Running Report against different copies of a database [message #651453] |
Mon, 31 January 2011 00:52  |
I need to create reports where in development a development database is used. When deployed to production the database name (only) will be differant. I need to deploy the same report to both differant machines and/ or differant environments. We have the situation where each client has their own copies of the database - a development, a test, a support and production each of which have unique names. eg AJAX_dev, AJAX_test, AJAX_support and AJAX_prod for comany AJAX and a similar set for ACME say. All of these on the same server.
How do you set the report up so that as you run the report it selects the database? All reports are run via run-time BIRT to PDF. There is no database name field etc here
Thanks in advance
Chris
FUDForum. Page generated in 1.04462 seconds
