CriteriaQuery<Boolean> fails with NoResultException but works when running generated SQL manua [message #651301] |
Fri, 28 January 2011 14:32  |
Hi All,
Hope someone can shed some light on a problem I have been having.
I have two objects - Object1 and Object2. Object1 and Object2 have a bidirectional OneToOne mapping to each other. Object1 owns the relationship. Object2 has a number of Boolean fields that are protected fields of a MappedSuperclass. Those boolean fields are what I want to query for.
Here are two queries I have tried.
Query 1: (This is the query I want to work)
CriteriaQuery<Boolean> cq = cb.createQuery(Boolean.class);
Root<Object1> obj1 = cq.from(Object1.class);
Join<Object1, Object2> obj2 = obj1.join(Object1_.object2);
cq.select(obj2.get(A_METHOD_ARG));
cq.where(
cb.and(
cb.equal(obj1.get(Object1_.field1), A_METHOD_ARG),
cb.equal(obj1.get(Object1_.field2), A_METHOD_ARG)
TypedQuery<Boolean> query = em.createQuery(cq);
I get a NoResultException when I run this. The SQL that is being generated by EclipseLink 2.2 is "SELECT t0.MYBOOLEAN FROM Object2 t0, Object1 t1 WHERE (((t1.FIELD1 = 1) AND (t1.FIELD2 = 1)) AND (t0.ID = t1.OBJECT2_ID))" and if I run this directly on the MySQL 5.5 database I get a single column with a 1 value in it so the query is working when run manually. Confused on that...
Query 2: (I can make this work but not optimal)
CriteriaQuery<Object1> cq = cb.createQuery(Object1.class);
cq.select(obj1);
cq.where(
cb.and(
TypedQuery< Object1> query = em.createQuery(cq);
This works and retrieves my Object1 using the same parameters. I can then retrieve Object2 and manually get the Boolean value that is stored in the DB. Is the join causing problems somehow?
Thanks for any help!
FUDForum. Page generated in 0.25017 seconds
