Home » Eclipse Projects » Eclipse Platform » EFS Vs ResourceMapping
EFS Vs ResourceMapping [message #651032] Thu, 27 January 2011 09:19 Go to next message
I haven't used EFS (Eclipse File System) or ResourceMapping myself, but have only read about them. To me, both appear to solve the same problem. Could anyone please explain to me whats the difference between the two and when one would use any of them?
Sorry if it was a naive question.
Thanks and regards,
Nirmal
[Updated on: Thu, 27 January 2011 09:27] by Moderator
Re: EFS Vs ResourceMapping [message #651516 is a reply to message #651032] Mon, 31 January 2011 09:03 Go to previous messageGo to next message
You can use your own implementation of EFS if your files are stored somewhere else than local filesystem. EFS is an abstract file system API. Eclipse uses it to hide implementation details about what file system is used to store data in the workspace. In other words, having an EFS implementation for CVS you could work with resources stored in a CVS server in the same way like they were regular files in the workspace. You can find more examples of EFS implementation here.
A resource mapping supports the transformation of a logical model object into its underlying file system resources. So if your files represent entities which you would like to use in your app, then you should use ResourceMappings to do the job. An example of such mapping can be found in JDT: it has a notion of Java class, package, java projects etc which can be transformed into files when needed.
Here is how I see it:
* Your logical model
* ResourceMapping (translates logical model to resoures)
* Resources
* EFS (abstract API)
* EFS implemenation (eg. local file system but can be replaces with something else)
Re: EFS Vs ResourceMapping [message #651612 is a reply to message #651516] Mon, 31 January 2011 16:26 Go to previous messageGo to next message
That makes sense for me now. Thanks Tomasz for your explanation.
Nirmal
Re: EFS Vs ResourceMapping [message #674177 is a reply to message #651516] Wed, 25 May 2011 22:54 Go to previous messageGo to next message
I am aware of EFS. But what is resource mapping ? Are you talking about stuff we do by mapping logical entities to files using adapters ?
Ashwani Kr Sharma
[Updated on: Wed, 25 May 2011 22:54] by Moderator
Re: EFS Vs ResourceMapping [message #674311 is a reply to message #674177] Thu, 26 May 2011 09:29 Go to previous message
ResourceMapping is a slightly different API than just adapter. See http://www.eclipse.org/eclipse/platform-team/team3.1/logical-physical-mappings.html
PW
Previous Topic:How to redirect key presses to another shell?
Next Topic:Is it possible to add eclipse main menu group
Current Time: Fri Jul 25 20:45:15 EDT 2025
Powered by FUDForum. Page generated in 0.03863 seconds
