Home » Eclipse Projects » Rich Client Platform (RCP) » drawing arrow lines between swt components/jface viewers
drawing arrow lines between swt components/jface viewers [message #651638] Mon, 31 January 2011 19:44 Go to next message
hi,
i've a multi page editor part with a scrolled composite and have 2
tree viewers along with few labels on it. and want to draw mapping
lines to interconnect them.
the requirement is :-
-- if i drag mouse from one tree viewer item to drop on a swt label or
on another tree viewer item, it should draw mapping lines with arrow
head on the destination.
--also the tree items may connect to other items in the same tree
But i'm not sure how to start with it. can you please give me some
pointers!
should i first make a dragdetectlistener for each control for the
mouse drag part?
should i pick zest / draw2d / gef?
i'm totally confused now. appreciate any help...
thanks,
ani
Re: drawing arrow lines between swt components/jface viewers [message #653777 is a reply to message #651638] Fri, 11 February 2011 01:48 Go to previous messageGo to next message
I think you can create a composite with Sash for ur Left and Right hand side components and put them on a canvas then u can use draweLine API to drawl links on SWT canvas.
You can always go to GEF connection anchors and that would give you more options .
Re: drawing arrow lines between swt components/jface viewers [message #654077 is a reply to message #653777] Sun, 13 February 2011 21:06 Go to previous messageGo to next message
hello,
thanks for the response.
but i think drawline api draws a static line whereas i want a movable and resizable line which moves when i move my components.
do u have any idea?
thanks,
Re: drawing arrow lines between swt components/jface viewers [message #1240821 is a reply to message #654077] Fri, 07 February 2014 00:22 Go to previous message
Hi Ani,
You got any solution for this problem?
Previous Topic:dynamic ContributionItems in toolbar are ignored completely
Next Topic:Source Provider State ignored by Handler
Current Time: Sat Jul 26 08:06:22 EDT 2025
Powered by FUDForum. Page generated in 0.36392 seconds
