Home » Eclipse Projects » DTP » Unable to create a new database connection in DSE
Unable to create a new database connection in DSE [message #651114] Thu, 27 January 2011 14:55 Go to next message
I've added a Postgresql 8.4 driver definition, but DSE fails to create a DB connection when I use the dialog. I input the appropriate values, and even use test connection, which reports "ping successful!", but when I click finish, it just silently fails. No new connection is added to DSE.
I'm using DTP 1.8.1 on 64 bit Eclipse Version: 3.6.1 Build id: M20100909-0800 on Linux, Fedora 13.
One thing I noticed that if I press next instead of finish, I'm shown the summary screen, which shows "Name" and "Description" at the top, but they're blank. I can find no place to add these properties anywhere in the previous dialog.
Daniel
Re: Unable to create a new database connection in DSE [message #651628 is a reply to message #651114] Mon, 31 January 2011 18:19 Go to previous messageGo to next message
Hi Daniel
That's definitely odd. I don't have any way of testing the 64 bit
version of Eclipse here, nor do I have any Postgres databases to test
against.
The Postgres support is located in the enablement plugins:
* org.eclipse.datatools.enablement.postgresql
* org.eclipse.datatools.enablement.postgresql.dbdefinition
* org.eclipse.datatools.enablement.postgresql.ui
The wizard doesn't seem to be contributing anything beyond what's in the
generic UI - uid, pwd, url, database name. So you might start with
what's there and see if you can get anywhere.
--Fitz
Daniel Ceregatti wrote:
> Daniel
Re: Unable to create a new database connection in DSE [message #651629 is a reply to message #651114] Mon, 31 January 2011 18:21 Go to previous messageGo to next message
Is it by chance that you're using a 32 bit JDBC driver on a 64-bit
machine and it's having issues that way? Not knowing how 64-bit OSes
would affect Eclipse and therefore DTP really hampers my knowing what
might happen there.
Can you write code against the Postgres JDBC driver outside of DTP that
can connect to a database successfully?
It doesn't seem that the driver would be the issue however based on what
you've said here.
--Fitz
> Daniel
Re: Unable to create a new database connection in DSE [message #651641 is a reply to message #651114] Mon, 31 January 2011 20:39 Go to previous message
I've figured out the problem:
DSE -> "Database Connections" -> (Right click) New
DSE -> "New connection profile" (icon in the DSE view toolbar)
The latter has a page for adding the Name and Description, the former does not. Once I used the latter, I was able to add the new connection.
Daniel
Previous Topic:Usage of DTP - Questions
Next Topic:Oracle DB URL failure, must have slash
Current Time: Fri Jul 25 22:55:15 EDT 2025
Powered by FUDForum. Page generated in 0.03990 seconds
