design
design = engine.openReportDesign("Reports/Master.rptdesign");
//Create task to run and render the report,
//task.setProgressMonitor(new MyProgressMonitor());
task.setLocale(new Locale("en", "US"));
ByteArrayOutputStream baos= new ByteArrayOutputStream();
PDFRenderOption options = new PDFRenderOption();
options.setOutputStream(baos);
task.run();
task.close();
PdfReader js1 = new PdfReader(baos.toByteArray());
PdfCopyFields cpy = new PdfCopyFields( new FileOutputStream(
"output/resample/printdialog.pdf" ));
cpy.addDocument(js1);
cpy.addJavaScript( "this.print({bUI: true,bSilent: false,bShrinkToFit:
true});" );
cpy.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
finally
Platform.shutdown( );
System.out.println("Finished");
This will create a pdf that when opened should launch the print dialog
box. BTW I destroy the engine and shutdown the platform in this
example, but generally if the app is going to continue to run this is a
bad idea. If your app is RCP platform is already started so you do not
have to startup or shutdown. Get the engine once with synchronized
method and do not destroy it until your app shuts down. The engine can
be used to create many tasks.
Jason
On 2/8/2011 5:06 AM, Vincenzo Caselli wrote:
> Thanks Jason,
> I saw the BirtUtility and PrintUtility classes.
> They works with an inputStream and with
> HttpServletRequest/HttpServletResponse concepts.
> Unfortunately we have to handle a large variety of printers, not
> necessarily supporting Postscript) from an RCP client application.
> Is there a way to export a report to a generic printer (something like
> the Exporter of JasperReports, where you just set the printerService or
> let the user choose the printer) ?
> Thank you
> Regards
> Vincenzo
FUDForum. Page generated in 0.06766 seconds
