Home » Modeling » M2T (model-to-text transformation) » [Xpand] Verifying Xpand output(Test strategy for the Xpand generator)
[Xpand] Verifying Xpand output [message #651353] Sat, 29 January 2011 13:49 Go to next message
there are solutions testing a Xtext grammar and the generated object structure but how is it, if I want to test the generator?
Is there a possibility creating tests for the generated output of xpand-templates or do I have to do a simple text-diff if I have for example a reference-output file?
Thank you
Michael
Re: [Xpand] Verifying Xpand output [message #651354 is a reply to message #651353] Sat, 29 January 2011 14:04 Go to previous message
Hello Michael,
Generally you could compare the generated output against a defined result file.
But often it is better to test the generated code on a runtime/ functional base (e.g. using unit tests) and not on source code base - since it imho does not play a role if the generated code stays the same even for the least blank Wink.
If you are interested in testing Xtend / Xpand on a more fine granular level then take a look at fit4oaw:
http://sourceforge.net/projects/fit4oaw/
http://kthoms.wordpress.com/?s=fit4oaw
http://blogs.itemis.de/feltes/2009/03/27/test-driven-mdsd-mi t-fit4oaw/
~Christian
Previous Topic:[Acceleo 3] - Expression in <init> clause of template
Next Topic:Eclipse Community Awards
Current Time: Sat Aug 30 20:51:58 EDT 2025
Powered by FUDForum. Page generated in 0.02709 seconds
