Home » Modeling » Epsilon » Execution of ETL transformations from Java code
Execution of ETL transformations from Java code [message #651865] Tue, 01 February 2011 15:17 Go to next message
Originally posted by: Juan.deLara.uam.es
I would like to execute an ETL transformation within Java. In previous
versions of Epsilon, I used to call method parse() from interface
IEolModule, but in this new version this has changed. Also, the example
on the web page seems to be using the old version, right?
Could you please provide a code snippet to perform such execution?
thanks!
juan.
Re: Execution of ETL transformations from Java code [message #651868 is a reply to message #651865] Tue, 01 February 2011 15:25 Go to previous message
Hi Juan,
I've checked out the org.eclipse.epsilon.examples.standalone project from the SVN and the ETL example seems to be working fine with the latest version of Epsilon. Would it perhaps help to do a fresh check-out of the source from the SVN?
Dimitris
Previous Topic:Epsilon Mac problem
Next Topic:[HUTN] Strings with fullstop?
Current Time: Sun Jul 27 06:40:15 EDT 2025
Powered by FUDForum. Page generated in 0.03100 seconds
