Home » Eclipse Projects » Remote Application Platform (RAP) » Update ui for OSGi-EventAdmin-Event(Receiving an Event from EventAdmin want to update the RAP UI)
Update ui for OSGi-EventAdmin-Event [message #652279] Thu, 03 February 2011 07:55 Go to next message
Hello!
I'm trying to show an Event received via OSGi-EventAdmin. Within my RCP-App everything works fine. Thanks to Tom Schindl and http://tomsondev.bestsolution.at/2011/01/03/enhanced-rcp-how -views-can-communicate/ .
Now in RAP I tried first following:
class ... {
Composite parent;
TableViewer tableViewer;
	protected Composite createEventCompositeInternal(final Composite parent) {
		this.parent = parent;
                this.tableViewer = new TableViewer(composite);
                BundleContext ctx = FrameworkUtil.getBundle(Client.class)
				.getBundleContext();
		EventHandler handler = new EventHandler() {
			public void handleEvent(final Event event) {
				UICallBack.activate("alarm");
				Thread bgThread = new Thread(createRunnable(event));
				bgThread.setDaemon(true);
				bgThread.start();
		Dictionary<String, String> properties = new Hashtable<String, String>();
		properties.put(EventConstants.EVENT_TOPIC, "events");
		ctx.registerService(EventHandler.class.getName(), handler, properties);
		return composite;
	private Runnable createRunnable(final Event event) {
		return new Runnable() {
			public void run() {
				// do some work...
				// schedule the UI update
				parent.getDisplay().asyncExec(new Runnable() {
					public void run() {
						// update the UI
						tableViewer.add(event.toString());
				// Deactivate the UI call-back
					public void run() {
						UICallBack.deactivate("alarm");
But this throws the following exception:
Log ErrorException while dispatching event org.osgi.service.event.Event [topic=events] to handler client.EventCompositeFacadeImpl$2@5ecfe500
java.lang.IllegalStateException: No context available outside of the request service lifecycle.
Looking in the RAP-FAQ for the IllegalstateException then tried UICallBack#runNonUIThreadWithFakeContext:
class...{
        Composite parent;
		Composite composite = new Composite(parent, SWT.NONE);
		composite.setLayout(new FillLayout());
		this.tableViewer.getTable().setHeaderVisible(true);
		this.tableViewer.getTable().setLinesVisible(true);
		this.tableViewer.setLabelProvider(new ColumnLabelProvider() {
			public String getText(Object element) {
				// return DateFormat.getDateTimeInstance().format(element);
				return element.toString();
		UICallBack.runNonUIThreadWithFakeContext(parent.getDisplay(),
						new Runnable() {
							public void run() {
								// do some work...
									public void run() {
										// update the UI
No Exception is thrown, but the UI does not automatically refresh. I have to first resize the browser window or the click in the tableviewer to see the new added events to the table.
Any suggestions?
Thanks for your help.
Stefan
Re: Update ui for OSGi-EventAdmin-Event [message #652288 is a reply to message #652279] Thu, 03 February 2011 08:36 Go to previous messageGo to next message
Hi Stefan,
in your second example the UICallBack is not activated at all, thus UI
HTH,
Ivan
On 2/3/2011 2:55 PM, Stefan wrote:
> Hello!
> class ... {
> Composite parent;
> @Override
> parent) {
> bgThread.start();
> String>();
> properties);
> return composite;
> public void run() {
> // do some work...
> public void run() {
> // update the UI
> public void run() {
> class...{
> Composite parent;
> @Override
> parent) {
> @Override
> // return
> UICallBack.runNonUIThreadWithFakeContext(parent.getDisplay() ,
> new Runnable() {
> public void run() {
> // do some work...
> Runnable() {
> public void run() {
> // update the UI
> String>();
> properties);
> Any suggestions?
> Stefan
Re: Update ui for OSGi-EventAdmin-Event [message #652324 is a reply to message #652279] Thu, 03 February 2011 10:19 Go to previous messageGo to next message
Short answer but very helpful! Very Happy
For others searching the same question here the running code:
				bgThread.start();
		properties.put(EventConstants.EVENT_TOPIC, "Events");
			public void run() {
						new Runnable() {
							public void run() {
								// do some work...
									public void run() {
										// update the UI
Re: Update ui for OSGi-EventAdmin-Event [message #652335 is a reply to message #652324] Thu, 03 February 2011 10:36 Go to previous message
Hi Stefan,
it's great that your code is running fine now. I will suggest to
deactivate the UICallBack when it is not needed anymore. In other words
- activate before you start the background thread, deactivate it when
the job is done.
Best,
Ivan
On 2/3/2011 5:19 PM, Stefan wrote:
> Short answer but very helpful! :d
> bgThread.start();
> properties);
> public void run() {
> new Runnable() {
> public void run() {
> // do some work...
> Runnable() {
> public void run() {
> // update the UI
Previous Topic:[RAP JUnit Test]: how to test a RAP application?
Next Topic:Slow RAP application start on Tomcat
Current Time: Wed Jul 23 18:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.03489 seconds
