Home » Language IDEs » PHP Development Tools (PDT) » pdt editor refuses to load a simple html file
pdt editor refuses to load a simple html file [message #651890] Tue, 01 February 2011 17:08 Go to next message
Hi everybody
PDT editor refuses to load a simple html file with folowing error:
Could not open the editor: Argument not valid
java.lang.IllegalArgumentException: Argument not valid
	at org.eclipse.swt.SWT.error(SWT.java:4064)
	at org.eclipse.swt.SWT.error(SWT.java:3998)
	at org.eclipse.swt.SWT.error(SWT.java:3969)
	at org.eclipse.swt.custom.StyledText.setStyleRanges(StyledText.java:9683)
	at org.eclipse.swt.custom.StyledText.replaceStyleRanges(StyledText.java:7705)
	at org.eclipse.jface.text.TextViewer.addPresentation(TextViewer.java:4803)
	at org.eclipse.jface.text.TextViewer.changeTextPresentation(TextViewer.java:4882)
	at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.applyTextRegionCollection(StructuredPresentationReconciler.java:893)
	at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.processDamage(StructuredPresentationReconciler.java:868)
	at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler$InternalListener.inputDocumentChanged(StructuredPresentationReconciler.java:271)
	at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.install(StructuredPresentationReconciler.java:600)
	at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.updateHighlighter(StructuredTextViewer.java:920)
	at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.setDocument(StructuredTextViewer.java:802)
	at org.eclipse.php.internal.ui.editor.PHPStructuredTextViewer.setDocument(PHPStructuredTextViewer.java:638)
	at org.eclipse.jface.text.source.SourceViewer.setDocument(SourceViewer.java:584)
	at org.eclipse.ui.texteditor.AbstractTextEditor.initializeSourceViewer(AbstractTextEditor.java:3873)
	at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:3401)
	at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:53)
	at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:432)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.createPartControl(StructuredTextEditor.java:1453)
	at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.createPartControl(PHPStructuredEditor.java:2243)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2863)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
	at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
	at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
	at org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAction(MainActionGroup.java:330)
	at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
	at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
	at org.eclipse.jface.util.OpenStrategy$1.mouseSelectItem(OpenStrategy.java:429)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:365)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
I open the file in other editors like kate, quanta+ without any problem.
Did someone experienced that ?
Re: pdt editor refuses to load a simple html file [message #699831 is a reply to message #651890] Fri, 22 July 2011 08:07 Go to previous message
Same Problem here.
Has anyone a solution for this?
€dit:
Solution on my Eclipse was Restore Defaults in "PHP->Editor->Syntax Coloring" Wink
[Updated on: Fri, 22 July 2011 08:14] by Moderator
Previous Topic:Remote systems file asociation
Next Topic:html5 tags in .php do not validate without a doctype
Current Time: Sat Jul 26 08:59:39 EDT 2025
Powered by FUDForum. Page generated in 0.04218 seconds
