Home » Eclipse Projects » Rich Client Platform (RCP) » How to use SWING component in RCP(Embedding swing compoennts inside RCP)
How to use SWING component in RCP [message #544213] Thu, 01 July 2010 23:22 Go to next message
I am wandering which is the best way to integrate swing components inside an RCP.
What I need to do for instance, is to show in a view a dynamic graph created from a stream of values using a swing library like JChart2D.
For that I need to instantiate a swing container in my view at least.
Which is the best solution to this problem?
As an alternative, I wander if there is a library like JChart2D for SWT.
Thank you.
Re: How to use SWING component in RCP [message #544231 is a reply to message #544213] Fri, 02 July 2010 01:51 Go to previous messageGo to next message
> inside an RCP.
> created from a stream of values using a swing library like JChart2D. For
You might want to start with the SWT_AWT bridge, see also the article
http://www.eclipse.org/articles/article.php?file=Article-Swi ng-SWT-Integration/index.html
In more advanced use-cases it is generally recommended to use
the Albireo bridge:
http://www.eclipse.org/albireo/
You may also have a look at
http://swik.net/swt/AWT,+Swing+and+Java2D+Integration
> Thank you.
We have quite good experience with JFreeChart
http://www.jfree.org/jfreechart/
but I don't know whether this covers your requirements. It might also
be worth to use the charts support provided by the Birt project, see e.g.
http://www.eclipse.org/articles/article.php?file=Article-BIR TChartEngine/index.html
HTH & Greetings from Bremen,
Daniel Krügler
Re: How to use SWING component in RCP [message #544398 is a reply to message #544213] Fri, 02 July 2010 10:46 Go to previous messageGo to next message
Thank for your help Daniel.
I will investigate the usage of the SWT_AWT bridge and albireo.
I knew about JFreeChart that is probably the most widely used chart library in java. After a short investigation we preferred JChart2D because it is lighter when managing a large stream of values in real time.
I have just found SWTChart that could be used avoiding the need of embedding AWT/SWING into SWT. It could be worst to givi it a shot.
Re: How to use SWING component in RCP [message #645866 is a reply to message #544398] Mon, 20 December 2010 15:56 Go to previous messageGo to next message
I see that your topic is very similar to my problem and thought maybe you could help out.
I have a swing form I created in netbeans and would like to port it to an eclipse plugin. Is there any way to create a container to hold it as is?
Re: How to use SWING component in RCP [message #648802 is a reply to message #645866] Fri, 14 January 2011 09:43 Go to previous messageGo to next message
> you could help out.
> Thanks
I recommend to google for the Albireo project which provides an
excellent SWT control wrapper for Swing classes.
Daniel Krügler
Re: How to use SWING component in RCP [message #651621 is a reply to message #648802] Mon, 31 January 2011 17:41 Go to previous messageGo to next message
Now that Eclipse has abandoned the Albireo project are there any updated recommendations? What should projects which foolishly depended on this code migrate to?
Tom
Re: How to use SWING component in RCP [message #651735 is a reply to message #651621] Tue, 01 February 2011 08:02 Go to previous messageGo to next message
> code migrate to?
If you don't need new functionality, then you're probably fine. But you
have full access to the code from that project if you only need to tweak
it. If you need more than that, you would probably go back to the
SWT_AWT bridge.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to use SWING component in RCP [message #727363 is a reply to message #544398] Wed, 21 September 2011 01:18 Go to previous message
Hello Caproni
we are also planning to use jchart2d for run time charting.
Were you able to use it successfully? if so which one you used SWT_AWT bridge or albireo?
Please do share your experience on jchart2d and on bridges, sure it will save a lot of time for me
regards
Raghu
[Updated on: Wed, 21 September 2011 01:22] by Moderator
Previous Topic:Change the loading Workbench Message
Next Topic:Progress Monitor in headless RCP
Current Time: Sat Jul 26 17:05:31 EDT 2025
Powered by FUDForum. Page generated in 0.05302 seconds
