Home » Eclipse Projects » Memory Analyzer » Error creating heap dump
Error creating heap dump [message #651463] Mon, 31 January 2011 04:03 Go to next message
Hi All,
I have installed MAT and MAT charts on Eclipse Helios which is a 64 bit one.My JDK is also 64 bit one.
When i try to acquire a heap dump of my process using HPROF jmap dump provider i get the following error.
Error creating heap dump. jmap exit code = 1
7976: Unable to attach to 64-bit process
Please help me to resolve the error.
Thanks and Regards,
Saurav
Re: Error creating heap dump [message #651529 is a reply to message #651463] Mon, 31 January 2011 10:04 Go to previous messageGo to next message
Hi Saurav,
Could you provide any more details of your environment, eg what platform are you running on (Windows/Linux) and what JRE/JDK are you using for Eclipse/MAT and the target Java application?
Re: Error creating heap dump [message #651539 is a reply to message #651463] Mon, 31 January 2011 10:29 Go to previous messageGo to next message
It may be that we try to trigger the heap dump using the wrong JDK. Can you try to explicitly configure the 64 bit one to be used? You can do this in the "Aquire Heap Dump Dialog" if you click the "Configure ..." button.
Let me know if this helps.
Krum
Re: Error creating heap dump [message #651697 is a reply to message #651463] Tue, 01 February 2011 05:40 Go to previous message
Thanks folks for the replies.
Due to time constraints i moved back to a 32 bit system and its working fine there.
I will check the 64 bit configuration though and will let you know.
cheers,
Saurav
Previous Topic:Stack trace for memory accumulation points
Next Topic:Heapdump is too small
Current Time: Fri Jul 18 23:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.03762 seconds
