Home » Modeling » BPEL Designer » Error while trying the HelloWorld tutorial(Getting org.xml.sax.SAXParseException error while editing deploy.xml)
Error while trying the HelloWorld tutorial [message #651455] Mon, 31 January 2011 02:13 Go to next message
I have tried the HelloWorld toturial as given in
http://people.apache.org/~vanto/HelloWorld-BPELDesignerAndOD E.pdf
On page 15,it is specified to edit the deploy.xml and edit the "Inbound Interfaces" . We need to select "HelloWorldProcessPort" as Associated Port for the client. However I am not able to see "HelloWorldProcessPort" in the drop down box. When I checked the console for error it is giving the following error:
Pl suggest what to try!
!MESSAGE Warning in platform:/resource/ODE_Test/HelloWorld.bpel [1:1] http://www.w3.org/TR/xml-schema-1#SchemaLocation?http://docs .oasis-open.org/wsbpel/2.0/process/executable
!STACK 0
org.xml.sax.SAXParseException: http://www.w3.org/TR/xml-schema-1#SchemaLocation?http://docs .oasis-open.org/wsbpel/2.0/process/executable
at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseExc eption(Unknown Source)
at org.apache.xerces.util.ErrorHandlerWrapper.warning(Unknown Source)
at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
at org.apache.xerces.impl.xs.XMLSchemaLoader.processExternalHin ts(Unknown Source)
at org.apache.xerces.impl.xs.XMLSchemaValidator.reset(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.configurePipeli ne(Unknown Source)
at org.apache.xerces.parsers.XIncludeAwareParserConfiguration.c onfigurePipeline(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.eclipse.bpel.model.resource.BPELReader.read(BPELReader.j ava:286)
at org.eclipse.bpel.model.resource.BPELReader.read(BPELReader.j ava:313)
at org.eclipse.bpel.model.resource.BPELResourceImpl.doLoad(BPEL ResourceImpl.java:150)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.bpel.apache.ode.deploy.ui.util.DeployUtils.loadB PEL(DeployUtils.java:145)
at org.eclipse.bpel.apache.ode.deploy.ui.editors.ODEDeployMulti PageEditor$2.visit(ODEDeployMultiPageEditor.java:248)
at org.eclipse.core.internal.resources.Resource$2.visit(Resourc e.java:112)
at org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:64)
at org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:74)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:110)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:94)
at org.eclipse.bpel.apache.ode.deploy.ui.editors.ODEDeployMulti PageEditor.populateModel(ODEDeployMultiPageEditor.java:244)
at org.eclipse.bpel.apache.ode.deploy.ui.editors.ODEDeployMulti PageEditor.createModel(ODEDeployMultiPageEditor.java:221)
at org.eclipse.bpel.apache.ode.deploy.ui.editors.ODEDeployMulti PageEditor.init(ODEDeployMultiPageEditor.java:110)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2863)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2711)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2682)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:747)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.NewODEDeployWi zard$2.run(NewODEDeployWizard.java:139)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:388)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 1008)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.NewODEDeployWi zard.performFinish(NewODEDeployWizard.java:91)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
EXECEPTION: null
EXECEPTION: null
EXECEPTION: null
Re: Error while trying the HelloWorld tutorial [message #651653 is a reply to message #651455] Tue, 01 February 2011 00:10 Go to previous messageGo to next message
Hi Nihita,
I'm sorry but I'm unable to reproduce this problem with the current build. Can you tell me which version of eclipse and the BPEL editor plug-ins you are using? If possible, please post your eclipse configuration here (Help->About Eclipse->Installation Details->Configuration). In the meantime, I'll go through the tutorial again step-by-step to see if I missed anything.
Bob
Re: Error while trying the HelloWorld tutorial [message #651713 is a reply to message #651653] Tue, 01 February 2011 06:52 Go to previous messageGo to next message
Thanks for your reply. I will also try again.
In my run configuration I have changed the Xms parameters to avoid the OutofMemory PermSpace error.
I am using Eclipse 3.6 and Java 1.6 - Both 64 bit. BPEL I Plug-in is from the BPEL Update site ( the latest version)
My configuration is:
*** Date: Tuesday, February 1, 2011 5:19:11 PM India Standard Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20100909-0800
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
-showsplash
-launcher
E:\ECLIPSE-EE-3.6\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
E:\ECLIPSE-EE-3.6\eclipse\plugins/org.eclipse.equinox.launch er.win32.win32.x86_64_1.1.1.R36x_v20100810\eclipse_1309.dll
-startup
E:\ECLIPSE-EE-3.6\eclipse\plugins/org.eclipse.equinox.launch er_1.1.0.v20100507.jar
-exitdata
5bc_58
-product
org.eclipse.epp.package.jee.product
-vm
C:\Windows\system32\javaw.exe
eclipse.home.location=file:/E:/ECLIPSE-EE-3.6/eclipse/
eclipse.launcher=E:\ECLIPSE-EE-3.6\eclipse\eclipse.exe
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=epp.package.jee
eclipse.product=org.eclipse.epp.package.jee.product
eclipse.startTime=1296560919730
eclipse.vm=C:\Windows\system32\javaw.exe
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=E:\ECLIPSE-EE-3.6\eclipse\plugins/org.eclips e.equinox.launcher_1.1.0.v20100507.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\Users\admin\AppData\Local\Temp\
java.library.path=C:\Windows\system32;.;C:\Windows\Sun\Java\ bin;C:\Windows\system32;C:\Windows;C:\Program Files (x86)\MiKTeX 2.8\miktex\bin;D:\DevSuiteHome_1\BIN\bin;C:\Windows\system32 ;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\Win dowsPowerShell\v1.0\;C:\Program Files\Java\jdk1.6.0_23\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_23-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_23
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=19.0-b09
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=e:\ECLIPSE-EE-3 .6\eclipse\plugins\org.eclipse.platform_3.6.1.v201009090800\ splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Windows 7
os.version=6.1
osgi.arch=x86_64
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=E:\ECLIPSE-EE-3.6\eclipse\configuration\org .eclipse.osgi\bundles
osgi.configuration.area=file:/E:/ECLIPSE-EE-3.6/eclipse/conf iguration/
osgi.framework=file:/e:/ECLIPSE-EE-3.6/eclipse/plugins/org.e clipse.osgi_3.6.1.R36x_v20100806.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.1.R36x_v20100806
osgi.install.area=file:/E:/ECLIPSE-EE-3.6/eclipse/
osgi.instance.area=file:/E:/Bpel/
osgi.instance.area.default=file:/C:/Users/admin/workspace/
osgi.logfile=E:\Bpel\.metadata\.log
osgi.manifest.cache=E:\ECLIPSE-EE-3.6\eclipse\configuration\ org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=e:\ECLIPSE-EE-3.6\eclipse\plugins\org.ec lipse.platform_3.6.1.v201009090800\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=e:\ECLIPSE-EE-3.6\eclipse\plugins
osgi.tracefile=E:\Bpel\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=64
sun.boot.class.path=C:\Program Files\Java\jre6\lib\resources.jar;C:\Program Files\Java\jre6\lib\rt.jar;C:\Program Files\Java\jre6\lib\sunrsasign.jar;C:\Program Files\Java\jre6\lib\jsse.jar;C:\Program Files\Java\jre6\lib\jce.jar;C:\Program Files\Java\jre6\lib\charsets.jar;C:\Program Files\Java\jre6\lib\modules\jdk.boot.jar;C:\Program Files\Java\jre6\classes
sun.boot.library.path=C:\Program Files\Java\jre6\bin
sun.cpu.endian=little
sun.cpu.isalist=amd64
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=
user.country=US
user.dir=E:\ECLIPSE-EE-3.6\eclipse
user.home=C:\Users\admin
user.language=en
user.name=admin
user.timezone=Asia/Calcutta
user.variant=
Re: Error while trying the HelloWorld tutorial [message #651813 is a reply to message #651713] Tue, 01 February 2011 12:17 Go to previous messageGo to next message
Hello: I've tried this again and am getting the same error. However this time I observed some more exceptions appearing in the console of the eclipse ( the parent one from where the new config executes ). I am attached the errors encountered:
!SESSION 2011-02-01 22:29:24.924 -----------------------------------------------
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data C:\bpel/../runtime-New_configuration -dev file:C:/bpel/.metadata/.plugins/org.eclipse.pde.core/New_con figuration/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.bpel.model 2 0 2011-02-01 22:29:30.337
!STACK 0
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1429)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbe nch.java:1567)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
!ENTRY org.eclipse.osgi 2 1 2011-02-01 22:29:32.475
!MESSAGE NLS unused message: add_script_load_bp in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: bp_conditional in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-02-01 22:29:32.491
!MESSAGE NLS unused message: bp_conditonal in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: bp_entry_and_exit in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-02-01 22:29:32.506
!MESSAGE NLS unused message: bp_entry_only in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: bp_exit_only in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: bp_hit_count in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: bp_line_number in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: bp_suspend_vm in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: breakpoint_configuration in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-02-01 22:29:32.523
!MESSAGE NLS unused message: connect in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: connector in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: connector_properties in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: creating_script_load_bp in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: enable_hit_count in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: enter_new_hit_count in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: exception_occurred_setting_bp_properties in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-02-01 22:29:32.538
!MESSAGE NLS unused message: hit_count_must_be_positive in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: no_description_provided in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: scripts in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: select_javascript_file in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: set_bp_hit_count in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: suspend_target in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-02-01 22:29:32.554
!MESSAGE NLS unused message: suspend_thread in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: the_argument_0_is_not_valid in: org.eclipse.wst.jsdt.debug.internal.ui.messages
!MESSAGE NLS unused message: osgi.nls.warnings in: org.eclipse.wst.jsdt.debug.internal.ui.messages
InitFunctions took: 171ms
!ENTRY org.eclipse.ui 4 0 2011-02-01 22:31:22.691
!MESSAGE Unable to create editor ID org.eclipse.bpel.ui.bpeleditor: An unexpected exception was thrown.
!STACK 0
at org.eclipse.bpel.ui.util.BPELEditModelClient.getExtensionsFi le(BPELEditModelClient.java:147)
at org.eclipse.bpel.ui.BPELMultipageEditorPart.loadModel(BPELMu ltipageEditorPart.java:1142)
at org.eclipse.bpel.ui.BPELMultipageEditorPart.createDesignPage (BPELMultipageEditorPart.java:425)
at org.eclipse.bpel.ui.BPELMultipageEditorPart.createPages(BPEL MultipageEditorPart.java:481)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:670)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.handleDeferredEvents(PartS tack.java:1222)
at org.eclipse.ui.internal.LayoutPart.deferUpdates(LayoutPart.j ava:400)
at org.eclipse.ui.internal.PartSashContainer.handleDeferredEven ts(PartSashContainer.java:1409)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1420)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1410)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1384)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1448)
at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$8$2. run(ProcessPage.java:863)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDia log2.run(RefactoringWizardDialog2.java:330)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPer formFinish(RefactoringWizard.java:573)
at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFi nish(UserInputWizardPage.java:153)
at org.eclipse.ltk.ui.refactoring.resource.DeleteResourcesWizar d$DeleteResourcesRefactoringConfigurationPage.performFinish( DeleteResourcesWizard.java:151)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFini sh(RefactoringWizard.java:646)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDia log2.okPressed(RefactoringWizardDialog2.java:454)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:4 72)
at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n$1.run(RefactoringWizardOpenOperation.java:180)
at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.run(RefactoringWizardOpenOperation.java:192)
at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.run(RefactoringWizardOpenOperation.java:115)
at org.eclipse.ltk.internal.ui.refactoring.actions.DeleteResour cesHandler.execute(DeleteResourcesHandler.java:40)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma ndInContext(HandlerService.java:270)
at org.eclipse.ui.internal.ide.actions.LTKLauncher.runCommand(L TKLauncher.java:95)
at org.eclipse.ui.internal.ide.actions.LTKLauncher.openDeleteWi zard(LTKLauncher.java:47)
at org.eclipse.ui.actions.DeleteResourceAction.run(DeleteResour ceAction.java:481)
at org.eclipse.jdt.internal.ui.refactoring.reorg.DeleteAction.r un(DeleteAction.java:162)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
!ENTRY org.eclipse.ui 2 2 2011-02-01 22:31:22.739
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@5b4af0fe from part: org.eclipse.ui.internal.ErrorEditorPart@5b4af0fe
at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList. java:40)
at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:375)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:610)
Could not create editpart for model: null
java.lang.Exception: Stack trace
at java.lang.Thread.dumpStack(Unknown Source)
at org.eclipse.wst.wsdl.ui.internal.asd.design.editparts.ASDEdi tPartFactory.createEditPart(ASDEditPartFactory.java:91)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:626)
at org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.init ializeGraphicalViewer(ASDMultiPageEditor.java:317)
at org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.crea tePages(ASDMultiPageEditor.java:155)
at org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor .createPages(InternalWSDLMultiPageEditor.java:406)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1439)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:541)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 06)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:120 )
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:83)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:269)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:278)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:71 )
at org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:631)
at org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:206)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:15 95)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:261)
!ENTRY org.eclipse.ui 4 0 2011-02-01 22:31:27.981
!MESSAGE Unable to create editor ID org.eclipse.wst.wsdl.ui.internal.WSDLEditor: null argument:
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.wst.wsdl.ui.internal.asd.design.editparts.ASDEdi tPartFactory.createEditPart(ASDEditPartFactory.java:93)
!ENTRY org.eclipse.ui 2 2 2011-02-01 22:31:27.981
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@4f8b56d0 from part: org.eclipse.ui.internal.ErrorEditorPart@4f8b56d0
EXECEPTION: null
EXECEPTION: null
EXECEPTION: null
EXECEPTION: null
EXECEPTION: null
EXECEPTION: null
EXECEPTION: null
!ENTRY org.eclipse.bpel.model 2 0 2011-02-01 22:42:00.130
!STACK 0
Re: Error while trying the HelloWorld tutorial [message #651914 is a reply to message #651455] Tue, 01 February 2011 23:12 Go to previous messageGo to next message
Also I have observed that I get this error only when I open deploy.xml i.e when i double click it or i specify Open with->Deployment Descripter. Looks like its a xml parsing error. Any specific jar file to check for this?
Re: Error while trying the HelloWorld tutorial [message #652087 is a reply to message #651914] Wed, 02 February 2011 11:23 Go to previous messageGo to next message
This is the xerces parser from apache. Can you tell me which version of this jar you are using?
BTW, the "Features" and all following sections from your Help->About->Configuration was missing in the previous post - this lists all of the jars and their version #s and would really be helpful in debugging this problem.
It's also possible that there is some kind of file encoding issue involved. Open your Eclipse Preferences dialog and type "encoding" in the filter text box. You should have UTF-8 or ISO Latin-1 for XML file types.
Re: Error while trying the HelloWorld tutorial [message #652211 is a reply to message #652087] Thu, 03 February 2011 02:00 Go to previous messageGo to next message
Hello: Please find below the config of my eclipse.
I checked the Windows preference->encoding. It is ISO 10646/Unicode(UTF-8)
Looking forward for your reply.
*** Date: Thursday, February 3, 2011 12:31:48 PM India Standard Time
win32
-ws
win32
-arch
x86_64
-showsplash
-launcher
-name
Eclipse
--launcher.library
-startup
-exitdata
1980_58
-product
-vm
eclipse.startTime=1296716210706
-Xms40m
-Xmx512m
-jar
equinox.use.ds=true
file.separator=\
line.separator=
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
org.eclipse.update.resolution_url=
os.arch=amd64
os.name=Windows 7
os.version=6.1
osgi.arch=x86_64
osgi.nl=en_US
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.desktop=windows
sun.os.patch.level=
user.country=US
user.language=en
user.name=admin
user.variant=
*** Features:
org.eclipse.cvs (1.2.0.v20100427-7B77FKt90GE5h0SBT5FV9A01911) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.8.1.v20100618-26-311A16321A3557) "Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user (1.8.1.v20100618-37D-7733L3D753L7BBF) "Data Tools Platform Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature (1.8.1.v20100618-7C7b8hEt1ZvtiLkdlO7BVoL_wm6) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.core.feature (1.8.1.v20100618-7B7C79CcNBGKBgIZCSNS) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.8.1.v20100618-4107w3121151A1A53) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.8.1.v20100618-7H7C7ACcNBHBBkHeGSMd) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.8.1.v20100618-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.8.1.v20100618-77778eBmKDNOMgJvJ8Of7QBR) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.8.1.v20100618-7J8x7FBWwUL6z-2z-fcrYC2s55KI) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.8.1.v20100618-67C1AqGBJVKbHlH1GU7QBR) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.8.1.v20100618-7F47SFC7sRbrSZope9vW) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.8.1.v20100618-540AkF78Y7VCOCQDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.8.1.v20100618-4-29oB56N5N7L6PAQ) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.8.1.v20100618-2-07w31211518181A) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.8.1.v20100618-542AkF79P7QCP9SDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.8.1.v20100618-546AkF78Y7R9PAX77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.8.1.v20100618-3328s73533G4A5B63) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.8.1.v20100618-7A7T78DZRDKDDdFyFiKD) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.8.1.v20100618-548cAkF79P7UBMATEE) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.8.1.v20100618-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.8.1.v20100618-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.8.1.v20100618-541AkF79P7N8NAQ77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.8.1.v20100618-7E45F9NiNWvOOXxPdVT) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.intro (1.8.1.v20100618-26-7w312116392911) "Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.8.1.v20100618-77078CcNBGKBZI_FcRd) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.8.1.v20100618-7A-2F7RZHLz-HvNlPz-Uk) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.8.1.v20100618-7N7y7AFDrhoZFIFUNhpFwckfaS-S) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.8.1.v20100618-622BgJ9CR9XFcEWLP) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.datatools.sqltools.doc.user (1.8.1.v20100618-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools User Documentation"
org.eclipse.draw2d (3.6.1.v20100908-1100-4507w31211A2403131) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.6.1.v20100914-1218) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.6.0.v20100914-1218) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.6.1.v20100914-1218) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100914-1218) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.6.0.v20100914-1218) "EMF Code Generation UI"
org.eclipse.emf.common (2.6.0.v20100914-1218) "EMF Common"
org.eclipse.emf.common.ui (2.6.0.v20100914-1218) "EMF Common UI"
org.eclipse.emf.converter (2.6.0.v20100914-1218) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20100914-1218) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20100914-1218) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.6.1.v20100914-1218) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.6.0.v20100914-1218) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.6.0.v20100914-1218) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.6.0.v20100914-1218) "EMF Edit"
org.eclipse.emf.edit.ui (2.6.0.v20100914-1218) "EMF Edit UI"
org.eclipse.emf.mapping (2.6.0.v20100914-1218) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.6.0.v20100914-1218) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100914-1218) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.6.0.v20100914-1218) "EMF Mapping UI"
org.eclipse.epp.mpc (1.0.1.v20100826-2143) "EPP Marketplace Client"
org.eclipse.epp.package.jee.feature (1.3.1.20100916-1202) "Java EE IDE"
org.eclipse.gef (3.6.1.v20100908-1100-777B181A3Bz-6B663E7974242) "Graphical Editing Framework GEF"
org.eclipse.help (1.2.0.v20100427-7e7jEQFEp4jsWcboLU9l93) "Help System Base"
org.eclipse.jdt (3.6.1.r361_v20100714-0800-7z8XFUSFLFlmgLc5z-Bvrt8-HVkH) "Eclipse Java Development Tools"
org.eclipse.jpt.eclipselink.feature (2.3.2.v201008242310-7778BjBgJ9E99_H_DFBA) "Dali Java Persistence Tools - EclipseLink Support"
org.eclipse.jpt.feature (2.3.2.v201008242310-7N7UF75FD3wTgbUpoff0aT) "Dali Java Persistence Tools"
org.eclipse.jst.common.fproj.enablement.jdt (3.2.2.v201008170019-377AB8s73533J5J759F) "Eclipse Faceted Project Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature (3.2.2.v201008190400-7b7GHf2FSK2WBLQ2D-mrubYEOrRh) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.100.v201005241530-78-FF0DZRDKDDePSKwHj) "Axis2 Tools"
org.eclipse.jst.ws.cxf.feature (1.0.2.v201008232129-7H777DFAKlRiOX8lGdRoz0878J) "CXF Web Services Core"
org.eclipse.jst.ws.jaxws.feature (1.0.1.v201008232129-7E777CF8NcJSSK-UBTwXn) "JAX-WS Tools Core"
org.eclipse.mylyn_feature (3.4.2.v20100916-0100-e3x-7Z7f77FBBoPbPQeUoFeZXJ8) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.4.2.v20100916-0100-e3x-7D773BgJ9DH9fCc4CICE1) "Mylyn"
org.eclipse.mylyn.context_feature (3.4.2.v20100916-0100-e3x-777718s73533L3L135331) "Mylyn"
org.eclipse.mylyn.ide_feature (3.4.2.v20100916-0100-e3x-7G7J2BgJ9E99jDd49E994) "Mylyn"
org.eclipse.mylyn.java_feature (3.4.2.v20100916-0100-e3x-7D7F-AkF7B77V7c37B773) "Mylyn"
org.eclipse.mylyn.team_feature (3.4.2.v20100916-0100-e3x-4317w31211A1A012110) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.3.2.v20100916-0100-e3x-7F7e1FC7sReRSnX-DReRRD) "Mylyn"
org.eclipse.pde (3.6.1.r361_v20100727-7b7mFL-FET3dhESDgE5_bkJ) "PDE"
org.eclipse.platform (3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L) "Eclipse Platform"
org.eclipse.rcp (3.6.1.r361_v20100827-9OArFLdFjY-ThSQXmKvKz0_T) "Eclipse RCP"
org.eclipse.rse (3.2.1.v201008191400-7L78FA-8wqbPcNj4qa8R0eViy7vZ) "Remote System Explorer End-User Runtime"
org.eclipse.rse.core (3.2.1.v201008191400-7a7FFMWFC7sRd_Sga_dQoV) "RSE Core"
org.eclipse.rse.dstore (3.2.1.v201008191400-7L77FD8EVVFLXG4Oz0NjKF) "RSE DStore Services"
org.eclipse.rse.ftp (3.0.200.v201005221100-780Bg9oB56N5J9QBADD) "RSE FTP Service"
org.eclipse.rse.local (2.1.201.v201009071110-7B4F8PBgJ9Ai9dIaHNA9) "RSE Local Services"
org.eclipse.rse.ssh (3.0.100.v201005221100-7A2BhAkF77g7VEYDG7C) "RSE SSH Services"
org.eclipse.rse.telnet (2.2.100.v201005221100-7730AkF77g7UDXELEF) "RSE Telnet Service"
org.eclipse.rse.terminals (1.0.101.v201008191400-77-DH9uCFiO1U8MBKTDB3622) "RSE Terminals UI"
org.eclipse.rse.useractions (1.1.200.v201005221100-31A78s733L3D7H7933) "Remote System Explorer User Actions"
org.eclipse.tm.terminal (3.0.201.v201008191400-4-8_7w3121192A2511) "Target Management Terminal Widget"
org.eclipse.tm.terminal.ssh (2.0.200.v201005271030-3-A77w312116382141) "Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.0.200.v201005032000-3-8_7w311A1A271116) "Target Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.1.0.v201006030830-30-7w312117152351) "Target Management Terminal View"
org.eclipse.wst.common.fproj (3.2.2.v201008170019-377AB8s73533J5H335L) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.2.2.v201008170101-7C78FGMF9JgLWLMUUEMtXc) "Eclipse JavaScript Development Tools"
org.eclipse.wst.web_ui.feature (3.2.2.v201008100100-7O7CFbKEMf84nUlEJyX7-SPQjhYZ) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.2.2.v201008170029-7H7AFUQDxumQGOpBqffOY2f1qxDZ) "Eclipse XML Editors and Tools"
org.eclipse.wst.xml.xpath2.processor.feature (1.1.5.v201009091745-67K2BgJ9DIAXCbBWJO) "Eclipse XPath 2 Developers Tools"
org.eclipse.wst.xsl.feature (1.1.2.v201009091745-7S7WFAPFIpS-1-NbCE6tnacCXKP) "Eclipse XSL Developer Tools"
*** Plug-in Registry:
com.ibm.icu (4.2.1.v20100412) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
java_cup.runtime (0.10.0.v201005080400) "Java Cup" [Resolved]
javax.activation (1.1.0.v201005080500) "Apache Geronimo Activation Plug-in" [Resolved]
javax.jws (2.0.0.v201005080400) "Web Services Metadata" [Resolved]
javax.mail (1.4.0.v201005080615) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.5.0.v200910301333) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.wsdl (1.5.1.v201005080630) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v201005080631) "WSDL4J" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
javax.xml.bind (2.1.9.v201005080401) "XML Binding for Java" [Resolved]
javax.xml.rpc (1.1.0.v201005080400) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v201005080501) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v201004272200) "Java XML Streaming API" [Resolved]
javax.xml.ws (2.1.0.v200902101523) "Java API for XML Web Services (JAX-WS)" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v201004271650) "SourceForge LPG" [Resolved]
org.apache.ant (1.7.1.v20100518-1145) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v201005080400) "Apache Web Services" [Resolved]
org.apache.bcel (5.2.0.v201005080400) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100518-1140) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v201005080500) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v201004190315) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v201004212143) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.httpclient (3.1.0.v201005080502) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.1.0.v201005080500) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.3.0.v201005080501) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v201005080501) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.net (2.0.0.v200905272248) "Apache Commons Net" [Resolved]
org.apache.jasper (5.5.17.v201004212143) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.15.v201005080500) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20100518-1140) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20100518-1140) "Apache Lucene Analysis" [Resolved]
org.apache.oro (2.0.8.v201005080400) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.ws.commons.util (1.0.0.v20100518-1135) "WS Commons Util Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v201005080400) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v201005080400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.200.v20100427) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.0.v20100427) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.0.v20100427) "Ant UI" [Starting]
org.eclipse.compare (3.5.100.I20100526-0800) "Compare Support" [Active]
org.eclipse.compare.core (3.5.100.I20100526-0800) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.100.I20100505-1245) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20100512-1500) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20100505-1235) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.3.100.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100601-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.3.0.I20100601-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.3.0.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.200.v20100505) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.1.v20100831_r361) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.100.v20100520-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.1.R36x_v20100727-0745) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86_64 (1.1.201.R36x_v20100727-0745) "Core File System for Windows 64 bit" [Resolved]
org.eclipse.core.jobs (3.5.1.R36x_v20100824) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20100511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86_64 (1.0.100.I20100505-1245) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.6.0.R36x_v20100825-0600) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.6.0.v20100505) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20100517) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.3.0.v20100520) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.400.v20100505) "Core Variables" [Active]
org.eclipse.cvs (1.0.500.v201009090800) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.7.0.20090521092446) "Data Tools Platform User Documentation" [Starting]
org.eclipse.datatools.connectivity (1.2.1.v201007142147) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v200906161815) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.3.v201007080903) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200908130547) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v201004070709) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v200906161815) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation" [Starting]
org.eclipse.datatools.connectivity.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.connectivity.oda (3.3.1.v201008030730) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.3.v201005281018) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.3.1.v201008171206) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.4.v201007150318) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.4.v201007150318) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.1.v201004090942) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.2.1.v201008120113) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.2.0.v201002281800) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v200910270503) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.2.0.v201006250003) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.4.v201004270430) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.3.v200906161800) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.4.v201005211215) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.4.v201005211230) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.1.v201005211230) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.4.v201005211230) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v201006242214) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v201004070709) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201001180222) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v201004211630) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200908130512) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201002041100) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200906161800) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.2.v201001131420) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.2.v201007141330) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.1.v201001151620) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.1.v201006031500) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200908130544) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.101.v201004211630) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.2.v201005051303) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.1.v200906161800) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041100) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201002041100) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200906020900) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjectedit or.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111150) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200906020900) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200906020900) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090458) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.7.0.v201005281800) "Eclipse Data Tools Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.2.v201002130228) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v201002161452) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.4.v201002250945) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.1.v201002161452) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.1.1.v201008100700) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.1.v201004291415) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v200907031118) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.2.0.v201005241300) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.2.0.v201005250945) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.1.v201002270530) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.1.v201005250945) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation" [Starting]
org.eclipse.datatools.sqltools.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.2.v201004291415) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200906030654) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.2.0.v201004291415) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.1.0.v201005260930) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.1.0.v201005261700) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.1.v201004060545) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.1.200810071) "Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.3.v201009131745) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.1.v201005130745) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.1.v201005250945) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.1.v201005250945) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.6.0.v20100519) "Debug Core" [Active]
org.eclipse.debug.ui (3.6.1.v20100901_r361) "Debug UI" [Active]
org.eclipse.draw2d (3.6.1.v20100913-2020) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.dstore.core (3.2.1.v201009071110) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.101.v200907301400) "RSE DStore Platform Support" [Starting]
org.eclipse.ecf (3.1.0.v20100529-0735) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (4.0.0.v20100529-0735) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.1.0.v20100529-0735) "ECF Identity API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.1.0.v20100529-0735) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20100529-0735) "ECF HttpClient Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20100529-0735) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20100529-0735) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20100529-0735) "ECF Core API" [Resolved]
org.eclipse.emf (2.6.0.v20100914-1218) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.6.1.v20100905-1631) "EMF Ant Tasks" [Starting]
org.eclipse.emf.codegen (2.6.0.v20100914-1218) "EMF Code Generation" [Starting]
org.eclipse.emf.codegen.ecore (2.6.1.v20100914-1218) "EMF Ecore Code Generator" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100914-1218) "EMF Ecore Code Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.6.0.v20100914-1218) "EMF Code Generation UI" [Starting]
org.eclipse.emf.common (2.6.0.v20100914-1218) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.6.0.v20100914-1218) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.5.0.v20100914-1218) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.2.0.v20100914-1218) "EMF Data Binding" [Starting]
org.eclipse.emf.databinding.edit (1.2.0.v20100914-1218) "EMF Edit Data Binding" [Starting]
org.eclipse.emf.ecore (2.6.1.v20100914-1218) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.5.1.v20100907-1643) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.5.0.v20100521-1846) "EMF Change Edit" [Starting]
org.eclipse.emf.ecore.edit (2.6.0.v20100914-1218) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.editor (2.6.0.v20100914-1218) "EMF Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.5.0.v20100521-1846) "EMF XML/XMI Persistence" [Active]
org.eclipse.emf.edit (2.6.0.v20100914-1218) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.6.0.v20100914-1218) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.6.0.v20100521-1846) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.6.0.v20100521-1846) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.6.0.v20100521-1846) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.6.0.v20100521-1846) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.6.0.v20100521-1846) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.6.0.v20100914-1218) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.6.0.v20100914-1218) "EMF Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100914-1218) "EMF Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.5.0.v20100521-1847) "EMF Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v20100521-1847) "EMF Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.5.0.v20100521-1847) "EMF Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.5.0.v20100521-1847) "EMF Ecore to XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.6.0.v20100914-1218) "EMF Mapping UI" [Starting]
org.eclipse.epp.mpc.core (1.0.0.v20100826-2143) "Marketplace Client" [Resolved]
org.eclipse.epp.mpc.help.ui (1.0.0.v20100826-2143) "Marketplace Client Help" [Resolved]
org.eclipse.epp.mpc.ui (1.0.1.v20100826-2143) "EPP Marketplace Client" [Starting]
org.eclipse.epp.package.common (1.3.1.20100913-1228) "EPP Common Bundle" [Resolved]
org.eclipse.epp.package.jee (1.3.1.20100913-1228) "Java EE IDE" [Resolved]
org.eclipse.epp.usagedata.gathering (1.3.0.R201005261100) "Usage Data Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.3.0.R201005261100) "Usage Data Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.3.0.R201005261100) "Usage Data UI Plug-in" [Starting]
org.eclipse.equinox.app (1.3.1.R36x_v20100803) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20100503) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.100.v20100503) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.2.1.R36x_v20100803) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.0.v20100503) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20100503) "Equinox Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.200.v20100505) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.0.v20100503) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.0.v20100503) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.0.v20100503) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.200.v20100421) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.1.0.v20100507) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86_64 (1.1.1.R36x_v20100810) "Equinox Launcher Win32 X86_64 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.1.R36x_v20100901) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.200.v20100601) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.0.2.R36x_v20100804) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.0.2.R36x_v20100823) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.201.R36x_v20100823) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.202.R36x_v20100727) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.0.0.v20100503) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.0.0.v20100518) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.engine (2.0.0.v20100606) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.0.v20100518) "Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.100.v20100503) "Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20100503a) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.0.0.v20100601) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.200.v20100503a) "Equinox Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.repository (1.1.0.v20100513) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.0.0.v20100510) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.publisher (1.1.2.v20100824-2220) "Equinox Provisioning Publisher" [Starting]
org.eclipse.equinox.p2.ql (2.0.0.v20100503a) "p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.0.v20100525) "Dropin Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.repository (2.0.1.R36x_v20100823) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.1.R36x_v20100823) "Equinox p2 repository tools." [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.0.2.R36x_v20100823) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.200.v20100503a) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (2.0.0.v20100518) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.0.0.v20100519) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.sdk (1.0.100.v20100513) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20100507-1815) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.101.R36x_v20100823) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.201.R36x_v20100823) "Update site repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.3.0.v20100503) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.0.v20100503) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.0.200.v20100503) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.200.v20100503) "Equinox Security Default UI" [Active]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20100503) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20100503) "Simple Configurator Manipulator" [Active]
org.eclipse.equinox.util (1.0.200.v20100503) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.6.1.v20100712-1224) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.5.0.v20100524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20100427) "Help Application Server" [Starting]
org.eclipse.help.base (3.5.2.v201009090800) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.2.r36_v20100702) "Help System UI" [Starting]
org.eclipse.help.webapp (3.5.2.r36_r20100816) "Help System Webapp" [Starting]
org.eclipse.jdt (3.6.1.v201009090800) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.401.R36_v20100727-0110) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.301.R36_v20100727-0110) "Java Compiler Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.300.v20100513-0845) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.300.v20100513-0845) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.100.v_A68_R36x) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.6.1.v_A68_R36x) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.3.0.v20100520-0800) "Java Code Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.6.1.v20100715_r361) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.5.0.v20100602-0830) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.user (3.6.1.r361_v20100721-0800) "Eclipse Java development user guide" [Resolved]
org.eclipse.jdt.junit (3.6.1.r361_v20100825-0800) "Java Development Tools JUnit support" [Starting]
org.eclipse.jdt.junit.core (3.6.1.r361_v20100825-0800) "Java Development Tools JUnit core support" [Starting]
org.eclipse.jdt.junit.runtime (3.4.200.v20100526-0800) "Java Development Tools JUnit Runtime Support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.1.100.v20100526-0800) "Java Development Tools JUnit4 Runtime Support" [Resolved]
org.eclipse.jdt.launching (3.5.100.v20100526) "Java Development Tools Launching Support" [Active]
org.eclipse.jdt.ui (3.6.1.r361_v20100825-0800) "Java Development Tools UI" [Active]
org.eclipse.jem (2.0.400.v201005110200) "Java EMF Model" [Starting]
org.eclipse.jem.beaninfo (2.0.300.v200905030615) "Java EMF Model BeanInfo (Introspection) Support" [Starting]
org.eclipse.jem.beaninfo.vm (2.0.300.v201004110600) "JEM Beaninfo VM Jar" [Resolved]
org.eclipse.jem.beaninfo.vm.common (2.0.300.v201004110600) "JEM Beaninfo Common Jar" [Resolved]
org.eclipse.jem.proxy (2.0.300.v201006080510) "Java EMF Model Proxy Support" [Starting]
org.eclipse.jem.util (2.1.2.v201008120100) "Java EMF Model Utilities" [Starting]
org.eclipse.jem.workbench (2.0.300.v200910290230) "Java EMF Model Workbench Support" [Starting]
org.eclipse.jface (3.6.1.M20100825-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.4.0.I20100601-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.6.1.r361_v20100825-0800) "JFace Text" [Resolved]
org.eclipse.jpt.branding (2.3.2.v201008242310) "Dali Java Persistence Tools" [Resolved]
org.eclipse.jpt.core (2.3.2.v201008252310) "Dali Java Persistence Tools - Core" [Starting]
org.eclipse.jpt.db (1.2.201.v201008242310) "Dali Java Persistence Tools - DB" [Starting]
org.eclipse.jpt.db.ui (1.1.200.v201003290000) "Dali Java Persistence Tools - DB UI" [Resolved]
org.eclipse.jpt.doc.user (1.3.1.v201007142310) "Dali Java Persistence Tools - Documentation" [Resolved]
org.eclipse.jpt.eclipselink.branding (2.3.2.v201008242310) "Dali Java Persistence Tools - EclipseLink Support" [Resolved]
org.eclipse.jpt.eclipselink.core (1.3.1.v201007142310) "Dali Java Persistence Tools - EclipseLink Support - Core" [Starting]
org.eclipse.jpt.eclipselink.core.ddlgen (1.0.300.v201003290000) "Dali Java Persistence Tools - EclipseLink Support - DDL Generation" [Resolved]
org.eclipse.jpt.eclipselink.jaxb.core.schemagen (1.0.0.v201005120000) "Dali Java Persistence Tools - EclipseLink JAXB Support - Schema Generation" [Resolved]
org.eclipse.jpt.eclipselink.ui (1.3.0.v201004280001) "Dali Java Persistence Tools - EclipseLink Support - UI" [Starting]
org.eclipse.jpt.gen (1.3.100.v201004260000) "Dali Java Persistence Tools - Entity Gen" [Resolved]
org.eclipse.jpt.jaxb.core.schemagen (1.0.1.v201006300000) "Dali Java Persistence Tools - JAXB Support - Schema Generation" [Resolved]
org.eclipse.jpt.jaxb.ui (1.0.1.v201006300000) "Dali Java Persistence Tools - JAXB Support - UI" [Starting]
org.eclipse.jpt.ui (2.3.2.v201008252310) "Dali Java Persistence Tools - UI" [Starting]
org.eclipse.jpt.utility (1.5.0.v201005100000) "Dali Java Persistence Tools - Utility" [Resolved]
org.eclipse.jsch.core (1.1.200.I20100505-1245) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.300.I20100505-1245) "JSch UI" [Starting]
org.eclipse.jsf.branding (3.2.0.v20100522) "JavaServer Faces Tools" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.300.v200908252030) "Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.300.v201004141630) "Annotation Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.300.v201002081900) "Annotations UI Plug-in" [Starting]
org.eclipse.jst.common.frameworks (1.1.402.v201009081300) "Integration Plug-in" [Starting]
org.eclipse.jst.common.project.facet.core (1.4.102.v201008182136) "Eclipse Faceted Project Framework JDT Enablement" [Active]
org.eclipse.jst.common.project.facet.ui (1.4.102.v201008182136) "Eclipse Faceted Project Framework JDT Enablement UI" [Starting]
org.eclipse.jst.common.ui (1.0.2.v201009080200) "Common JST UI Plug-in" [Starting]
org.eclipse.jst.ejb.doc.user (1.1.200.v20100519) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.501.v201007070821) "WTP EJB UI Plug-in" [Starting]
org.eclipse.jst.ejb.ui.infopop (1.0.300.v2010022311013) "EJB infopop" [Starting]
org.eclipse.jst.j2ee (1.1.402.v201009151730) "Java EE Component" [Starting]
org.eclipse.jst.j2ee.core (1.2.2.v201008120100) "J2EE Core Component" [Starting]
org.eclipse.jst.j2ee.doc.user (1.1.300.v201007141655) "J2EE tools documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.401.v201007150400) "EJB component Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.300.v201003112036) "EJB Annotation Model Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.200.v200909290826) "EJB Emitter Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.200.v201004290730) "EJB Annotations Ui Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.2.100.v201003112036) "Xdoclet Annotations Plug-in" [Starting]
org.eclipse.jst.j2ee.infopop (1.0.300.v200805140415) "J2EE tools infopops" [Resolved]
org.eclipse.jst.j2ee.jca (1.1.400.v201005270700) "JCA Plug
Re: Error while trying the HelloWorld tutorial [message #652213 is a reply to message #652211] Thu, 03 February 2011 02:11 Go to previous messageGo to next message
Posting this again as the full details didn't come in my last mesage also..
*** Date: Thursday, February 3, 2011 12:42:26 PM India Standard Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20100909-0800
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
-showsplash
-launcher
E:\ECLIPSE-EE-3.6\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
E:\ECLIPSE-EE-3.6\eclipse\plugins/org.eclipse.equinox.launch er.win32.win32.x86_64_1.1.1.R36x_v20100810\eclipse_1309.dll
-startup
E:\ECLIPSE-EE-3.6\eclipse\plugins/org.eclipse.equinox.launch er_1.1.0.v20100507.jar
-exitdata
1980_58
-product
org.eclipse.epp.package.jee.product
-vm
C:\Windows\system32\javaw.exe
eclipse.home.location=file:/E:/ECLIPSE-EE-3.6/eclipse/
eclipse.launcher=E:\ECLIPSE-EE-3.6\eclipse\eclipse.exe
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=epp.package.jee
eclipse.product=org.eclipse.epp.package.jee.product
eclipse.vm=C:\Windows\system32\javaw.exe
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=E:\ECLIPSE-EE-3.6\eclipse\plugins/org.eclips e.equinox.launcher_1.1.0.v20100507.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\Users\admin\AppData\Local\Temp\
java.library.path=C:\Windows\system32;.;C:\Windows\Sun\Java\ bin;C:\Windows\system32;C:\Windows;C:\Program Files (x86)\MiKTeX 2.8\miktex\bin;D:\DevSuiteHome_1\BIN\bin;C:\Windows\system32 ;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\Win dowsPowerShell\v1.0\;C:\Program Files\Java\jdk1.6.0_23\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_23-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_23
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=19.0-b09
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=e:\ECLIPSE-EE-3 .6\eclipse\plugins\org.eclipse.platform_3.6.1.v201009090800\ splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Windows 7
os.version=6.1
osgi.arch=x86_64
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=E:\ECLIPSE-EE-3.6\eclipse\configuration\org .eclipse.osgi\bundles
osgi.configuration.area=file:/E:/ECLIPSE-EE-3.6/eclipse/conf iguration/
osgi.framework=file:/e:/ECLIPSE-EE-3.6/eclipse/plugins/org.e clipse.osgi_3.6.1.R36x_v20100806.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.1.R36x_v20100806
osgi.install.area=file:/E:/ECLIPSE-EE-3.6/eclipse/
osgi.instance.area=file:/E:/Bpel/
osgi.instance.area.default=file:/C:/Users/admin/workspace/
osgi.logfile=E:\Bpel\.metadata\.log
osgi.manifest.cache=E:\ECLIPSE-EE-3.6\eclipse\configuration\ org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=e:\ECLIPSE-EE-3.6\eclipse\plugins\org.ec lipse.platform_3.6.1.v201009090800\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=e:\ECLIPSE-EE-3.6\eclipse\plugins
osgi.tracefile=E:\Bpel\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=64
sun.boot.class.path=C:\Program Files\Java\jre6\lib\resources.jar;C:\Program Files\Java\jre6\lib\rt.jar;C:\Program Files\Java\jre6\lib\sunrsasign.jar;C:\Program Files\Java\jre6\lib\jsse.jar;C:\Program Files\Java\jre6\lib\jce.jar;C:\Program Files\Java\jre6\lib\charsets.jar;C:\Program Files\Java\jre6\lib\modules\jdk.boot.jar;C:\Program Files\Java\jre6\classes
sun.boot.library.path=C:\Program Files\Java\jre6\bin
sun.cpu.endian=little
sun.cpu.isalist=amd64
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=
user.country=US
user.dir=E:\ECLIPSE-EE-3.6\eclipse
user.home=C:\Users\admin
user.language=en
user.name=admin
user.timezone=Asia/Calcutta
user.variant=
*** Features:
org.eclipse.jst.j2ee.jca (1.1.400.v201005270700) "JCA Plug-in" [Starting]
org.eclipse.jst.j2ee.jca.ui (1.1.400.v201004150700) "WTP JCA UI Plug-in" [Starting]
org.eclipse.jst.j2ee.navigator.ui (1.1.402.v201009081300) "J2EE Extensions to Common Navigato
Re: Error while trying the HelloWorld tutorial [message #652371 is a reply to message #652213] Thu, 03 February 2011 12:08 Go to previous messageGo to next message
That's odd...I don't see the org.eclipse.bpel.* plugins in the Plugin Registry. Is it possible you took this snapshot before eclipse had finished loading all of the plugins?
Also, not all of the configuration details posted (again!) Can you please copy the configuration to http://pastebin.com (or somewhere similar) and post a link to it here?
The plugins and JRE that did come through, look OK to me though, so I'm not sure what the problem could be Sad
Re: Error while trying the HelloWorld tutorial [message #652470 is a reply to message #652371] Fri, 04 February 2011 01:36 Go to previous messageGo to next message
Extremely sorry about the same. I have now copied two files at
ftp://ftp.tifr.res.in/nihita
The config_eclipse gives the configuration of my eclipse.
config_eclipse_plug-in is the configuratoion that appears in the eclipse plugin that starts from my eclipse for the bpel designer.
Hope this works out..
Thanks sooooooo much for your help,
Re: Error while trying the HelloWorld tutorial [message #652616 is a reply to message #652470] Fri, 04 February 2011 12:48 Go to previous messageGo to next message
Hmm, I replied earlier but it looks like my comments weren't posted, so I'll try again.
I still don't see the bpel plugins. Is it possible that one or more of the plugins were disabled by the workbench because they could not be activated? If this is the case, there should be something in the log. Are you able to create and edit a *.bpel file?
The SAXParserException is just a warning because there is no schema information for the deploy.xml file, but what has me worried is the NullPointerException at org.eclipse.bpel.ui.util.BPELEditModelClient.getExtensionsFi le(BPELEditModelClient.java:147)
Can you please export the project and post it to ftp://ftp.tifr.res.in/nihita? Maybe there is a text file encoding issue with the editor.
Thanks!
Bob
Re: Error while trying the HelloWorld tutorial [message #652671 is a reply to message #652616] Sat, 05 February 2011 00:29 Go to previous messageGo to next message
I have copied two files at ftp://ftp.tifr.res.in/nihita
MyBpelProject.jar is created using the Export->Java Jar in eclipse and Bpel.zip is the zipped folder of my workspace. the workspace directory there contains the bpel file.
As soon as i start my bpel designer plug-in the exception is thrown though the plugin opens and I am able to open and edit bpel file. Problem comes with deploy.xml
Re: Error while trying the HelloWorld tutorial [message #652913 is a reply to message #652671] Mon, 07 February 2011 10:08 Go to previous messageGo to next message
Ah ha! I see the problem now Smile
The BPEL process file (*.bpel) and all related artifacts (*.wsdl and *.xsd if any) must be in the same directory as the deploy.xml file. But it looks like when you created the HelloWorld.bpel file, you selected the project root as the files' location (this is done in the last page of the New BPEL Process wizard). If you simply click "Finish" without changing the selection on this wizard page, or if you select the "bpelContent" folder in your project, then everything should work.
HTH
Bob
Re: Error while trying the HelloWorld tutorial [message #653032 is a reply to message #652913] Tue, 08 February 2011 02:21 Go to previous messageGo to next message
Thanks you soooooooooo much. It worked now. I could never have debugged this. The warning message of
org.xml.sax.SAXParseException still appears when the application is started but I guess I can ignore it. Another thing which I wanted to view but am not able to are the console messages (Page 20 and 21) on running the HelloWorld process from Web Service Explorer. The output string displays the input given so it is executing fine but I also wanted to see the execution trace in the console which I am not able to see. It must be some setting which I am not aware of. If possible, please let me know of that.
Thanks, I can now get started with writing my own BPEL processes..
Re: Error while trying the HelloWorld tutorial [message #653110 is a reply to message #653032] Tue, 08 February 2011 09:45 Go to previous messageGo to next message
I'm glad that worked for you Smile
This is an easy mistake to make and the ODE Deployment editor should probably display a more obnoxious warning dialog if it does not find any BPEL process files in the current folder - right now it simply displays an error message at the top of the editor form.
ODE uses a log4j property file to control the level of tracing output. You should have a file in $CATALINA_HOME/webapps/ode/WEB-INF/classes called log4j.properties. Do a web search for "log4j.category.org.apache.ode" to learn how to configure this file.
One last thing to watch out for: the New BPEL Process wizard creates a WSDL for you, but it does not construct the service port address properly for ODE. The default address generated by the wizard is:
http://localhost:8080/HelloWorld
but for ODE it should look like this:
http://localhost:8080/ode/processes/HelloWorld
Happy BPELing Smile
Re: Error while trying the HelloWorld tutorial [message #764143 is a reply to message #653110] Sun, 11 December 2011 08:40 Go to previous messageGo to next message
Hey guys,
I have a similar issue. I am getting a very similar error message (which i am posting below).
As bob has suggested, i checked and see that all my *.wsdl,*.bpel and deploy.xml are in hte same folder. But still, no interface is present in the drop-down of inbound interfaces and the outbound interfaces...
I have tried putting all the files in the project root folder as well as in the bpelcontent folder.
I am using eclipse 3.7.1 and tomcat 5.5 and the error message i am getting on console is
I am unable to post any links as i haven't yet posted 5 messages..
pastebin.com/VKfWgm9A is where the log of the error message and
I have uploaded both my versions of the helloworld project in here:
qfpost.com/download.do?get=2c71ab2aa51053907e76e9e06681725d
any help will be much appreciated!!
Thanks and Regards,
-Anand
Re: Error while trying the HelloWorld tutorial [message #764357 is a reply to message #764143] Sun, 11 December 2011 21:36 Go to previous message
Hi folks,
Please ignore the previous post. I took a break and started the whole thing again and i see its populating fine.. I did try restarting, but obviously should have missed restarting something.. that was a false alarm and i ran into a couple more ODE issues for which i found the solution in the forums.
Thanks again to nihita and bob for discussing the original problem again...
-Anand
Previous Topic:How to get the P2 repository for the BPEL Designer?
Next Topic:Custom bpel designer, add feature that can drag and drop existing web services to canvas.
Current Time: Wed Jul 23 01:22:50 EDT 2025
Powered by FUDForum. Page generated in 0.07025 seconds
